GS-Flash Interface Starter Files v.1.0
GSLogic
Attached are all the files for the GSFlash interface to control a Netlinx NI-3000 master.
These files are only to get you started and that's only if you KNOW the Flash application (7.2 or higher).
This is by no means a replacement for a real AMX touchpanel, but it is cool to use your cell phone to control/view your AMX system. From the road it's great for turning up the heat before you get home, arming and/or disarming the security system or letting someone in from a door release.
Post any changes, ideas and/or interfaces, as I'd love to see them.
File size 1.6megs
clikck here to download
File size 1.6megs
I will go to work with it and keep you updated about any progress I make.
Hi Gary
The link seems to be dead. Is this still available and still willing to share?
I realize it's quite a while, but I have approached (and got some results) this solution just recently. And not with AMX... right! But it beacames that much more interresting finding out there would be a workarund to (maybe) bridge the gap and do some work only once for whatever the case might be.
You know what I mean... develop a generic template interface ready to mould over whatever the sales dept might sell.
I reset the link to the file.
It took me a few moments to remember what was going on with the code. You have to know Flash to try to get this to work, but once connected it work fine. I never finished it as a module for sale because it was to complicated to get started and never had the time to refine it.
Please email me any changes, and/or interfaces - good luck!
File size 1.5megs
