NO Data in buffer, realy URGENT !!!
I have create buffer, and I can see incoming string, but there is no data in buffer?
What can be a problem ?
dvAudioMixer = 5001:1:1
char drugo[500]
VOLATILE char trece[500]
create_buffer dvAudioMixer,drugo
create_buffer vdvAudioMixer1,trece
I am using some module to controll Philips (BOSCH) DCN system.
URGENT
    You may need to have a data event for the hardware in order to see the incoming strings in notifications.
  • VladaPUBVladaPUB Posts: 139
    I see string in notification !!! I sometimes can see it in buffer, but it stop respond after SOME time (less than minute) !!
    Are you doing anything with the buffer? If the buffer fills up, I don't think it overwrites the data. You could also make the variables that hold the buffered data larger if the device is really active.
    Also, is the module a duet module? If so, they take control of the physical device and prevent notifications from being seen by netlinx.
    Spire_Jeff wrote: »
    HOW ??
    Yes, it is duet module !
    Duet has priority over the physical port. If you need to parse the raw data coming from the device, most duet modules have a PASSBACK command. This will send all incoming data from the physical device to the virtual device as a String. Check the manual for the duet module and it should indicate this.
  • yuriyuri Posts: 861
    you're using the Duet module to control a Philips DCN CCU?
    Is it a Next Generation CCU, or the "old" one?
    For the old one there is also an axcent code file on the AMX website :)
