ASTRO_CLOCK?
jjames
Could someone post an example for the usage of ASTRO_CLOCK? Should I put this in define_program? I need sunrise & sunset times everyday to manage some lighting controls.
http://www.amx.com/products/i!-TimeManager.asp
You get a button event when Sunrise or Sunset time has been reached. (Of course you got to make sure your latitude/longitude settings are correct)...
(***********************************************************) (* BUTTON_EVENT: Sunrise Channel *) (* PURPOSE: Channel is pushed (and turned on) when *) (* the Sunrise occurs *) (***********************************************************) BUTTON_EVENT[vdvTmEvents,nTmSunriseChannel] { PUSH: { SEND_STRING 0,"'Sunrise occured at ',TIME" } } (***********************************************************) (* BUTTON_EVENT: Sunset Channel *) (* PURPOSE: Channel is pushed (and turned on) when *) (* the Sunset occurs *) (***********************************************************) BUTTON_EVENT[vdvTmEvents,nTmSunsetChannel] { PUSH: { SEND_STRING 0,"'Sunset occured at ',TIME" } }// full code
(*********************************************************************) (* AMX Corporation *) (* Copyright (c) 2000 - 2005 AMX Corporation. All rights reserved. *) (*********************************************************************) (* please refer to EULA.TXT for software license agreement *) (*********************************************************************) (* *) (* i!-TimeManager (1.0.11) *) (* *) (*********************************************************************) PROGRAM_NAME='i!-TimeManagerTest' (***********************************************************) (*{{PS_SOURCE_INFO(PROGRAM STATS) *) (***********************************************************) (* ORPHAN_FILE_PLATFORM: 1 *) (***********************************************************) (*}}PS_SOURCE_INFO *) (***********************************************************) (***********************************************************) (* DEVICE NUMBER DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_DEVICE vdvTmEvents = 33001:1:0 dvTmTimeSync = 0:3:0 (***********************************************************) (* CONSTANT DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_CONSTANT (* Timeserver protocols *) nProtoNone = 0 nProtoDaytime = 1 nProtoTime = 2 nProtoSNTP = 3 nProtoSNTPBCast = 4 (* Channels *) nTmSunriseChannel = 1 nTmSunsetChannel = 2 nTmDstChannel = 3 nTmTimeChangeChannel = 4 (* Levels *) nTmGmtEffLevel = 1 nTmGmtLevel = 2 nTmLongLevel = 3 nTmLatLevel = 4 (***********************************************************) (* DATA TYPE DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_TYPE (***********************************************************) (* VARIABLE DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_VARIABLE (* Timezone *) CHAR dTmTzName[100] CHAR dTmTzDesc[10] DOUBLE dTmTzGmtOffset CHAR strTmTzDstRules[1000] (* Location *) CHAR strTmLocName[100] DOUBLE dTmLocLong DOUBLE dTmLocLat (* Timeserver *) INTEGER nTmTsProtocol INTEGER nTmTsCheckTime CHAR strTmTsServer[100] (***********************************************************) (* SUBROUTINE DEFINITIONS GO BELOW *) (***********************************************************) (***********************************************************) (* STARTUP CODE GOES BELOW *) (***********************************************************) DEFINE_START (***********************************************************) (* Step 1 - Configure the timezone: *) (***********************************************************) // Configure Timezone // Parameter 1: Timezone Name. ex: "Eastern" // Parameter 2: Timezone description. ex: "E%sT" // Parameter 3: Timezone GMT offset in hours. ex: -5.0 dTmTzName = 'Central' dTmTzDesc = 'C%sT' dTmTzGmtOffset = -6.0 // Configure Timezone Rules *) // Parameter 1: Daylight savings string. ex: "None", "US" or custom. // Custom string: "Month" "DayDescription" "Time" "Offset From Std" "Descrption" // "Month": Month name ex: "Apr" // "Time" Time to activate (hh:mm:ss, 24 hour). ex: "02:00:00" // "Offset From Std" Time to offset from GMT (hh:mm:ss, 24 hour). ex: "01:00:00" // "Description" String to replace "%s" with in Timezone description. ex: 'D' // "DayDescription" Day Description. Fixed Date, Last Day Of Week or // First Day of Week Before/After Date // Fixed ex: "15" // Last Day of Week ex: "LastSunday" // First Day of Week Beforer DATE-ex: "Sun<=24" // First Day of Week After DATE-ex: "Sun>=1" strTmTzDstRules = 'US' (***********************************************************) (* Step 2 - Configure Physical Location: *) (***********************************************************) // Configure Physical Location // Parameter 1: Location Name. ex: 'Seattle' // Parameter 2: Location Longitude. ex: -122.33 (>0 == East, < 0 == West) // Parameter 3: Location Latitude. ex: 47.6 (>0 == North, < 0 == South) strTmLocName = 'Dallas' dTmLocLong = -96.76 dTmLocLat = 32.79 // You can find longitude/latitude values and descriptions at: // http://geography.about.com/cs/latitudelongitude/ // http://www.census.gov/cgi-bin/gazetteer // http://www.njdxa.org/landl-lookup-dx.shtml (***********************************************************) (* Step 3 - Configure Time servers: *) (***********************************************************) // Configure Time servers // Parameter 1: Protocol, 0=Disbaled, 1=DayTime(13/udp, 13/tcp), 2=Time(37/udp, 37/tcp), 3=SNTP(123/udp), 4=SNTP Broadcast (137/udp). ex: 2 // Parameter 3: Default Server. ex: 'mytimeserver.mydomain.com'. Leave blank to read from time sevrer file (time/nist_svr.lst) // Parameter 2: Check Time interval in seconds. Use 0 for default (2 hours). ex: 3600 // Parameter 4: Prefered Index of Timeservers in list. ex: 2 // Notes: If parameters 3 is supplied, parameter 4 is ignored // If paramater 3 is an empty string and parameter 4 is 0, a default will be picked from the list is possible //nProtoNone = 0 //nProtoDaytime = 1 //nProtoTime = 2 //nProtoSNTP = 3 //nProtoSNTPBCast = 4 nTmTsProtocol = nProtoSNTP nTmTsCheckTime = 0 strTmTsServer = '' (***********************************************************) (* Alternate Manual Timezone configurations: *) (***********************************************************) // These are shown for example purposes and represent information that is not guaranteed to be correct! // Here is an exmaple configuration for Santiago, Chile which is -4 hours behind GMT and observes Daylight savings starting // on the Saturday on or after October 9th at midnight (jump ahead 1 hour) and the Saturday on or after the 9th of March at midnight (jump back 1 hour) // and describes the time as "hh:mm:ss CST" or "hh:mm:ss CDT" depending on Daylight savings and is located at "33s27, 70w40": // //dTmTzName = 'Santiago' //dTmTzDesc = 'C%sT' //dTmTzGmtOffset = -4.0 //strTmTzDstRules = "'Oct Sat>=9 00:00:00 01:00:00 D',$FF,'Mar Sat>=9 00:00:00 00:00:00 S'" // // AND // //strTmLocName = 'Santiago' //dTmLocLong = -70.67 //dTmLocLat = -33.45 // Here is an exmaple configuration for Sydney, Australia which is +10 hours ahead of GMT and observes Daylight savings starting // on the Last Sunday in October 2:00 AM (jump ahead 1 hour) and the Last Sunday in March at 3:00 AM (jump back 1 hour) // and describes the time as "hh:mm:ss EST" regardless of Daylight savings and is located at "33s52, 151e13": // //dTmTzName = 'Sydney' //dTmTzDesc = 'EST' //dTmTzGmtOffset = 10.0 //strTmTzDstRules = "'Oct LastSun 02:00:00 01:00:00 X',$FF,'Mar LastSun 03:00:00 00:00:00 X'" // // AND // //strTmLocName = 'Sydney' //dTmLocLong = 151.22 //dTmLocLat = -33.86 // Here is the example configuration for London, England which uses GMT and observes Daylight savings starting // on the last Sunday in March at 1:00 AM (jump ahead 1 hour) and the Last Sunday in October at 2:00 AM (jump back 1 hour) // and describes the time as "hh:mm:ss BST" or "hh:mm:ss GMT" depending on Daylight savings and is located at "51n30, 0w10": // //dTmTzName = 'London' //dTmTzDesc = '%s' //dTmTzGmtOffset = 0.0 //strTmTzDstRules = "'Mar LastSun 01:00:00 01:00:00 BST',$FF,'Oct LastSun 02:00:00 00:00:00 GMT'" // // AND // //strTmLocName = 'London' //dTmLocLong = -0.16 //dTmLocLat = 51.50 (***********************************************************) (* THE MODULE CODE GOES BELOW *) (***********************************************************) DEFINE_MODULE 'i!