IPort Module 3.21 Modification Question
Here is the UI that is available for download
[code]
MODULE_NAME='iPort_UI' (DEV vdviPort, DEV dvTP[], INTEGER TP_BUTTONS[],INTEGER TP_FIELDS[], INTEGER TP_LEVELS[], INTEGER nLISTS[],
INTEGER nR4_DMS_Port1, INTEGER nR4_DMS_Port2) //Added TP_LEVELS Edit v1_1 8-18-2006 - Added R4 ports in v3.21
(* FILE CREATED ON: 08/28/2005 AT: 19:00:15 *)
(* FILE_LAST_MODIFIED_ON: 03/10/2008 AT: 17:15:51 *)
(* System Type : NetLinx *)
(* REV HISTORY: *)
(* DEVICE NUMBER DEFINITIONS GO BELOW *)
//Current iPod Firmware Tested: 1.2.3 Video 5th Generation
//--Current iPort Firmware Tested: 1.32 on IW - 1.06 on FS
//--Many of the programming methods follow the G3 usage so this module can be used for both G3 and G4 panels and now the MIO-DMS and MIO-R4
//--If using the MIO-DMS pinnacle you will want to set nDOUBLE_PUSH = 0 anywhere it appears or just comment it out -
// this will allow the scroll bar to operate normally instead of going to the end of the list on use of the scroll bar.
//--nDOUBLE_PUSH allows the list to go to the bottom or the top of any list immediately.
//--On the hold of a selection the selection will start to play all files within that list selection -
// so if one pushes and holds an album selection it will start to play all the songs on that album.
//--The list size on the touch panels and DMS must be all the same.
//--One COMM file and only one UI file per iPort.
//--There is a known bug with the Audiobooks option that starts playing the first Audiobook when selected
(* CONSTANT DEFINITIONS GO BELOW *)
DEFINE_CONSTANT
//LstLength = 8 // - Length of list on TP - old v1.0 beta way
LstRepeat = 2 // - Repeat default setting
LstShuffle = 3 // - Shuffle Default setting
Name_TL1 = 1 //Timeline Name_TL1
WC_FORMAT_UTF8 = 3 //Unicode format type
WC_FORMAT_TP = 100 //Unicode format type for panels
//R4_DMS_PORT1 = nR4_DMS_PORT1
//R4_DMS_PORT2 = nR4_DMS_PORT2
(* DATA TYPE DEFINITIONS GO BELOW *)
DEFINE_TYPE
(* VARIABLE DEFINITIONS GO BELOW *)
VOLATILE INTEGER nNOW_PLAYING // FLAG TRACKS WHEN IPORT NOW PLAYING POPUP IS ON
VOLATILE INTEGER nDebug_Level = 0
VOLATILE INTEGER nPLAY_STATE = 0 // 1=PLAY, 0=PAUSE
VOLATILE INTEGER nONLINE = 0
VOLATILE INTEGER nFF_RWD_ON = 0 //Is FForward or Rewind occurring?
VOLATILE INTEGER nREPEAT_ON = 0 //Is Repeat occurring?
VOLATILE INTEGER nSHUFFLE_ON = 0 //Is Shuffle occurring?
VOLATILE CHAR strRESPONSE[6000]
VOLATILE INTEGER nSLIDER_LEVEL = 0
VOLATILE INTEGER nTIME_LEVEL = 0
VOLATILE INTEGER nKEY_PRESSED = 0 // TP PRESSED
VOLATILE INTEGER nRUN_ONCEa = 0
VOLATILE INTEGER nRUN_ONCEb = 0
VOLATILE INTEGER nRECORD_LEVEL[2]
VOLATILE INTEGER nHOLD = 0 // was button held down
VOLATILE INTEGER nDOUBLE_PUSH = 0 // was button pushed and then pushed again under a second
VOLATILE INTEGER nVIDEO_MENU = 0
VOLATILE INTEGER nCURRENT_INDEX_NUM[5]
VOLATILE INTEGER nMENU_RECORD_COUNT[5] //Total number of records in the given menu
VOLATILE INTEGER nTOTAL_CURRENT_SONGS = 0
VOLATILE INTEGER nCURRENT_INDEX_START = 0 //where list starts to report - incremented after each Database Record is returned
VOLATILE INTEGER nCURRENT_INDEX_TOTAL = 0
//VOLATILE INTEGER nCURRENT_INDEX_HILITE = 0
VOLATILE INTEGER nCURRENT_INDEX_LENGTH = 0 //List Length - default is 10 - populated by UI_LIST Variable passed in define module for UI
VOLATILE INTEGER nCURRENT_MENU = 1
VOLATILE CHAR cCURRENT_SONG_LENGTH[8] //'PLAYBACK_SONG_LENGTH='
VOLATILE CHAR cCURRENT_PLAYING_INDEX_NUM[8] // !! R !! WAS 5
VOLATILE INTEGER nSONG_SECONDS_LEVEL = 0
VOLATILE CHAR cINDEX_LIST_1[5][2][10][30]// MAX list size is 10 - if this UI runs a G4 panel then the Fourth array parameter can be extended to 200
The cINDEX_LIST_1 array is set up to record the ID numbers and info pertaining to that ID that is returned from the iPod for each menu and is set up as follows:
[5] 5 different menus of information. If one selects Playlist it will actually only use 3 of the menus ? Songs will only use 2 ? Artists will use 4 - Albums and videos use 5.
[2] 2 types of information in each menu ? ID number[1] and either Song, Album, or Artist [2]. This info in [2] is sent to the Touch Panels when a list is produced or on the push of the Menu button.
[10] This is the list length of each menu. This can be set the same as the TP_UI_list variable in the Main.axs actually.
[30] The max character length of the information ? set to 30 for the DMS length ? G3 panels max is 39 ? G4 panels max is 200
VOLATILE INTEGER nCURRENT_CATEGORY_START = 0 //Category that was selected on the first menu eg: Playlists=1, Artists=2, Etc.
VOLATILE INTEGER nCURRENT_CATEGORY[5] //Holds selection for each menu page
VOLATILE INTEGER nCURRENT_CATEGORY2[5]
VOLATILE INTEGER nCHANGE = 0
VOLATILE INTEGER nFLAG = 0
VOLATILE INTEGER nONLINE_FLAG = 0
VOLATILE INTEGER nWAIT_FLAG = 0
VOLATILE INTEGER nLEVEL_FLAG = 0
VOLATILE INTEGER nSELECT_FLAG = 0
VOLATILE CHAR cDIRECT_SELECTION[4]
LONG Name_TimeArray[] = {10000}//Time array set to poll every 10 seconds @ 10000 - 1 second = 1000
VOLATILE CHAR cMenu0[8][11] = {'Playlists','Artists','Albums','Genres','Songs','Composers','Audio Books','Podcasts'}
VOLATILE CHAR cMenu_VIDEOS[4][14] = {'Movies','Music Videos','TV Shows','Video Podcasts'} //Text sent to
VOLATILE INTEGER nCURRENT_TP_PORT //Current Touch Panel port - used to determine which device port to send page flips when using more than 1 iPort on a DMS
VOLATILE INTEGER nDEV_LENGTH = 0
VOLATILE INTEGER nON_IPORT_PAGE[30] // 0 = Panel off page - 1 = on iPort Page
VOLATILE INTEGER nNO_ALBUM = 0
(* LATCHING DEFINITIONS GO BELOW *)
DEFINE_LATCHING
(* MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW *)
DEFINE_MUTUALLY_EXCLUSIVE
(* SUBROUTINE/FUNCTION DEFINITIONS GO BELOW *)
DEFINE_FUNCTION DEBUG (INTEGER Priority, CHAR strMSG[]) //Debug messages
If((Priority >= nDebug_Level) && (nDebug_Level > 0))
SEND_STRING 0, "'iPort_UI: ',strMSG"
DEFINE_FUNCTION SEND_VTEXT (INTEGER nCHAN, CHAR strMSG[]) //All variable text to panel is sent thru this function
STACK_VAR WIDECHAR strSTRING1[600]
STACK_VAR CHAR strSTRING2[600]
STACK_VAR INTEGER iTEXT
strSTRING1 = WC_DECODE(strMSG,WC_FORMAT_UTF8,1) // Used to Decode
strSTRING2 = WC_ENCODE(strSTRING1,WC_FORMAT_TP,1)
FOR(itext = 1;iTEXT <= nDEV_LENGTH;iTEXT++) //Check to see if G3 or G4 panel to send correct text command
//SEND_STRING 0,"'R4 Device_ID = ',ITOA(DEVICE_ID(dvTP[3]))" //R4 Device is 322
IF(DEVICE_ID(dvTP[iTEXT]) < 256) //Is it a G3 Panel in the array?
IF(nON_IPORT_PAGE[iTEXT] = 1) // Is the Panel currently on the iPort page?
SEND_COMMAND dvTP[iTEXT], "'TEXT',ITOA(nCHAN),'-',strMSG" //G3 Panels without Unicode Support
} //NOTE: Unicode not supported on G3 panels
ELSE //It must be a Modero Panel and not a G3 panel
IF(DEVICE_ID(dvTP[iTEXT]) = 322) //Is it an R4 Remote in the array?
