Calling a webservice???
I need to call a web service from a Sonic Foundry webserver and I need to know if this is possible from opening and IP connection to the server. I have attached the technical doc.
Hi Steve,
Yes it's possible.
And how was this possible? I'm attempting to do something similar with VBrick Portal Server.
If you do not have a sample application available and are not familiar with programming in a .NET language, you may be looking up a very steep learning curve.
The SDK has some sample .NET apps. I have few yrs in programming .NET so I'll get the APP up and monitor as you suggest.
