Kaleidescape Module 7.20
Has anyone had issues with the SATP with the new version of the module?
I am not getting any kind of feedback on the SATP but I have some control.
here is my include file
I am also using a do_push based on the player to select the correct one
Does anyone have a modified version of the module that does away with the
char m_UIPages[20][],
char m_UIPopups[10][],
char m_UIImages[3][],
char m_UIIcons[3]
as we are using a non standard panel design?
I am also getting the following errors
PROGRAM_NAME='KPLAYERS' /******************************************************************************************* * File Information *******************************************************************************************/ /* * (c) 2004-2009 Kaleidescape Inc. Please see legal notice below. * * Version 7.2.0 * Dated Jan 16, 2009 * * This module has been created and supported by Kaleidescape Inc. * This module is supported directly by Kaleidescape Inc. Please * direct all inquiries regarding this module to Kaleidescape support * at (650) 625-6160. AMX does not support this module itself. * * ---------------------------------------------------------------------- * * LEGAL NOTICE * (c) 2004-2009 Kaleidescape Inc. This Source Code is the intellectual * property of Kaleidescape, Inc. Kaleidescape grants the non-exclusive * right to modify and/or compile and/or compress the Source Code, and * upload such modified and/or compiled and/or compressed Source Code * to control systems that control at least one licensed Kaleidescape * System. No right is granted to otherwise copy, reproduce, modify, * upload, download, transmit, or distribute the Source Code, or * derivative works, in any way. The Source Code, and derivative works, * are protected by copyright, trade secret, and other intellectual * property laws and by international treaties, which provide rights * and obligations in addition to the rights and obligations set forth here. */ /******************************************************************************************* * Device Definitions *******************************************************************************************/ DEFINE_DEVICE /******************************************************** * Create a virtual device per KPlayer controlled. * ********************************************************/ KPLAYER1 = 33005:1:0 KPLAYER2 = 33006:1:0 KPLAYER3 = 33007:1:0 KPLAYER4 = 33008:1:0 KPLAYER5 = 33009:1:0 KPLAYER6 = 33010:1:0 KPLAYER7 = 33011:1:0 KPLAYER8 = 33012:1:0 /******************************************************************************************* * Global Variables *******************************************************************************************/ DEFINE_VARIABLE /******************************************************** * Put all Kplayer virtual devs into one array. * ********************************************************/ dev Kplayer[] = //Add any additional controlled players here { KPLAYER1, KPLAYER2, KPLAYER3, KPLAYER4, KPLAYER5, KPLAYER6, KPLAYER7, KPLAYER8 } /******************************************************** * Define all the touch panels that will control a * * Kaleidescape Player and which player they will * * control. * ********************************************************/ //An array of all the touch panels that will control the K Players dev KTouchPanels[] = { dvFoyer_Kal, dvWineCellar_Kal, dvBedroom1_Kal, dvHall7_Kal, dvGarage_Kal, dvExercise_Kal, dvDining_Kal, dvKitchen_Kal, dvHerVanity_Kal, dvLoggia_Kal, dvSnackBar_Kal, dvTheater_Kal, dvCabana_Kal, dvSafe_Kal } //This array determines what player each touch panel controls integer controlledKplayer[] = //for each touch panel, add an entry to this array { 0,0,0,0,0, 0,0,0,0,0, 0,0,0,0,0 //First TP to control Player 1 //2, //Second TP to control Player 2 //3, //Third TP to control Player 3 } /******************************************************** * Create an array of the Kaleidescape TP page names. * * These pages are called when the player flips to the * * indicated page. * ********************************************************/ char KTouchpanelPages[20][20] //page names on the touch panel for automatic page flip /******************************************************** * Create an array of the Kaleidescape TP popup names. * * These popups are called at various points. * ********************************************************/ char KTouchpanelPopups[10][30] //popup