//Send Nothing - Use Virtual R4 in Main.axs in DEV array for iPort UI devices
ELSE
SEND_COMMAND dvTP[iTEXT], "'^UNI-',ITOA(nCHAN),',0,',strSTRING2" //Unicode Modero Panels
//SEND_COMMAND dvTP,"'^TXT-',ITOA(nCHAN),',1&2,',strMSG" // G4 panels without Unicode
DEFINE_FUNCTION SEND_CMD (CHAR strCMD[]) //Commands sent to COMM module
Send_Command vdviPort, strCMD
DEFINE_FUNCTION fnDO_FEEDBACK() //Feedback for panel channels is sent thru this function
(***** BUTTON FEEDBACK *****)
[dvTP,TP_BUTTONS[2]] = nSELECT_FLAG
[dvTP,TP_BUTTONS[3]] = (nPLAY_STATE == 1) // PLAY/PAUSE button
[dvTP,TP_BUTTONS[4]] = (nONLINE == 1) // Online Status button
[dvTP,TP_BUTTONS[5]] = (nFF_RWD_ON == 1) // Fast Forward button
[dvTP,TP_BUTTONS[6]] = (nFF_RWD_ON == 2) // Rewind button
[dvTP,TP_BUTTONS[23]] = (nREPEAT_ON > 0) // Repeat button
[dvTP,TP_BUTTONS[24]] = (nSHUFFLE_ON > 0) // Shuffle button
SWITCH(nREPEAT_ON) //Which Repeat?
CASE 0:
SEND_VTEXT(TP_FIELDS[17],'REPEAT|OFF')
CASE 1:
SEND_VTEXT(TP_FIELDS[17],'REPEAT|TRACK')
CASE 2:
SEND_VTEXT(TP_FIELDS[17],'REPEAT|ALL')
SWITCH(nSHUFFLE_ON) //Which Shuffle?
CASE 0:
SEND_VTEXT(TP_FIELDS[18],'SHUFFLE|OFF')
CASE 1:
SEND_VTEXT(TP_FIELDS[18],'SHUFFLE|SONGS')
CASE 2:
SEND_VTEXT(TP_FIELDS[18],'SHUFFLE|ALBUMS')
DEFINE_FUNCTION PROCESS_RESPONSE() // Process the responses from the COMM
CHAR strTEMP_STRING[40]
nONLINE_FLAG = 0
strTEMP_STRING = REMOVE_STRING(strRESPONSE,'=',1) // GET RETURNED STRING
// WHAT IS LEFT IS PARAMETER LIST
SWITCH(strTEMP_STRING)
CASE 'IPOD_NAME=': //COMM Returned iPod name
STACK_VAR CHAR ciPodName[40]
ciPodName = strRESPONSE
SEND_VTEXT(TP_FIELDS[1],ciPodName)
nONLINE = 1
fnDO_FEEDBACK()
IF(ciPodName = '') //Send the command till it gets the iPod name
SEND_CMD("'REQUEST_IPOD_NAME?'")
CASE 'ALBUM_NAME=': //COMM Returned Album name
STACK_VAR CHAR cAlbumName[30]
cAlbumName = strRESPONSE
SEND_VTEXT(TP_FIELDS[14],cAlbumName) // Send it to the touch panel
CASE 'TITLE_NAME=': //COMM Returned Track name
STACK_VAR CHAR cTrackName[30]
cTrackName = strRESPONSE
SEND_VTEXT(TP_FIELDS[15],cTrackName) // Send it to the touch panel
CASE 'ARTIST_NAME=': //COMM Returned Artist name
STACK_VAR CHAR cArtistName[30]
cArtistName = strRESPONSE
SEND_VTEXT(TP_FIELDS[13],cArtistName) // Send it to the touch panel
CASE 'NUM_PLAYING_SONGS=': //COMM Returned Number of playing songs
STACK_VAR INTEGER nCONVERT
nTOTAL_CURRENT_SONGS = ATOI(strRESPONSE)
nCONVERT=ATOI(cCURRENT_PLAYING_INDEX_NUM)
SEND_VTEXT(TP_FIELDS[12],"ITOA(nCONVERT+1),' / ',ITOA(nTOTAL_CURRENT_SONGS)")
CASE 'UI_MODE=': //Online or offline
STACK_VAR INTEGER UIMode
UIMode = ATOI(strRESPONSE)
SWITCH(UIMode)
CASE 1: //Online
nONLINE = 1
fnUpdate_Info_Online()
nRUN_ONCEb = 0
nONLINE_FLAG = 0
CASE 0: //Offline
nONLINE = 0
nRUN_ONCEa = 0
fnUpdate_Info_Offline()
CASE 'IPOD_DOCK_STATUS=': //Online or offline when docked - added v1.2 - 09-15-2006
STACK_VAR INTEGER DockStatus
DockStatus = ATOI(strRESPONSE)
SWITCH(DockStatus)
CASE 1: //Online
nONLINE = 1
nRUN_ONCEb = 0
nONLINE_FLAG = 0
CASE 0: //Offline
nONLINE = 0
nRUN_ONCEa = 0
CASE 'IPORT_FIRMWARE=': //COMM Returned iPort Firmware Version
SEND_CMD("'REQUEST_REMOTE_UI_MODE?'") //Check for iPod Online
nONLINE_FLAG = 1
SEND_CMD("'SET_PLAY_STATUS_CHANGE_NOTIFICATION=0'") //Restart Time return
WAIT 90
IF(nONLINE_FLAG)
nONLINE = 0
fnDO_FEEDBACK()
nRUN_ONCEa = 0
CASE 'PLAY_STATUS=': //Current playback status
STACK_VAR INTEGER PLAYMode
PLAYMode = ATOI(strRESPONSE)
SWITCH(PLAYMode)
CASE 0: //Stopped
SEND_VTEXT(TP_FIELDS[19],'w') // w = stop icon with AMXBOLD font
OFF[dvTP,TP_BUTTONS[3]] //turns DMS play button OFF
CASE 1: //Playing
SEND_VTEXT(TP_FIELDS[19],'q') // q = play icon with AMXBOLD font
ON[dvTP,TP_BUTTONS[3]] //turns DMS play button ON
CASE 2: //Paused
SEND_VTEXT(TP_FIELDS[19],'e') // e = pause icon with AMXBOLD font
CASE 3: //Error
SEND_VTEXT(TP_FIELDS[19],'A') // A = AMX icon with AMXBOLD font
CASE 'REPEAT_STATUS=': //Current repeating status
STACK_VAR INTEGER nRepeatMode
nRepeatMode = ATOI(strRESPONSE)
SWITCH(nRepeatMode)
CASE 0: //Repeat Off
nREPEAT_ON = 0
fnDO_FEEDBACK()
CASE 1: //Repeat one track
nREPEAT_ON = 1
fnDO_FEEDBACK()
CASE 2: //Repeat All
nREPEAT_ON = 2
fnDO_FEEDBACK()
CASE 'SHUFFLE_STATUS=':
STACK_VAR INTEGER nShuffleMode
nShuffleMode = ATOI(strRESPONSE)
SWITCH(nShuffleMode)
CASE 0: //Shuffle Off
nSHUFFLE_ON = 0
fnDO_FEEDBACK()
CASE 1: //Shuffle songs
nSHUFFLE_ON = 1
fnDO_FEEDBACK()
CASE 2: //Shuffle Albums
nSHUFFLE_ON = 2
fnDO_FEEDBACK()
CASE 'PLAYBACK_SONG_CHANGED=': //COMM Returned Playback Song Change
cCURRENT_PLAYING_INDEX_NUM = ''
cCURRENT_PLAYING_INDEX_NUM = strRESPONSE
nONLINE = 1
fnDO_FEEDBACK()
SEND_CMD("'GET_INDEXED_PLAYING_SONG_INFO?',cCURRENT_PLAYING_INDEX_NUM")
WAIT 2
SEND_CMD("'GET_NUM_PLAYING_SONGS?'")
CASE 'PLAYBACK_SONG_POSITION_CHANGE=': //COMM Returned Current song time passing
STACK_VAR CHAR cSongTime[8]
INTEGER nTHour
INTEGER nTMinute
INTEGER nTSecond
cSongTime = strRESPONSE
//SEND_VTEXT(TP_FIELDS[16],"cSongTime,'/',cCURRENT_SONG_LENGTH") //
nTHour = ATOI(REMOVE_STRING(cSongTime,':',1))
nTMinute = ATOI(REMOVE_STRING(cSongTime,':',1))
nTSecond = ATOI(cSongTime)
nTSecond = ((nTHour * 3600)+(nTMinute * 60)+ nTSecond)
//strSTRING1 = WC_DECODE(strMSG,WC_FORMAT_UTF8,1) // Used to Decode
//strSTRING2 = WC_ENCODE(strSTRING1,WC_FORMAT_TP,1)
SEND_COMMAND dvTP[iTEXT], "'TEXT',ITOA(TP_FIELDS[16]),'-',strRESPONSE,'/',cCURRENT_SONG_LENGTH" //G3 Panels without Unicode Support
IF(nSONG_SECONDS_LEVEL = 0)
//Do nothing - made to fix divide by 0 runtime errors
ELSE
SEND_LEVEL dvTP,TP_LEVELS[2],((100-(nSONG_SECONDS_LEVEL - nTSecond)*100/nSONG_SECONDS_LEVEL)*255/100)
IF((DEVICE_ID(dvTP[iTEXT]) = 322) OR (DEVICE_ID(dvTP[iTEXT]) = 65534)) //Is it an R4 Remote or virtual device in the array?
