NXD-435
edgelitoc
Hi there,
I have noticed that NXD-435 is not on the list for touch panel design. Any body knows what TP should be used.
Edit:
Assuming these panels are real G4 panels, not like the R4s...
It's unwise to sell something that doesn't exist. It's simply crazy to end up having to do interface design for something that doesn't exist. I'm not having a pop at you but someone here has got well ahead of themselves.
I saw it at ISE - what was on the booth was clearly a prototype - this product should not be in a project that is so advanced that it is now calling for a TPD design
Will it be downloaded, if you use the other template..
I'm not exactly sure I understand the question, but you are only able to load a TP design to a touch panel with a matching resolution. If you are using an 8400 (800x600) to create your temporary 4" panel design, you could load it to an 8400 but not the 4" panel.
Once you convert it to the 4" version (after the new TP4 is available) you will no longer be able to load it to the 8400.
Does that answer your question or did I misunderstand?
thanks for the reply, I mean if you fake the resolution to match the NXD-435 resolution, will it be dowloaded to the touch panel, where it has only 480 x 272. What Im trying to obtain is to load a TP design to NXD-435. The basic question is , will it be able to do that by faking the resolution.
So when I said you can fake it, I meant you could develop a 480x272 panel in TP4.
I did not mean that you could fake TP4 into loading to a NXD-435.
so for this time the only solution is to wait for the new updates of TPD4,
From the TPD4 perspective, the R4 penel file is created just like and other panel. The only thing different is how it communicates and it has no streaming video abilities.
I too would not be selling AMX products that don't exist yet. I have burnt by that too many times. Even when the hardware becomes available, I would run it through all of the paces necessary to use it in your configuraion before making any promises.
A wise man once said, "Never buy version 1.0 of anything!"
I was referring to the ability to Save As Different Panel Type...
You can not convert anything to/from an R4.