-TimeManagerMod' mdlTM(vdvTmEvents, dvTmTimeSync, (* Timezone *) dTmTzName, dTmTzDesc, dTmTzGmtOffset, strTmTzDstRules, (* Location *) strTmLocName, dTmLocLong, dTmLocLat, (* Timeserver *) nTmTsProtocol, nTmTsCheckTime, strTmTsServer) (***********************************************************) (* THE EVENTS GOES BELOW *) (***********************************************************) DEFINE_EVENT (***********************************************************) (* BUTTON_EVENT: Sunrise Channel *) (* PURPOSE: Channel is pushed (and turned on) when *) (* the Sunrise occurs *) (***********************************************************) BUTTON_EVENT[vdvTmEvents,nTmSunriseChannel] { PUSH: { SEND_STRING 0,"'Sunrise occured at ',TIME" } } (***********************************************************) (* BUTTON_EVENT: Sunset Channel *) (* PURPOSE: Channel is pushed (and turned on) when *) (* the Sunset occurs *) (***********************************************************) BUTTON_EVENT[vdvTmEvents,nTmSunsetChannel] { PUSH: { SEND_STRING 0,"'Sunset occured at ',TIME" } } (***********************************************************) (* BUTTON_EVENT: DST Activity Channel *) (* PURPOSE: Channel is pushed (and turned on) when *) (* the DST rules affect a time change with *) (* a non-zero time offset (DST Active) *) (* Channel is release (and turned off) when *) (* the DST rules affect a time change with *) (* a zero time offset (DST Inactive) *) (***********************************************************) BUTTON_EVENT[vdvTmEvents,nTmDstChannel] { PUSH: { SEND_STRING 0,"'DST is now active: ',TIME" } RELEASE: { SEND_STRING 0,"'DST is now inactive: ',TIME" } } (***********************************************************) (* BUTTON_EVENT: Time Change Channel *) (* PURPOSE: Channel is pushed (and pulsed) when *) (* the Time is changed by a communication *) (* with a time server. *) (***********************************************************) BUTTON_EVENT[vdvTmEvents,nTmTimeChangeChannel] { PUSH: { SEND_STRING 0,"'Time adjusted by time server. New Time is ',TIME" } } (***********************************************************) (* LEVEL_EVENT: Effective GMT Offset *) (* PURPOSE: Level is sent whenever the effective GMT *) (* offset is changed. The effective offset *) (* is the real GMT offset with DLS correction*) (***********************************************************) LEVEL_EVENT[vdvTmEvents,nTmGmtEffLevel] { SEND_STRING 0,"'Effective GMT Offset=',FTOA(LEVEL.VALUE)" } (***********************************************************) (* LEVEL_EVENT: GMT Offset *) (* PURPOSE: Level is sent whenever the GMT *) (* offset is changed. *) (***********************************************************) LEVEL_EVENT[vdvTmEvents,nTmGmtLevel] { SEND_STRING 0,"'GMT Offset=',FTOA(LEVEL.VALUE)" } (***********************************************************) (* LEVEL_EVENT: Longitude *) (* PURPOSE: Level is sent whenever the longitude is *) (* changed. *) (***********************************************************) LEVEL_EVENT[vdvTmEvents,nTmLongLevel] { SEND_STRING 0,"'Longitude=',FTOA(LEVEL.VALUE)" } (***********************************************************) (* LEVEL_EVENT: Latitude *) (* PURPOSE: Level is sent whenever the Latitude is *) (* changed. *) (***********************************************************) LEVEL_EVENT[vdvTmEvents,nTmLatLevel] { SEND_STRING 0,"'Latitude=',FTOA(LEVEL.VALUE)" } (***********************************************************) (* DATA_EVENT: Strings for Sunrise/Sunset *) (* PURPOSE: parse strings for sunrise and sunset *) (***********************************************************) DATA_EVENT[vdvTmEvents] { STRING: { STACK_VAR CHAR strUpper[30] CHAR strTemp[30] CHAR strTrash[30] strUpper = UPPER_STRING(DATA.TEXT) strTemp = DATA.TEXT strTrash = REMOVE_STRING(strTemp,'-',1) SELECT { (* SUNRISE *) ACTIVE (FIND_STRING(strUpper,'SUNRISE-',1)): SEND_STRING 0,"'Sunrise Time=',strTemp" (* SUNSET *) ACTIVE (FIND_STRING(strUpper,'SUNSET-',1)): SEND_STRING 0,"'Sunset Time=',strTemp" (* TIME ZONE NAME *) ACTIVE (FIND_STRING(strUpper,'TIMEZONE-',1)): SEND_STRING 0,"'Timezone=',strTemp" (* TIME DESCRPTION *) ACTIVE (FIND_STRING(strUpper,'TIMEDESC-',1)): SEND_STRING 0,"'Time Description=',strTemp" (* LOCATION *) ACTIVE (FIND_STRING(strUpper,'LOCATION-',1)): SEND_STRING 0,"'Location=',strTemp" } } } (***********************************************************) (* CONSTANT DEFINITIONS GO BELOW *) (***********************************************************) DEFINE_CONSTANT (***********************************************************) (* THE ACTUAL PROGRAM GOES BELOW *) (***********************************************************) DEFINE_PROGRAM (***********************************************************) (* END OF PROGRAM *) (* DO NOT PUT ANY CODE BELOW THIS COMMENT *) (***********************************************************)Much appreciated!
and then down in your code...
The latitude and longitude are for Charleston, SC You have to convert Latitude and Longitude values from minutes and seconds to decimal.