//Send No Level or Text Level updates to R4 physical or virtual
ELSE
SEND_COMMAND dvTP[iTEXT], "'^TXT-',ITOA(TP_FIELDS[16]),',0,',strRESPONSE,'/',cCURRENT_SONG_LENGTH" //Unicode Modero Panels
ELSE
CASE 'PLAYBACK_SONG_LENGTH=': //COMM Returned Current song time Length
INTEGER nLHour
INTEGER nLMinute
INTEGER nLSecond
CHAR cSongLength[8]
cCURRENT_SONG_LENGTH = strRESPONSE
//SEND_VTEXT(TP_FIELDS[16],cSongTime)
cSongLength = strRESPONSE
nLHour = ATOI(REMOVE_STRING(cSongLength,':',1))
nLMinute = ATOI(REMOVE_STRING(cSongLength,':',1))
nLSecond = ATOI(cSongLength)
nSONG_SECONDS_LEVEL = ((nLHour * 3600)+(nLMinute * 60)+ nLSecond)
CASE 'CURRENT_PLAYING_SONG_INDEX=': //COMM Returned Playback Song Change
nONLINE = 1
fnDO_FEEDBACK()
WAIT 2
CASE 'NUMBER_DB_RECORDS=': //COMM returned the number of records in the selected list
SEND_LEVEL dvTP,TP_LEVELS[1],0 //Reset level on list bargraph - Edit v1_1 8-18-2006
nMENU_RECORD_COUNT[nCURRENT_MENU] = ATOI(strRESPONSE)
SEND_VTEXT(TP_FIELDS[20],"'1 / ',ITOA(nMENU_RECORD_COUNT[nCURRENT_MENU])")
IF (nMENU_RECORD_COUNT[nCURRENT_MENU]>= 0)
SWITCH(nCURRENT_MENU) //Which Menu is selected?
CASE 2: // first menu after main menu
IF(nCURRENT_CATEGORY_START = 1) //If current category selected is Playlists
nMENU_RECORD_COUNT[nCURRENT_MENU] -- // added - 1 to fix lists under 10 not showing in Playlists
nCURRENT_INDEX_NUM[nCURRENT_MENU] ++ //Added +1 to start Playlists after iPod Name playlist defect
IF(nMENU_RECORD_COUNT[nCURRENT_MENU] < nCURRENT_INDEX_LENGTH)
SEND_CMD("'RETRIEVE_CATEGORIZED_DB_RECORDS?',ITOA(nCURRENT_CATEGORY_START),':',ITOA(nCURRENT_INDEX_NUM[nCURRENT_MENU]-1),':',ITOA(nMENU_RECORD_COUNT[nCURRENT_MENU]-1)") // -1
nCURRENT_CATEGORY2[2] = nCURRENT_CATEGORY_START
ELSE
SEND_CMD("'RETRIEVE_CATEGORIZED_DB_RECORDS?',ITOA(nCURRENT_CATEGORY_START),':',ITOA(nCURRENT_INDEX_NUM[nCURRENT_MENU]-1),':',ITOA(nCURRENT_INDEX_LENGTH-1)") // -1
CASE 3: // Second Menu after start
IF(nSELECT_FLAG) //Direct Select was enabled
cDIRECT_SELECTION = cINDEX_LIST_1[2][2][nCURRENT_CATEGORY[1]]
//SEND_CMD("'PLAY_CURRENT_SELECTION=',cINDEX_LIST_1[3][2][nCURRENT_CATEGORY[1]]")
SEND_CMD("'PLAY_CURRENT_SELECTION=',cDIRECT_SELECTION")
nSELECT_FLAG = 0
SWITCH(nCURRENT_CATEGORY_START)
CASE 1: //Playlist goes to Songs(5) on 2nd Menu
SEND_CMD("'RETRIEVE_CATEGORIZED_DB_RECORDS?5:0:',ITOA(nMENU_RECORD_COUNT[nCURRENT_MENU]-1)")// -1
nCURRENT_CATEGORY2[3] = 5
ELSE
SEND_CMD("'RETRIEVE_CATEGORIZED_DB_RECORDS?5:0:',ITOA(nCURRENT_INDEX_LENGTH-1)")// -1
//SEND_CMD("'RETRIEVE_CATEGORIZED_DB_RECORDS?5',':',ITOA(nCURRENT_INDEX_NUM),':',ITOA(nCURRENT_INDEX_LENGTH)")
CASE 2: //Artists goes to Albums(3) on 2nd Menu
IF(nMENU_RECORD_COUNT[nCURRENT_MENU] < nCURRENT_INDEX_LENGTH) //is there less albums in the database for this artist than the total list length?
IF(nMENU_RECORD_COUNT[nCURRENT_MENU] <= 1) //Send it to songs if there is 1 album or less
//SEND_VTEXT(TP_FIELDS[2],'ALL')
nCURRENT_CATEGORY2[3] = 3 //Current category on Menu 3 is 3 or Albums
nCURRENT_INDEX_START = 0 //Reset counter for list return to 0
SEND_CMD("'SELECT_DB_RECORD=3:0'") //Select Albums from this artist
WAIT 2
SEND_CMD("'GET_NUMBER_CATEGORIZED_DB_RECORDS?5'") // Look for number of Songs in the selected Artist
fnCLEAR_LIST()
nCURRENT_MENU++ //Jump a menu
nNO_ALBUM = 1 // Set for when going back it will go to Artists list
ELSE //there were more than 1 albums per this artist - show me the albums
//SEND_CMD("'RETRIEVE_CATEGORIZED_DB_RECORDS?3:0:1'")
SEND_CMD("'RETRIEVE_CATEGORIZED_DB_RECORDS?3:0:',ITOA(nMENU_RECORD_COUNT[nCURRENT_MENU]-1)") // -1
ELSE //More albums in the list than the total List length
SEND_CMD("'RETRIEVE_CATEGORIZED_DB_RECORDS?3:0:',ITOA(nCURRENT_INDEX_LENGTH-1)") // -1
//SEND_CMD("'RETRIEVE_CATEGORIZED_DB_RECORDS?3',':',ITOA(nCURRENT_INDEX_NUM),':',ITOA(nCURRENT_INDEX_LENGTH)")
CASE 3: //Albums goes to Songs(5) on 2nd Menu
SEND_CMD("'RETRIEVE_CATEGORIZED_DB_RECORDS?5:0:',ITOA(nMENU_RECORD_COUNT[nCURRENT_MENU]-1)") // -1
ELSE
SEND_CMD("'RETRIEVE_CATEGORIZED_DB_RECORDS?5:0:',ITOA(nCURRENT_INDEX_LENGTH-1)") // -1
CASE 4: //Genres goes to Artists(2) on 2nd Menu
SWITCH(nVIDEO_MENU)
CASE 0: //Music
CASE 2: //Music Videos
CASE 3: //TV Shows
CASE 4: //Video Podcasts
SEND_CMD("'RETRIEVE_CATEGORIZED_DB_RECORDS?2:0:',ITOA(nMENU_RECORD_COUNT[nCURRENT_MENU]-1)")// -1
nCURRENT_CATEGORY2[3] = 2
ELSE
SEND_CMD("'RETRIEVE_CATEGORIZED_DB_RECORDS?2:0:',ITOA(nCURRENT_INDEX_LENGTH-1)") // -1
CASE 1: //Movies
ELSE
CASE 5: //Songs is on Songs now- Use Play_current_selection=index# now