names on the touch panel /*********************************************************** * Create an array of the Kaleidescape TP resource names. * * These resources are updated with the URL of the * * appropriate images. * ***********************************************************/ char KTouchpanelResources[3][20] //resource names on the touch panel /********************************************************** * Create an array of the Kaleidescape TP bitmap names. * * These are used in SATP to indicate the status of each * * line shown on the touch panel text window. * *********************************************************/ char KTouchpanelIcons[3] = //icons on the touch panel { 3, //play 2, //pause 1 //checkmark } /******************************************************** * Create an array of the Variable Text fields to * * populate on the touch panel. * ********************************************************/ integer KVariableTextFields[30] = { 1, //Movie Title 2, //Chapter number 3, //Total track time 4, //Remaining track time 5, //Current track time 6, //Keyboard & Keypad prompt 7, //Keyboard & Keypad entry field 0, //unused //Player friendly name 8, //Details title 9, //Details info 11, //Song Name 12, //Artist Name 13, //Album Name 14, //SATP Search Button 15, //SATP Keyboard Text feedback 16, //SATP Search Mini Result 17, //Now Playing Item 18, //PRESET 1 Label 19, //PRESET 2 Label 20, //PRESET 3 Label 21, //PRESET 4 Label 22, //PRESET 5 Label 23, //PRESET 6 Label 24, //PRESET 7 Label 25, //PRESET 8 Label 26, //PRESET 9 Label 27 //PRESET 10 Label } /******************************************************** * The following two arrays are only needed under * * special circumstances. If the keyboard strings come* * from a different device than the button and level * * events, enable these arrays and define the * * information just as above. * ********************************************************/ //An array of all the keyboard devices that will control the K Players /*dev keyboardDev[] = { TP_ONE_KEYB //Note that this is different than the TP_ONE above. //TP_TWO_KEYB, //TP_THREE_KEYB, } //This array determines what player each touch panel keyboard controls integer controlledKplayerKeyboard[] = { 1 //First TP Keyboard to control Player 1 //2, //Second TP Keyboard to control Player 2 //1, //Third TP Keyboard to control Player 1 } */ /********************************************************* * Define the module with the created variables/devices.* *********************************************************/ DEFINE_MODULE 'Kaleidescape' Kplayers ( dvKalPort, //port (232 or TCP/IP) used for communication with //the Kaleidescape System Kplayer, //virtual device array for communicating with one //or more Kaleidescape Players KVariableTextFields, //Variable text fields to use on the touch panel KTouchpanelPages, //Pages to flip to on the touch panel for //various OSD states KTouchpanelPopups, //Popup pages to turn on/off on the touch panel KTouchpanelResources, //Touch panel resources (cover art) to update KTouchpanelIcons) //Bitmaps to use /****************************************************************************************** * Startup code * ******************************************************************************************/ DEFINE_START //Populate the TP page names array /*KTouchpanelPages[1] = 'K MovieList' //Movie List control page KTouchpanelPages[2] = 'K Collections' //Movie Collections control page KTouchpanelPages[3] = 'K CoverArt' //Movie Covers control page KTouchpanelPages[4] = 'K ParentalControl' //Parental controls page KTouchpanelPages[5] = '' //unused - reserved for future use KTouchpanelPages[6] = '' //Screen Saver enabled KTouchpanelPages[7] = 'K Movie Playing' //Playing a movie KTouchpanelPages[8] = 'K StatusScreen' //System status page KTouchpanelPages[9] = 'K MusicList' //Music List control page KTouchpanelPages[10]= 'K MusicCovers' //Music Covers control page KTouchpanelPages[11]= 'K MusicCollections' //Music Collections control page KTouchpanelPages[12]= 'K MusicNowPlaying' //Music Now Playing control page KTouchpanelPopups[1] = 'K Keyboard' //Keyboard popup page KTouchpanelPopups[2] = 'K Keypad' //Numeric keypad popup page KTouchpanelPopups[3] = 'K Music Playing' //Music Playing info popup KTouchpanelPopups[4] = 'K Details' //Details popup (only used for OSD w/o Video control) KTouchpanelPopups[5] = '' //SATP Now Playing popup KTouchpanelPopups[6] = 'K SATP Keyboard Search' //SATP Keyboard Search KTouchpanelResources[1] = 'K Now Playing Cover' //Cover art for the currently playing item KTouchpanelResources[2] = 'K Details Cover' //Cover art for the currently showing details KTouchpanelResources[3] = '' //unused - reserved for future use */ /********************************************************* * Set up interface information. * *********************************************************/ /* * tell the module the what this virtual device should control: * send_command <virtual device>, '<ID>[.