How to egt firmware version in controler
Hi
I have a CV7 panel who freeze 2 or 3 times a year, I want to udate firmware to try to fix this problem.
In firmware kit description is indicate " Requires latest master firmware (Build 352 or greater). "
How I can get info .
    Denis wrote: »
    Here are a few different ways to find the firmware version of the NI Master:
    You can telnet into the NI Master and from the command prompt type in:
    Show device 0
    Or you can use Netlinx Studio and view the master (device 00000) firmware in the online tree.
    Or you can HTTP into the NI Master and select device 00000 ? Ni Master to view the info.
  • DenisDenis Posts: 163
    Thanks Joe
    I uploaded the new firmware yesterday (sorry for long delay) and I hope as that will fix the issue with this panel.