// Should be playing SEND_CMD("'PLAY_CURRENT_SELECTION=',ITOA(nCURRENT_CATEGORY_START),':',ITOA(nCURRENT_INDEX_NUM),':6'")
CASE 6: //Composers goes to Songs(5) on 2nd Menu
ELSE
CASE 7: //Audiobooks goes to Songs(5) on 2nd Menu
ELSE
CASE 8: //Composers goes to Songs(5) on 2nd Menu
ELSE
CASE 4:
IF(nSELECT_FLAG)
SEND_CMD("'PLAY_CURRENT_SELECTION=',cINDEX_LIST_1[3][2][nCURRENT_CATEGORY[2]]")
nSELECT_FLAG = 0
CASE 2: //Artists goes to Songs here
nCURRENT_CATEGORY2[4] = 5
ELSE
CASE 4: // Genres goes to Albums here
SWITCH(nVIDEO_MENU)
CASE 0: //Music
CASE 3: //TV Shows
SEND_CMD("'RETRIEVE_CATEGORIZED_DB_RECORDS?3:0:',ITOA(nMENU_RECORD_COUNT[nCURRENT_MENU]-1)")// -1
ELSE
SEND_CMD("'RETRIEVE_CATEGORIZED_DB_RECORDS?3:0:',ITOA(nCURRENT_INDEX_LENGTH-1)")// -1
nCURRENT_CATEGORY2[5] = 5
ELSE
CASE 5: //Genres goes to Songs here
ELSE
ELSE
SEND_CMD("'RETRIEVE_CATEGORIZED_DB_RECORDS?',ITOA(nCURRENT_CATEGORY_START),':',ITOA(nCURRENT_INDEX_NUM[nCURRENT_MENU]),':',ITOA(nMENU_RECORD_COUNT[nCURRENT_MENU]-1)")// -1
CASE 'DATABASE_RECORD=': // COMM returned database record
STACK_VAR INTEGER i
CHAR cRecordIndex[5]
CHAR cRecord[50] //With DMS this will need to be set lower for word wrap options not to take up 3 lines with records
CHAR cTrash[5]
cTrash = REMOVE_STRING(strRESPONSE,':',1)
cRecordIndex = REMOVE_STRING(strRESPONSE, ':',1)
cRecord = strRESPONSE
IF(nCURRENT_INDEX_START >= nCURRENT_INDEX_LENGTH)
nWAIT_FLAG = 0
IF(nFLAG = 0) //Populate the Index Array
nCURRENT_INDEX_START ++
i = nCURRENT_INDEX_START
cINDEX_LIST_1[nCURRENT_MENU][1] = cRecord //This is the record that was returned
cINDEX_LIST_1[nCURRENT_MENU][2] = cRecordIndex //This si the Record Index or ID returned
SEND_VTEXT(TP_FIELDS[(i+1)],cRecord) //Send the record to the touch panel
CLEAR_BUFFER strRESPONSE
DEFINE_FUNCTION fnUpdate_Info_Online()
IF(!nRUN_ONCEa)
cINDEX_LIST_1[1][1][1] = cMenu0[1]
cINDEX_LIST_1[1][1][2] = cMenu0[2]
cINDEX_LIST_1[1][1][3] = cMenu0[3]
cINDEX_LIST_1[1][1][4] = cMenu0[4]
cINDEX_LIST_1[1][1][5] = cMenu0[5]
cINDEX_LIST_1[1][1][6] = cMenu0[6]
cINDEX_LIST_1[1][1][7] = cMenu0[7]
cINDEX_LIST_1[1][1][8] = cMenu0[8]
SEND_VTEXT(TP_FIELDS[2],'Playlists')
SEND_VTEXT(TP_FIELDS[3],'Artists')
SEND_VTEXT(TP_FIELDS[4],'Albums')
SEND_VTEXT(TP_FIELDS[5],'Genres')
SEND_VTEXT(TP_FIELDS[6],'Songs')
SEND_VTEXT(TP_FIELDS[7],'Composers')
SEND_VTEXT(TP_FIELDS[8],'Audiobooks')
SEND_VTEXT(TP_FIELDS[9],'Podcasts')
SEND_VTEXT(TP_FIELDS[10],'')
SEND_VTEXT(TP_FIELDS[11],'')
SEND_VTEXT(TP_FIELDS[21],"'pick an option from below'")
WAIT 5
SEND_CMD("'SET_PLAY_STATUS_CHANGE_NOTIFICATION=1'") //=1 ON, =0 OFF - Sets Unsolictied feedback of time and record index on song change
nRUN_ONCEa = 1
nCURRENT_INDEX_NUM[1] = 1
nCURRENT_INDEX_NUM[2] = 1
nCURRENT_INDEX_NUM[3] = 1
nCURRENT_INDEX_NUM[4] = 1
nCURRENT_INDEX_NUM[5] = 1
nCURRENT_MENU = 1
//fnINDEX_HILITE(1)
fnDO_FEEDBACK()
SEND_COMMAND dvTP,'@PPN-SONG DETAILS;iPort Main'
SEND_COMMAND dvTP, '@PPF-Eject;iPort' // Popup eject off
WAIT 8
SEND_CMD("'GET_PLAY_STATUS?'")
WAIT 11
SEND_CMD("'GET_CURRENT_PLAYING_SONG_INDEX?'")
WAIT 14
SEND_CMD('RESET_DB_SELECTION=0')
WAIT 16
SEND_CMD("'GET_REPEAT?'")
WAIT 19
SEND_CMD("'GET_SHUFFLE?'")
OFF[nNOW_PLAYING]
DEFINE_FUNCTION fnUpdate_Info_Offline()
IF(!nRUN_ONCEb)
SEND_VTEXT(TP_FIELDS[1],'Offline')
SEND_VTEXT(TP_FIELDS[2],'')
SEND_VTEXT(TP_FIELDS[3],'')
SEND_VTEXT(TP_FIELDS[4],'')
SEND_VTEXT(TP_FIELDS[5],'')
SEND_VTEXT(TP_FIELDS[6],'')
SEND_VTEXT(TP_FIELDS[7],'')
SEND_VTEXT(TP_FIELDS[8],'')
SEND_VTEXT(TP_FIELDS[9],'')
SEND_VTEXT(TP_FIELDS[12],'x/x')
SEND_VTEXT(TP_FIELDS[13],'')
SEND_VTEXT(TP_FIELDS[14],'')
SEND_VTEXT(TP_FIELDS[15],'')
SEND_VTEXT(TP_FIELDS[16],'00:00')
SEND_VTEXT(TP_FIELDS[20],'') // CLEAR X OF Y ON PLAYLIST POPUP
SEND_LEVEL dvTP,TP_LEVELS[2],0
//fnINDEX_HILITE(1)
fnDO_FEEDBACK()
nRUN_ONCEb = 1
//SEND_COMMAND dvTP,'@PPA-iPort' // CLOSE POPUP INFO
OFF[nNOW_PLAYING]
DEFINE_FUNCTION fnCLEAR_LIST() //Clear the list
STACK_VAR INTEGER i
FOR(i=1;i <= nCURRENT_INDEX_LENGTH;i++)
SEND_VTEXT(TP_FIELDS[i+1],'') //Lists start at TP_FIELDS[2]
DEFINE_FUNCTION fnCLEAR_SONG_INFO()
DEFINE_FUNCTION fnPROCESS_SELECTION(INTEGER nCategory)
IF(nCURRENT_MENU <= 5)
CASE 1: //Main Menu
nCURRENT_CATEGORY_START = nCategory
SEND_VTEXT(TP_FIELDS[21],"cMenu0[nCURRENT_CATEGORY_START]")
IF(nCategory = 5) //Cat - Songs?
SEND_CMD("'GET_NUMBER_CATEGORIZED_DB_RECORDS?1'")
fnCLEAR_LIST()
WAIT 3
SEND_CMD("'SELECT_SORT_DB_RECORD=1:0:4'") //Sort the iPods default 0 playlist (all songs) alphabetically by Song
WAIT 5
fnCLEAR_LIST()
ELSE IF(nCategory = 3) //Cat - Albums?
