Binary bitmask
Hi All,
I'm sure i'm doing something stupid here (my background is in C which tends to cause me problems when coding for netlinx), but I can't seem to use a binary integer when doing a bitmask comparison.
I'm receiving a char via serial and need to check if a bit (in this case bit 2) is set. I tried using:
if (receivedChr & 00000010b)
// do something
But it results in a compiler error:
ERROR: C10201: Syntax error; Illegal or Invalid syntax in code
Of course changing it to:
if (receivedChr & $02)
// do something
Compiles fine. My question is, how come I can't do a binary bitmask (it will make the code easier to understand)?
I have also tried declaring my binary value as a constant (which the docs seem to indicate is legal) but that too generates an error.
Matt.
// do something
// do something
Matt.
A binary number is not an intinsic data type in Netlinx or C. You will have to use an integer or the hex equivalent, in your case, 2 or $02.
I have seen that several times when I ran through the help file, it has never worked. I think it was a "WISH" item from the beginning of time, just never got removed from the help file.
The help file does imply that binary notation is acceptable; however, as discovered that isn?t the case. An error in a help file, imagine that.
I shall move on with a hex bitmask.
DEFINE_CONSTANT // For easier code reading FAN_RELAY_ON = 1 Y1_RELAY_ON = 2 // 1st Stage Cooling/Dehumidify W1_RELAY_ON = 4 // 1st Stage Heat/Humidify Y2_RELAY_ON = 8 // 2nd Stage Cooling/Dehumidify W2_RELAY_ON = 16 // 2nd Stage Heat/Humidify B_RELAY_ON = 32 // Cool reversing valve O_RELAY_ON = 64 // Heat reversing valve // from the parsing function: ACTIVE (FIND_STRING(sRsp, "'HVAC='", 1)) : { STACK_VAR CHAR nBase ; nBase = 128 ; REMOVE_STRING(sRsp, "'HVAC='", 1) ; IF(FIND_STRING(sRsp, "'G+'", 1)) nBase = nBase | FAN_RELAY_ON ; IF(FIND_STRING(sRsp, "'G-'", 1)) nBase = nBase & ~FAN_RELAY_ON ; IF(FIND_STRING(sRsp, "'Y1+'", 1)) nBase = nBase | Y1_RELAY_ON ; IF(FIND_STRING(sRsp, "'Y1-'", 1)) nBase = nBase & ~Y1_RELAY_ON ; IF(FIND_STRING(sRsp, "'Y2+'", 1)) nBase = nBase | Y2_RELAY_ON ; IF(FIND_STRING(sRsp, "'Y2-'", 1)) nBase = nBase & ~Y2_RELAY_ON ; IF(FIND_STRING(sRsp, "'W1+'", 1)) nBase = nBase | W1_RELAY_ON ; IF(FIND_STRING(sRsp, "'W1-'", 1)) nBase = nBase & ~W1_RELAY_ON ; IF(FIND_STRING(sRsp, "'W2+'", 1)) nBase = nBase | W2_RELAY_ON ; IF(FIND_STRING(sRsp, "'W2-'", 1)) nBase = nBase & ~W2_RELAY_ON ; IF(FIND_STRING(sRsp, "'B+'", 1)) nBase = nBase | B_RELAY_ON ; IF(FIND_STRING(sRsp, "'B-'", 1)) nBase = nBase & ~B_RELAY_ON ; IF(FIND_STRING(sRsp, "'O+'", 1)) nBase = nBase | O_RELAY_ON ; IF(FIND_STRING(sRsp, "'O-'", 1)) nBase = nBase & ~O_RELAY_ON ;