SEND_CMD("'GET_NUMBER_CATEGORIZED_DB_RECORDS?3'")
fnCLEAR_LIST()
WAIT 3
SEND_CMD("'SELECT_SORT_DB_RECORD=3:0:3'") //Sort the iPods Albums alphabetically by Album
WAIT 5
fnCLEAR_LIST()
ELSE
SEND_CMD("'SELECT_DB_RECORD=',ITOA(nCategory),':0'") // Valid only 1-6 on Menu 0
WAIT 2
SEND_CMD("'GET_NUMBER_CATEGORIZED_DB_RECORDS?',ITOA(nCategory)")
fnCLEAR_LIST()
CASE 2: //Menu #2
nCURRENT_CATEGORY[1] = nCategory
//SEND_VTEXT(TP_FIELDS[21],"cMenu0[nCURRENT_CATEGORY_START],'/',cINDEX_LIST_1[2][1][nCURRENT_CATEGORY[1]]") //shortened below
IF(nCURRENT_CATEGORY_START <> 5)
SEND_VTEXT(TP_FIELDS[21],"cINDEX_LIST_1[2][1][nCURRENT_CATEGORY[1]]")
CASE 1: //Playlist Goes to Songs on 3rd Menu
SEND_CMD("'SELECT_DB_RECORD=1:',ITOA(ATOI(cINDEX_LIST_1[nCURRENT_MENU][2][nCategory]))")
WAIT 2
SEND_CMD("'GET_NUMBER_CATEGORIZED_DB_RECORDS?5'") // Looking for number of Songs in the selected playlist
fnCLEAR_LIST()
CASE 2: //Artist Goes to Album on 3rd Menu
SEND_CMD("'SELECT_DB_RECORD=2:',ITOA(ATOI(cINDEX_LIST_1[nCURRENT_MENU][2][nCategory]))")
//SEND_CMD("'SELECT_DB_RECORD=3:3'")
//SEND_CMD("'SELECT_SORT_DB_RECORD=3:',ITOA(ATOI(cINDEX_LIST_1[nCURRENT_MENU][2][nCategory])),':255'")
WAIT 3 //Changed to WAIT 3 to sidestep effect of $0A in string to physical device on pre-duet firmwares - Edit v1_1 8-18-2006
SEND_CMD("'GET_NUMBER_CATEGORIZED_DB_RECORDS?3'") // Looking for number of Albums in the selected Artist
fnCLEAR_LIST()
CASE 3: //Album Goes to Songs on 3rd Menu
SEND_CMD("'SELECT_DB_RECORD=3:',ITOA(ATOI(cINDEX_LIST_1[nCURRENT_MENU][2][nCategory]))")
WAIT 2
fnCLEAR_LIST()
CASE 4: //Genre Goes to Artists on 3rd Menu
SWITCH(nVIDEO_MENU)
CASE 0: //Music
CASE 3: //TV Shows
SEND_CMD("'SELECT_DB_RECORD=4:',ITOA(ATOI(cINDEX_LIST_1[nCURRENT_MENU][2][nCategory]))")
WAIT 2
SEND_CMD("'GET_NUMBER_CATEGORIZED_DB_RECORDS?2'") // Looking for number of Artists in the selected Genre
fnCLEAR_LIST()
CASE 1: //Movies
WAIT 2
SEND_CMD("'GET_NUMBER_CATEGORIZED_DB_RECORDS?5'") // Looking for number of Artists in the selected Genre
fnCLEAR_LIST()
CASE 5: //Song goes to songs in this menu - Play this selection
SEND_CMD("'PLAY_CURRENT_SELECTION=',cINDEX_LIST_1[nCURRENT_MENU][2][nCategory]")
nCURRENT_MENU = 1
fnCLEAR_SONG_INFO()
WAIT 2
WAIT 3
SEND_CMD("'SET_PLAY_STATUS_CHANGE_NOTIFICATION=1'") //Restart Time return
SEND_COMMAND dvTP,'@PPF-SONG DETAILS' // Popup iPort Now Playing on
fnPAGE_FLIP_NP()
ON[nNOW_PLAYING] // SET FLAG TO PREVENT MENU BUTTON FROM FLIPPING BACK TOO MANY LEVELS
CASE 6: //Composer goes to songs on 3rd menu
SEND_CMD("'SELECT_DB_RECORD=6:',ITOA(ATOI(cINDEX_LIST_1[2][2][nCategory]))")
WAIT 2
SEND_CMD("'GET_NUMBER_CATEGORIZED_DB_RECORDS?5'") // Looking for number of Songs in the selected Composer
fnCLEAR_LIST()
CASE 7: // audio books??? Needs work
SEND_CMD("'SELECT_DB_RECORD=7:',ITOA(ATOI(cINDEX_LIST_1[nCURRENT_MENU][2][nCategory]))")
WAIT 2
SEND_CMD("'GET_NUMBER_CATEGORIZED_DB_RECORDS?7'") // Looking for number of Entries in the selected Audio book
fnCLEAR_LIST()
nCURRENT_CATEGORY2[3] = 7
CASE 8: // PODCASTS
SEND_CMD("'SELECT_DB_RECORD=8:',ITOA(ATOI(cINDEX_LIST_1[nCURRENT_MENU][2][nCategory]))")
WAIT 2
SEND_CMD("'GET_NUMBER_CATEGORIZED_DB_RECORDS?5'") // Looking for number of Songs in the selected Podcast
fnCLEAR_LIST()
CASE 3: // Menu #3
STACK_VAR CHAR cSelectionTemp[15]
nCURRENT_CATEGORY[2] = nCategory
//cSelectionTemp = LEFT_STRING(cINDEX_LIST_1[2][1][nCURRENT_CATEGORY[1]], (LENGTH_STRING(cINDEX_LIST_1[2][1][nCURRENT_CATEGORY[1]]) -1)) // Take off the $00 on the end of the string to send v-text
//SEND_VTEXT(TP_FIELDS[21],"cMenu0[nCURRENT_CATEGORY_START],'/',cSelectionTemp,'/',cINDEX_LIST_1[3][1][nCURRENT_CATEGORY[2]]") //Send v-text to path
IF(nCURRENT_CATEGORY_START <> 1)
SEND_VTEXT(TP_FIELDS[21],"cINDEX_LIST_1[3][1][nCURRENT_CATEGORY[2]]") //Send v-text to path
CASE 1: //Playlist Goes to Songs on 3nd Menu
nCURRENT_MENU = 2
fnCLEAR_SONG_INFO()
WAIT 2
WAIT 3
fnPAGE_FLIP_NP()
CASE 2: //Artist Goes to Songs on 3rd Menu
WAIT 2
fnCLEAR_LIST()
nCURRENT_MENU = 2
fnCLEAR_SONG_INFO()
WAIT 2
WAIT 3
fnPAGE_FLIP_NP() // Page flip on DMS to Transports
CASE 4: //Genre Goes to Artists on 3rd Menu - This is where the videos return their first selected list
SWITCH(nVIDEO_MENU)
CASE 0: //Music get album info
CASE 3: //TV Shows get Season info
WAIT 2
fnCLEAR_LIST()
CASE 1: //Movies Play Now
nCURRENT_MENU = 2
fnCLEAR_SONG_INFO()
WAIT 2
WAIT 3
CASE 2: //Music Videos get Album info
CASE 4: //Video Podcasts get videos
nCategory = ATOI(cINDEX_LIST_1[nCURRENT_MENU][2][nCategory])
SEND_CMD("'SELECT_DB_RECORD=2:',ITOA(nCategory)")
WAIT 2
SEND_CMD("'SELECT_DB_RECORD=2:',ITOA(nCategory)") //Fix applied for Music Videos to select correctly on first selection "Work around the iPod"
WAIT 4
SEND_CMD("'GET_NUMBER_CATEGORIZED_DB_RECORDS?5'") // Looking for number of Songs in the selected album
fnCLEAR_LIST()
//SEND_CMD("'PLAY_CURRENT_SELECTION=',cINDEX_LIST_1[nCURRENT_MENU][2][nCategory]")
//nCURRENT_MENU = 2
//fnCLEAR_SONG_INFO()
//WAIT 2
//SEND_CMD("'GET_CURRENT_PLAYING_SONG_INDEX?'")
//WAIT 3
//SEND_CMD("'SET_PLAY_STATUS_CHANGE_NOTIFICATION=1'") //Restart Time return
//SEND_COMMAND dvTP,'@PPF-SONG DETAILS' // Popup iPort Now Playing on
//fnPAGE_FLIP_NP() // Page flip on DMS to Transports
//ON[nNOW_PLAYING] // SET FLAG TO PREVENT MENU BUTTON FROM FLIPPING BACK TOO MANY LEVELS
CASE 6: //Composer
nCURRENT_MENU = 2
fnCLEAR_SONG_INFO()
WAIT 2
WAIT 3
CASE 8: // PODCASTS
nCURRENT_MENU = 2
fnCLEAR_SONG_INFO()
WAIT 2
WAIT 3
CASE 4: // Menu #3
nCURRENT_CATEGORY[3] = nCategory
CASE 2: //Artist Goes to Songs on 4th Menu
nCURRENT_MENU = 3
fnCLEAR_SONG_INFO()
WAIT 2
WAIT 3
SEND_COMMAND dvTP,'@PPF-SONG DETAILS' // Popup iPort Now Playing ON
CASE 4: //Genre Goes to Albums on 4th menu
SWITCH(nVIDEO_MENU)
CASE 0: //Music
CASE 3: //TV Shows
WAIT 2
fnCLEAR_LIST()
CASE 2:
CASE 4:
nCURRENT_MENU = 3
fnCLEAR_SONG_INFO()
WAIT 2
WAIT 3
CASE 5: //Menu #4 (Genres only in this menu)
nCURRENT_MENU = 4
fnCLEAR_SONG_INFO()
WAIT 2
WAIT 3
IF(nCURRENT_MENU < 5)
nCURRENT_MENU = nCURRENT_MENU + 1
ELSE IF(nCURRENT_MENU > 5)
nCURRENT_MENU = 5
DEFINE_FUNCTION fnUPDATE_INDEX_LEVEL(INTEGER nLevel) //Update bargraph for listings
STACK_VAR INTEGER nTemp
nTemp = nLevel
SEND_LEVEL dvTP,TP_LEVELS[1],1
//made to fix divide by 0 runtime errors
ELSE
SEND_LEVEL dvTP,TP_LEVELS[1],((100-(nMENU_RECORD_COUNT[nCURRENT_MENU] - nTemp)*100/nMENU_RECORD_COUNT[nCURRENT_MENU])*255/100)
//SEND_LEVEL dvTP,TP_LEVELS[1],(((nMENU_RECORD_COUNT[nCURRENT_MENU] - nTemp)*100/nMENU_RECORD_COUNT[nCURRENT_MENU])*255/100) //For G3 Panels
DEFINE_FUNCTION fnRESET_DB_SELECTION()
//LOCAL_VAR INTEGER iTP_TEMP
//iTP_TEMP = GET_LAST(dvTP)
SEND_VTEXT(TP_FIELDS[8],'Audio Books')
fnDO_FEEDBACK()
OFF[nNOW_PLAYING]
DEFINE_FUNCTION fnPAGE_FLIP_NP()
STACK_VAR INTEGER nTEMP
nTEMP = GET_LAST(dvTP)
SELECT //This is done to page flip back to the corresponding iPort Page if there are multiple iPorts controlled from 1 DMS
{ // More ports can be added depending on how many iPorts are being controlled by one DMS
ACTIVE (nR4_DMS_PORT1 = nCURRENT_TP_PORT):
SEND_COMMAND dvTP[nTEMP], 'PAGE-iPort Now Playing' //Flip DMS page to Now Playing page 1
WAIT 5
ACTIVE (nR4_DMS_PORT2 = nCURRENT_TP_PORT):
SEND_COMMAND dvTP[nTEMP], 'PAGE-iPort Now Playing 2' //Flip DMS page to Now Playing page 2
WAIT 5
(* STARTUP CODE GOES BELOW *)
CREATE_BUFFER vdviPort,strRESPONSE // Feedback buffer
CREATE_LEVEL dvTP, TP_LEVELS[1], nSLIDER_LEVEL // Follow Index slider
CREATE_LEVEL dvTP, TP_LEVELS[2], nTIME_LEVEL // Follow Time slider
#INCLUDE 'UnicodeLib.axi'
(* THE EVENTS GO BELOW *)
DATA_EVENT[vdviPort]
STRING:
debug(1, "'RECEIVED FROM COMM: ',strRESPONSE")
PROCESS_RESPONSE() // Process the responses from the COMM module
DATA_EVENT[dvTP]
ONLINE:
nDEV_LENGTH = LENGTH_ARRAY(dvTP)
IF(nONLINE) //If the iPod is already online send updated info to TP
nRUN_ONCEa = 0
ELSE
OFF[dvTP,TP_BUTTONS[4]] // Init in offline condition
SEND_VTEXT(TP_FIELDS[1],' Offline') // Initialize text fields
SEND_VTEXT(TP_FIELDS[2],'iPort Netlinx Module')
SEND_VTEXT(TP_FIELDS[3],'Version 3.21 Release with Video')
fnDO_FEEDBACK() // Initialize panel feedback buttons
nCURRENT_INDEX_LENGTH = nLISTS[1] //Gets default from nLists for list length
//SEND_COMMAND dvTP,'@PPN-SONG DETAILS;iPort Main' // Popup iPort List on
OFF[nNOW_PLAYING]
//SEND_CMD("'VERSION?'") // Get Comm module version number
IF(!TIMELINE_ACTIVE(Name_TL1))
TIMELINE_CREATE(Name_TL1, Name_TimeArray, 1, TIMELINE_ABSOLUTE,TIMELINE_REPEAT) // Timeline to poll for iPod name
OFFLINE:
STACK_VAR INTEGER iPanel_off
iPanel_off = GET_LAST(dvTP)
nON_IPORT_PAGE[iPanel_off] = 0
TIMELINE_EVENT[Name_TL1] //Runs every 10 seconds to check name and status
nONLINE_FLAG = 1
WAIT 50
IF(nONLINE)
SEND_CMD("'GET_PLAY_STATUS?'") //Check for iPod Status and Total Song Length
WAIT 90
IF(nONLINE_FLAG)
nONLINE = 0
fnDO_FEEDBACK()
nRUN_ONCEa = 0
ELSE
//nONLINE = 1
BUTTON_EVENT[dvTP,TP_BUTTONS] //Buttons pushed
nCURRENT_TP_PORT = button.input.device.port
nKEY_PRESSED = GET_LAST(TP_BUTTONS) //Get last button pushed on panel
debug(1,"'key pressed:',itoa(nKEY_PRESSED)")
SWITCH(nKEY_PRESSED)
CASE 1: // Menu (Back button)
SEND_CMD("'SET_PLAY_STATUS_CHANGE_NOTIFICATION=1'") //Start Time return
IF(nCURRENT_MENU > 1)// AND !nNOW_PLAYING)
IF(nVIDEO_MENU >= 1 && nCURRENT_MENU = 3) //Since Video Menu is actually Genres Menu we want it to skip back 2 menus when going back to start
nCURRENT_MENU = 2
nVIDEO_MENU = 0
nCURRENT_MENU = nCURRENT_MENU - 1
SEND_LEVEL dvTP,TP_LEVELS[1],0 //Reset list bargraph to 0 - Edit v1_1 8-18-2006
STACK_VAR INTEGER i
IF(nNO_ALBUM = 1) // Added for when there are no albums for a specific artist to jump back to artists
nCURRENT_MENU = 2
nNO_ALBUM = 0
FOR(i=1; i < (nCURRENT_INDEX_LENGTH + 1);i++)
SEND_VTEXT(TP_FIELDS[i+1],"cINDEX_LIST_1[nCURRENT_MENU][1]")
//nCURRENT_INDEX_HILITE = 1
//fnDO_HILITE()
SEND_VTEXT(TP_FIELDS[20],"ITOA(nCURRENT_INDEX_NUM[nCURRENT_MENU]),' / ',ITOA(nMENU_RECORD_COUNT[nCURRENT_MENU])")
IF(nCURRENT_MENU = 2)
FOR(i=1; i <= nCURRENT_INDEX_LENGTH;i++) //Clear the Array for back button to populate only current records
cINDEX_LIST_1[(nCURRENT_MENU + 1)][1] = ''
cINDEX_LIST_1[(nCURRENT_MENU + 1)][2] = ''
IF(nCURRENT_MENU = 1)
STACK_VAR INTEGER i
SELECT //This is done to page flip back to the corresponding iPort Menu if there are multiple iPorts controlled from 1 DMS
SEND_COMMAND dvTP[nTEMP], 'PAGE-iPort Menu' //Flip DMS page back to Menu 1
SEND_COMMAND dvTP[nTEMP], 'PAGE-iPort Menu 2' //Flip DMS page back to Menu 2
//nCURRENT_INDEX_HILITE = 0 //WAS 1
//fnDO_HILITE()
SEND_VTEXT(TP_FIELDS[20],"'1 / 6'") //
cINDEX_LIST_1[2][1] = ''
cINDEX_LIST_1[2][2] = ''
cINDEX_LIST_1[3][1] = ''
cINDEX_LIST_1[3][2] = ''
cINDEX_LIST_1[4][1] = ''
cINDEX_LIST_1[4][2] = ''
ELSE IF(!nNOW_PLAYING)
nCURRENT_MENU = 1
OFF[nNOW_PLAYING]
CASE 2: //Select - occurs on Release and Hold event
// !! JP !! DISABLED DIRECT PLAY - Direct select occurs on the hold event of each select button
CASE 3: //Play/Pause
IF(TP_BUTTONS[3])
SEND_CMD("'PLAY_CONTROL=1'")
nPLAY_STATE = 0
ELSE
nPLAY_STATE = 1
fnDO_FEEDBACK()
WAIT 2
WAIT 5
WAIT 7
CASE 4: //Offline/Online
IF(nONLINE)
SEND_CMD("'EXIT_REMOTE_UI_MODE='")
SEND_COMMAND dvTP, '@PPN-EJECT;iPort' // Popup EJECT on
WAIT 5
nRUN_ONCEa = 0
nRUN_ONCEb = 0
nONLINE = 0
WAIT 50
fnDO_FEEDBACK()
WAIT 60
ELSE
SEND_CMD("'ENTER_REMOTE_UI_MODE='")
WAIT 20
CASE 5:{} //Previous (Done in Release Event)
CASE 6:{} //Next (Done in Release Event)
CASE 7:{} //Fast Rewind (Done in Hold Event)
CASE 8:{} //Fast Forward (Done in Hold Event)
CASE 9: // -10 Up or list up full index length
IF(nDOUBLE_PUSH = 0) //Do a normal list jump
nDOUBLE_PUSH = 1 //Set this to 0 or comment out if you do not want double push to occur
nLEVEL_FLAG = 0
IF(nCURRENT_INDEX_NUM[nCURRENT_MENU] > 1)
IF(nCURRENT_INDEX_NUM[nCURRENT_MENU] <= nCURRENT_INDEX_LENGTH) // LESS THAN 10 RECORDS BACK FILL LIST WITH 0-9 RECORDS
IF(nCURRENT_CATEGORY_START = 1 && nCURRENT_MENU = 2) //Is the current menu the Playlists Menu?
nCURRENT_INDEX_NUM[nCURRENT_MENU] = 1 // don't get the playlist which is the name of the iPod - iPod bug fix
ELSE
nCURRENT_INDEX_NUM[nCURRENT_MENU] = 0 // Start menu at beginning of current list
SEND_CMD("'RETRIEVE_CATEGORIZED_DB_RECORDS?',ITOA(nCURRENT_CATEGORY2[nCURRENT_MENU]),':',ITOA(nCURRENT_INDEX_NUM[nCURRENT_MENU]),':',ITOA(nCURRENT_INDEX_LENGTH - 1)")
fnUPDATE_INDEX_LEVEL(nCURRENT_INDEX_NUM[nCURRENT_MENU])
SEND_VTEXT(TP_FIELDS[20],"'1 / ',ITOA(nMENU_RECORD_COUNT[nCURRENT_MENU] + 1)")
ELSE // MORE THAN List Length of RECORDS LEFT IN LIST
IF((nCURRENT_INDEX_NUM[nCURRENT_MENU] - nCURRENT_INDEX_LENGTH) <= 0)
//End of list
ELSE
nCURRENT_INDEX_NUM[nCURRENT_MENU] = nCURRENT_INDEX_NUM[nCURRENT_MENU] - nCURRENT_INDEX_LENGTH
SEND_CMD("'RETRIEVE_CATEGORIZED_DB_RECORDS?',ITOA(nCURRENT_CATEGORY2[nCURRENT_MENU]),':',ITOA(nCURRENT_INDEX_NUM[nCURRENT_MENU]-1),':',ITOA(nCURRENT_INDEX_LENGTH - 1)") // -1:9
SEND_VTEXT(TP_FIELDS[20],"ITOA(nCURRENT_INDEX_NUM[nCURRENT_MENU]),' / ',ITOA(nMENU_RECORD_COUNT[nCURRENT_MENU] + 1)")
ELSE // Jump to the top of the list
//End of list
ELSE
ELSE
SEND_CMD("'RETRIEVE_CATEGORIZED_DB_RECORDS?',ITOA(nCURRENT_CATEGORY2[nCURRENT_MENU]),':1:',ITOA(nCURRENT_INDEX_LENGTH - 1)")
SEND_VTEXT(TP_FIELDS[20],"' 1 / ',ITOA(nMENU_RECORD_COUNT[nCURRENT_MENU] + 1)")
WAIT 5
nDOUBLE_PUSH = 0
CASE 10: // -1 Up
STACK_VAR INTEGER i
nLEVEL_FLAG = 0
IF(nCURRENT_INDEX_NUM[nCURRENT_MENU] <= 1)
//End of list
ELSE
nCURRENT_INDEX_NUM[nCURRENT_MENU] --
SEND_CMD("'RETRIEVE_CATEGORIZED_DB_RECORDS?',ITOA(nCURRENT_CATEGORY2[nCURRENT_MENU]),':',ITOA(nCURRENT_INDEX_NUM[nCURRENT_MENU]-1),':',ITOA(nCURRENT_INDEX_LENGTH - 1)") // -1 0 was 1
SEND_VTEXT(TP_FIELDS[20],"ITOA(nCURRENT_INDEX_NUM[nCURRENT_MENU]),' / ',ITOA(nMENU_RECORD_COUNT[nCURRENT_MENU] + 1)") // ADDED SPACES
CASE 11: // +1 Down
STACK_VAR INTEGER i
nLEVEL_FLAG = 0
IF((nCURRENT_INDEX_NUM[nCURRENT_MENU]+ (nCURRENT_INDEX_LENGTH - 1)) >= nMENU_RECORD_COUNT[nCURRENT_MENU])
//End of list
ELSE
nCURRENT_INDEX_NUM[nCURRENT_MENU]++
//WAIT 1
CASE 12: // +10 Down or list down full index length
IF(nDOUBLE_PUSH = 0) // Do normal jump of list
nDOUBLE_PUSH = 1 // Comment this out if you do not want double push on down button to go to the bottom of the list
nLEVEL_FLAG = 0
nWAIT_FLAG = 1
IF((nCURRENT_INDEX_NUM[nCURRENT_MENU]+(nCURRENT_INDEX_LENGTH * 2)) <= nMENU_RECORD_COUNT[nCURRENT_MENU]) // If the list is less than 2x the list length from the end
nCURRENT_INDEX_NUM[nCURRENT_MENU] = nCURRENT_INDEX_NUM[nCURRENT_MENU] + nCURRENT_INDEX_LENGTH // changed from 10 for dynamic listing
SEND_CMD("'RETRIEVE_CATEGORIZED_DB_RECORDS?',ITOA(nCURRENT_CATEGORY2[nCURRENT_MENU]),':',ITOA(nCURRENT_INDEX_NUM[nCURRENT_MENU]-1),':',ITOA(nCURRENT_INDEX_LENGTH - 1)") // -1 and 9 was 10
//SEND_STRING 0,"'in the IF'"
ELSE // LESS THAN Index Length of RECORDS FROM LAST
nCURRENT_INDEX_NUM[nCURRENT_MENU] = nMENU_RECORD_COUNT[nCURRENT_MENU] - nCURRENT_INDEX_LENGTH // changed from 10 for dynamic listing
SEND_CMD("'RETRIEVE_CATEGORIZED_DB_RECORDS?',ITOA(nCURRENT_CATEGORY2[nCURRENT_MENU]),':',ITOA(nCURRENT_INDEX_NUM[nCURRENT_MENU]),':',ITOA(nCURRENT_INDEX_LENGTH - 1)") // -1 and 9 was 10
fnUPDATE_INDEX_LEVEL(nCURRENT_INDEX_NUM[nCURRENT_MENU]+1)
nCURRENT_INDEX_NUM[nCURRENT_MENU]++ // NEED TO ADD 1 WHEN AT END OF LIST
//SEND_STRING 0,"'in the ELSE'"
ELSE //Jump to the bottom of the list if double push occured
//SEND_STRING 0,"'in the DOUBLE ELSE'"
WAIT 5
nDOUBLE_PUSH = 0
CASE 13: // Selection 1
CASE 14: // Selection 2
CASE 15: // Selection 3
CASE 16: // Selection 4
CASE 17: // Selection 5
CASE 18: // Selection 6
CASE 19: // Selection 7
CASE 20: // Selection 8
CASE 21: // Selection 9
CASE 22: // Selection 10
// Moved to release of the button for version 1.1
(*IF(LENGTH_STRING(cINDEX_LIST_1[nCURRENT_MENU][1][(nKEY_PRESSED - 12)]) = 0) //Checks array to see if position is empty and if so will not allow user to select nothing
//Do Nothing
ELSE // Since the array has something it allows the selection
//fnINDEX_HILITE(nKEY_PRESSED - 12)
fnPROCESS_SELECTION(nKEY_PRESSED - 12)
CASE 23: //Repeat options
IF(nREPEAT_ON <= 1)
nREPEAT_ON ++
ELSE
nREPEAT_ON = 0
SEND_CMD("'SET_REPEAT=',ITOA(nREPEAT_ON)")
fnDO_FEEDBACK()
CASE 24: //Shuffle Options
IF(nSHUFFLE_ON <= 1)
nSHUFFLE_ON ++
ELSE
nSHUFFLE_ON = 0
SEND_CMD("'SET_SHUFFLE=',ITOA(nSHUFFLE_ON)")
fnDO_FEEDBACK()
CASE 25: // Case 25 and 26 are both done on the Release below
CASE 27: //List Level Set
nLEVEL_FLAG = 1
CASE 42: // TP is on the iPort page
STACK_VAR INTEGER iPanel_on
iPanel_on = GET_LAST(dvTP)
nON_IPORT_PAGE[iPanel_on] = 1
nRUN_ONCEa = 0
ELSE //Clear info and show offline
OFF[nNOW_PLAYING]
CASE 43: // TP is off the iPort page
RELEASE:
IF(nFF_RWD_ON > 0)
SEND_CMD("'PLAY_CONTROL=7'") //Stop Fast Forward Search/Rewind
nFF_RWD_ON = 0
fnDO_FEEDBACK()
nHOLD = 0
ELSE
CASE 5: // Previous
nHOLD = 0
SEND_CMD("'PLAY_CONTROL=4'")
nFF_RWD_ON = 1
fnDO_FEEDBACK()
WAIT 10
nFF_RWD_ON = 0
fnDO_FEEDBACK()
CASE 6: //Next
nHOLD = 0
SEND_CMD("'PLAY_CONTROL=3'")
nFF_RWD_ON = 2
fnDO_FEEDBACK()
WAIT 10
nFF_RWD_ON = 0
fnDO_FEEDBACK()
CASE 9:
CASE 10:
CASE 11:
CASE 12:
nLEVEL_FLAG = 1
IF(nHOLD = 0) //If Hold was not produced process selection
//Do Nothing
//WAIT 15
fnDO_FEEDBACK()
nHOLD = 0
CASE 25:
OFF[nNOW_PLAYING]
//fnDO_HILITE()
CASE 26:
[code]
(* REV HISTORY: *)
DEFINE_CONSTANT
DEFINE_TYPE
DEFINE_LATCHING
ELSE
CASE 0:
CASE 1:
CASE 2:
CASE 0:
CASE 1:
CASE 2:
nONLINE_FLAG = 0
nONLINE = 1
fnDO_FEEDBACK()
SWITCH(UIMode)
CASE 1: //Online
nONLINE = 1
nRUN_ONCEb = 0
nONLINE_FLAG = 0
CASE 0: //Offline
nONLINE = 0
nRUN_ONCEa = 0
SWITCH(DockStatus)
CASE 1: //Online
nONLINE = 1
nRUN_ONCEb = 0
nONLINE_FLAG = 0
CASE 0: //Offline
nONLINE = 0
nRUN_ONCEa = 0
nONLINE_FLAG = 1
WAIT 90
IF(nONLINE_FLAG)
nONLINE = 0
fnDO_FEEDBACK()
nRUN_ONCEa = 0
SWITCH(PLAYMode)
CASE 0: //Stopped
CASE 1: //Playing
CASE 2: //Paused
CASE 3: //Error
SWITCH(nRepeatMode)
nREPEAT_ON = 0
fnDO_FEEDBACK()
nREPEAT_ON = 1
fnDO_FEEDBACK()
nREPEAT_ON = 2
fnDO_FEEDBACK()
nSHUFFLE_ON = 0
fnDO_FEEDBACK()
nSHUFFLE_ON = 1
fnDO_FEEDBACK()
nSHUFFLE_ON = 2
fnDO_FEEDBACK()
nONLINE = 1
fnDO_FEEDBACK()
WAIT 2
INTEGER nTHour
INTEGER nTMinute
INTEGER nTSecond
ELSE
ELSE
ELSE
INTEGER nLHour
INTEGER nLMinute
INTEGER nLSecond
CHAR cSongLength[8]
nONLINE = 1
fnDO_FEEDBACK()
WAIT 2
ELSE
nSELECT_FLAG = 0
ELSE
WAIT 2
fnCLEAR_LIST()
ELSE
SWITCH(nVIDEO_MENU)
CASE 0: //Music
CASE 3: //TV Shows
ELSE
CASE 1: //Movies
ELSE
ELSE
ELSE
ELSE
CASE 4:
IF(nSELECT_FLAG)
nSELECT_FLAG = 0
ELSE
SWITCH(nVIDEO_MENU)
CASE 0: //Music
CASE 3: //TV Shows
ELSE
ELSE
ELSE
ELSE
STACK_VAR INTEGER i
CHAR cTrash[5]
nWAIT_FLAG = 0
IF(!nRUN_ONCEa)
WAIT 5
nRUN_ONCEa = 1
nCURRENT_MENU = 1
//fnINDEX_HILITE(1)
fnDO_FEEDBACK()
WAIT 8
WAIT 11
WAIT 14
WAIT 16
WAIT 19
OFF[nNOW_PLAYING]
IF(!nRUN_ONCEb)
//fnINDEX_HILITE(1)
fnDO_FEEDBACK()
nRUN_ONCEb = 1
OFF[nNOW_PLAYING]
STACK_VAR INTEGER i
CASE 1: //Main Menu
fnCLEAR_LIST()
WAIT 3
WAIT 5
fnCLEAR_LIST()
fnCLEAR_LIST()
WAIT 3
WAIT 5
fnCLEAR_LIST()
ELSE
WAIT 2
fnCLEAR_LIST()
CASE 2: //Menu #2
WAIT 2
fnCLEAR_LIST()
fnCLEAR_LIST()
WAIT 2
fnCLEAR_LIST()
SWITCH(nVIDEO_MENU)
CASE 0: //Music
CASE 3: //TV Shows
WAIT 2
fnCLEAR_LIST()
CASE 1: //Movies
WAIT 2
fnCLEAR_LIST()
nCURRENT_MENU = 1
fnCLEAR_SONG_INFO()
WAIT 2
WAIT 3
fnPAGE_FLIP_NP()
WAIT 2
fnCLEAR_LIST()
WAIT 2
fnCLEAR_LIST()
CASE 8: // PODCASTS
WAIT 2
fnCLEAR_LIST()
CASE 3: // Menu #3
nCURRENT_MENU = 2
fnCLEAR_SONG_INFO()
WAIT 2
WAIT 3
fnPAGE_FLIP_NP()
WAIT 2
fnCLEAR_LIST()
nCURRENT_MENU = 2
fnCLEAR_SONG_INFO()
WAIT 2
WAIT 3
SWITCH(nVIDEO_MENU)
WAIT 2
fnCLEAR_LIST()
nCURRENT_MENU = 2
fnCLEAR_SONG_INFO()
WAIT 2
WAIT 3
WAIT 2
WAIT 4
fnCLEAR_LIST()
//nCURRENT_MENU = 2
//WAIT 2
//WAIT 3
CASE 6: //Composer
nCURRENT_MENU = 2
fnCLEAR_SONG_INFO()
WAIT 2
WAIT 3
CASE 8: // PODCASTS
nCURRENT_MENU = 2
fnCLEAR_SONG_INFO()
WAIT 2
WAIT 3
CASE 4: // Menu #3
nCURRENT_MENU = 3
fnCLEAR_SONG_INFO()
WAIT 2
WAIT 3
SWITCH(nVIDEO_MENU)
CASE 0: //Music
CASE 3: //TV Shows
WAIT 2
fnCLEAR_LIST()
CASE 2:
CASE 4:
nCURRENT_MENU = 3
fnCLEAR_SONG_INFO()
WAIT 2
WAIT 3
nCURRENT_MENU = 4
fnCLEAR_SONG_INFO()
WAIT 2
WAIT 3
nCURRENT_MENU = 5
nTemp = nLevel
ELSE
fnDO_FEEDBACK()
OFF[nNOW_PLAYING]
WAIT 5
WAIT 5
STRING:
DATA_EVENT[dvTP]
ONLINE:
nRUN_ONCEa = 0
ELSE
OFF[nNOW_PLAYING]
OFFLINE:
nONLINE_FLAG = 1
WAIT 50
IF(nONLINE)
WAIT 90
IF(nONLINE_FLAG)
nONLINE = 0
fnDO_FEEDBACK()
nRUN_ONCEa = 0
ELSE
//nONLINE = 1
nCURRENT_MENU = 2
nVIDEO_MENU = 0
STACK_VAR INTEGER i
nCURRENT_MENU = 2
nNO_ALBUM = 0
//fnDO_HILITE()
STACK_VAR INTEGER i
//fnDO_HILITE()
nCURRENT_MENU = 1
OFF[nNOW_PLAYING]
IF(TP_BUTTONS[3])
nPLAY_STATE = 0
ELSE
nPLAY_STATE = 1
fnDO_FEEDBACK()
WAIT 2
WAIT 5
WAIT 7
IF(nONLINE)
WAIT 5
nRUN_ONCEa = 0
nRUN_ONCEb = 0
nONLINE = 0
WAIT 50
fnDO_FEEDBACK()
WAIT 60
ELSE
WAIT 20
nLEVEL_FLAG = 0
ELSE
//End of list
ELSE
//End of list
ELSE
ELSE
WAIT 5
nDOUBLE_PUSH = 0
CASE 10: // -1 Up
STACK_VAR INTEGER i
nLEVEL_FLAG = 0
//End of list
ELSE
CASE 11: // +1 Down
STACK_VAR INTEGER i
nLEVEL_FLAG = 0
//End of list
ELSE
//WAIT 1
nLEVEL_FLAG = 0
nWAIT_FLAG = 1
WAIT 5
nDOUBLE_PUSH = 0
//Do Nothing
IF(nREPEAT_ON <= 1)
nREPEAT_ON ++
ELSE
nREPEAT_ON = 0
fnDO_FEEDBACK()
nSHUFFLE_ON ++
ELSE
nSHUFFLE_ON = 0
fnDO_FEEDBACK()
nLEVEL_FLAG = 1
nRUN_ONCEa = 0
OFF[nNOW_PLAYING]
RELEASE:
IF(nFF_RWD_ON > 0)
nFF_RWD_ON = 0
fnDO_FEEDBACK()
nHOLD = 0
ELSE
CASE 5: // Previous
nHOLD = 0
nFF_RWD_ON = 1
fnDO_FEEDBACK()
WAIT 10
nFF_RWD_ON = 0
fnDO_FEEDBACK()
CASE 6: //Next
nHOLD = 0
nFF_RWD_ON = 2
fnDO_FEEDBACK()
WAIT 10
nFF_RWD_ON = 0
fnDO_FEEDBACK()
CASE 9:
CASE 10:
CASE 11:
CASE 12:
nLEVEL_FLAG = 1
//Do Nothing
//WAIT 15
fnDO_FEEDBACK()
nHOLD = 0
CASE 25:
OFF[nNOW_PLAYING]
//fnDO_HILITE()
CASE 26:
In this case, the point looks to be to prevent having to cut and paste identical code to another location. If that code has to change, you now have to track down every copy of it. Without spending any more than the 30 seconds I took to look that code over (
What are the issues that the naysayers have with it? I've been using it extensively lately in my new modules as the primary means of communication between the main code ui and the comm module. I normally use the do_push_timed infinite followed by a do_release which allows me create a hold in my module which you can't do with a channel event w/o creating/terminating a timeline. I haven't noticed any problems with this method and can't image it being any more or less reliable than a channel event trigger by an ON, OFF or PULSE [something,xx].
So what's the deal? Why the hatred of my beloved DO_PUSH?
Mee too. I use DO_PUSH all the time with no ill effects. The times I've seen people get in trouble with it is when they seem to have a mixed up understanding of the difference between a button being 'on' and a button being 'pushed'
I commonly make my modules activate funtions via button pushes. So the main program just pushes a button on the module's virt device and the fun begins.
Love and embrace the DO_PUSH, don't fear and outcast it!
When writing modules, I tend to stick with channel_events as opposed to button_events within the module. The reason I decided to go with this is it seems to be the new standard for AMX modules and I like the look of pulse[dev,chan] better than do_push(dev,chan).... plus I don't have to use the SHIFT key to type pulse
I tried the channel route but didn't want to create a timeline to affect a hold/repeat. When using a do_push_timed I can mirror the button pushes, holds and releases in the module. And as you mentioned by using the do_push_timed the button push will last as long or as short as you hold the button just the same as sending a channel on/off with a push/release.
You can't use do_push(_timed) for an array of devices so that limitation alone makes it virtually useless in my code.