<Zone>][/<sequence>]' * * <ID> is set on the player as the * "Control Protocol Device ID" within the installer web * utility. If the IP addresse defined below (in the 'IP' command) * is the IP address of the player, you can simply use an ID of '01' * and the module will figure out the correct setting. * * example: * send_command KPLAYER1, 'ID 05' will make the virtual device * KPLAYER1 control the player * whose Control Protocol Device ID * is set to 5. * * if using SATP, you need to define which zone you want to * control. Zone (output) 1 of the Kaleidescape Music Player * is defined as '.01' Zone 2 is '.02' etc. If you want to set * the virtual device to use SATP with a Kaleidescape Movie * Player, set the Zone to '.01' * * examples: * send_command KPLAYER1, 'ID 05.03' will make the virtual device * KPLAYER1 control output 3 on * player 5 using SATP. * * send_command KPLAYER1, 'ID 05.01' will make the virtual device * KPLAYER1 control output 1 on * player 5 using SATP. (the only * output for a movie player) * * if you need to control the same player's Zone with multiple, different * sized touch panels or you want to allow each touch panel to browse * independently, you need to define separate virtual devices * that use the same ID and Zone, but use different sequence numbers. * The sequence number is a single digit between 1 and 9. * * example: * send_command KPLAYER1, 'ID 05.03/1' * send_command KPLAYER2, 'ID 05.03/2' * both KPLAYER1 and KPLAYER2 will * control output 3 on player 5, * but will have independant browse * trees, and can show a different * number of lines on the touch panel. */ /* * sometimes there are problems with the startup sequence. * this wait will clear up those problems by ensuring these * commands are only sent after the event handler starts. */ Send_Command KPLAYER1,'DEBUG' wait 50 { send_command KPLAYER1, 'ID 02' //OSD control send_command KPLAYER2, 'ID 03' //OSD control send_command KPLAYER3, 'ID 04' //OSD control send_command KPLAYER4, 'ID 05' //OSD control send_command KPLAYER5, 'ID 06.01' //SATP control send_command KPLAYER6, 'ID 06.02' //SATP control send_command KPLAYER7, 'ID 06.03' //SATP control send_command KPLAYER8, 'ID 06.04' //SATP control //send_command KPLAYER2, 'ID 01.01' //SATP control //send_command KPLAYER2, 'ID 04' //send_command KPLAYER3, 'ID 05' /* * If Kaleidescape_Port is a network port, tell the module * the ip address to connect to. This only needs to be set * once for the entire module and can be sent through * any one of the defined virtual devices. */ /* * Kaleidescape recommends using the server as the single * point of connection. That way if any player is turned off, * the rest of the system will still function. */ send_command KPLAYER1, 'IP 192.168.4.150' //send_command KPLAYER2, 'IP 192.168.4.150' // send_command KPLAYER3, 'IP 192.168.4.150' // send_command KPLAYER4, 'IP 192.168.4.150' // send_command KPLAYER5, 'IP 192.168.4.150' // send_command KPLAYER6, 'IP 192.168.4.150' // send_command KPLAYER7, 'IP 192.168.4.150' // send_command KPLAYER8, 'IP 192.168.4.150' //Tell the module how many SATP lines of text to populate on this interface send_command KPLAYER5, 'LINES 6' //AXT-CV6 and CP4 send_command KPLAYER6, 'LINES 6' //CV10, MVP-8400 and NXT-1700 send_command KPLAYER7, 'LINES 6' send_command KPLAYER8, 'LINES 6' /* * This section sets up the keypad control of the module. * Keypads can be used to start music playing without requring the user * to use either a video display or a text-based touch panel. */ /* * There are two methods for keypad control. The first is a set of buttons * to cycle through any collection. Each virtual device can be instructed * to control up to three collections. There are 3 channels per collection - * first, next and previous. */ //define the first set of channels to cycle through albums //send_command KPLAYER1, 'COLLECTION 1 Albums' //first = 131, next = 132, previous = 133 //define the second set of channels to cycle through genres //send_command KPLAYER1, 'COLLECTION 2 Genres' //first = 134, next = 135, previous = 136 //define the third set of channels to cycle through mix albums //send_command KPLAYER1, 'COLLECTION 3 Mix Albums' //first = 137, next = 138, previous = 139 /* * For keypad control, all virtual devices are set up independantly. If KPLAYER2 is defined, * and a keypad is to be used to control it, copy the above commands and define which collections * it will cycle through. */ /* * The second method for keypad control is using presets. * The 10 channels for presets are 121-130 * Every virtual device needs a Preset ID to identify which set of presets to use. * This ID is used to identify a set of presets to the player, and may one day * be visible to the user. * * The Preset ID is used to create the tag that is ultimately used per preset. * If a Preset ID of 'test' is used, the first preset (channel 121) will use the tag * 'test1', the second preset (channel 122) will use the tag 'test2', etc. */ //send_command KPLAYER1, 'PRESET ID test' /* * if two different players are to share a set of presets, give them the same Preset ID. * To save a preset, press and hold the channel (use a "to" statement) and the preset will save * See below for sample code. */ } //end of wait /************************** * End of interface setup * **************************/ /* * Use this call to match user defined events. User defined events can be used * inside scripts to make the control system do something. Examples may be to * change the lighting level, open or close curtains, or whatever else the end-user * may want to happen automatically from a script that they write. * * A good suggestion is to give the user a mechanism to disable the screen masking * changes. This way, when they've got a script that plays a series of favorite * scenes, they can leave the masking set to a specific position. You may also * want to provide a command to re-enable the auto masking within a script * so that if the user wanted to create a script that played a series of favorite * scenes, then a movie - they could freeze the mask when desired (scenes) then * allow the mask to automatically move at the appropriate time (during the movie). */ /*DEFINE_CALL 'Kaleidescape User Commands' (integer kplayerReference, char userCommand[]) { userCommand = upper_string(userCommand) //make all text case insensitive switch (userCommand) { case 'OPEN CURTAINS': {} case 'DISABLE MASK': {} case 'ENABLE MASK': {} case 'START POPCORN': {} } }*/ /******************************************************************************************* * Event Handlers *******************************************************************************************/ DEFINE_EVENT /* * if the TP is controlling multiple players or other devices with the same * channel, level or VT numbers, put a conditional on the events below * and only send controls or feedback when the Player is selected on the TP. * * In such a case, the UI may be out of sync. Issue the following command: * send_command KPLAYER1, 'refresh' * and the TP page flips, VT data and levels will be resent. */ DATA_EVENT[KTouchPanels] { online: { stack_var integer touchpanelRef stack_var integer kplayerRef //determine which touch panel triggered the event touchpanelRef = get_last(KTouchPanels) //determine which player this panel is controlling kplayerRef = controlledKplayer[touchpanelRef] //tell the controlled player to refresh the signals if(kplayerRef > 0) send_command Kplayer[kplayerRef], 'refresh' } /* * keyboard input can be accomplished by placing text within the buttons on the * touch panel. Set key "a" to "KAL-A", "b" to "KAL-B", etc. Any single character * command sent to the interface will be processed as if it were a keyboard key. * the "space" and "backspace" buttons are handled with the button event below. * Space is channel 66 and backspace is 67 */ string: { stack_var char kCharacter[10] stack_var integer touchpanelRef stack_var integer kplayerRef //determine which touch panel triggered the event touchpanelRef = get_last(KTouchPanels) //determine which player this panel is controlling kplayerRef = controlledKplayer[touchpanelRef] //only proceed if the ref is valid if(kplayerRef > 0) { if(find_string(data.text,'KAL-', 1)) // when our custom header is found { remove_string(data.text, 'KAL-', 1) // remove the header kCharacter = "get_buffer_char(data.text)" // remove the keyboard character if(kCharacter[1] = '[') // if this is a fuzzy set (for instance [abc2] ) { //pull out the remaining characters kCharacter = "'[', remove_string(data.text,']',1)" } // send that character (or set) to the player send_command Kplayer[kplayerRef], "kCharacter" } if(find_string(data.text,'WAKE',1)) // when the TP wakes up { // clear the screen saver from the kplayer (if active) pulse [Kplayer[kplayerRef],79] } } } } /* * Let's wake up the panel when the K screen saver kicks in, then wake up the panel when * it clears. The above DATA_EVENT will clear the K screen saver when the touch panel * wakes up (opposite of this CHANNEL_EVENT) * * Use caution when changing which player the TP is controlling. If you change the * controlledKplayer array and send 'refresh' the panel will immediately sleep if the * K screen saver is up. The best implementation is to clear the screen saver * with channel 79 immediately before sending the refresh to prevent this. */ /*CHANNEL_EVENT[Kplayer, 1078] //screen saver feedback { on: { stack_var integer touchpanelRef stack_var integer kplayerRef kplayerRef = get_last(Kplayer) //determine which player triggered the event //step through each TP for(touchpanelRef = 1; touchpanelRef <= length_array(KTouchPanels); touchpanelRef++) { //if this TP is controlling this player if(controlledKplayer[touchpanelRef] = kplayerRef) { //put the panel to sleep too send_command KTouchPanels[touchpanelRef], 'SLEEP' } } } off: { stack_var integer touchpanelRef stack_var integer kplayerRef kplayerRef = get_last(Kplayer) //determine which player triggered the event //step through each TP for(touchpanelRef = 1; touchpanelRef <= length_array(KTouchPanels); touchpanelRef++) { //if this TP is controlling this player if(controlledKplayer[touchpanelRef] = kplayerRef) { send_command KTouchPanels[touchpanelRef], 'WAKE' //wake up the panel } } } }*/ /******************************************************** * Pass VT and level information to the touch panel. * ********************************************************/ DATA_EVENT[Kplayer] { string: { stack_var integer touchpanelRef stack_var integer kplayerRef kplayerRef = get_last(Kplayer) //determine which player triggered the event //step through each TP for(touchpanelRef = 1; touchpanelRef <= length_array(KTouchPanels); touchpanelRef++) { //if this TP is controlling this player if(controlledKplayer[touchpanelRef] = kplayerRef) { switch (data.text[1]) //evaluate the first character { case '~': //string passing flag { switch (data.text[2]) //evaluate the second character { case 'U': //user defined command { stack_var char userCommand[256] userCommand = right_string(data.text, length_string(data.text) - 2) //call 'Kaleidescape User Commands' (kplayerRef, userCommand) } } } default: //pass all other commands directly to the touch panel { send_command KTouchPanels[touchpanelRef], data.text } } //end of 'switch' } //end of 'if' } //end of 'for' } //end of 'string' } //end of event /********************************************************* * Pass progress level information to the touch panel. * *********************************************************/ LEVEL_EVENT[Kplayer, 1] { stack_var integer touchpanelRef stack_var integer kplayerRef kplayerRef = get_last(Kplayer) //determine which virtual device triggered the event //step through each TP for(touchpanelRef = 1; touchpanelRef <= length_array(KTouchPanels); touchpanelRef++) { //if this TP is controlling this player if(controlledKplayer[touchpanelRef] = kplayerRef) { //send the level to the touch panel send_level KTouchPanels[touchpanelRef], 1, level.value } } } /********************************************************* * Pass scroll bar top information to the virtual dev. * *********************************************************/ LEVEL_EVENT[KTouchPanels, 4] { stack_var integer touchpanelRef stack_var integer kplayerRef //determine which touch panel triggered the event touchpanelRef = get_last(KTouchPanels) //determine which player this panel is controlling kplayerRef = controlledKplayer[touchpanelRef] if(kplayerRef) { send_level Kplayer[kplayerRef], 4, level.value } } /********************************************************* * Pass scroll bar top information to the touch panel. * *********************************************************/ LEVEL_EVENT[Kplayer, 5] { stack_var integer touchpanelRef stack_var integer kplayerRef kplayerRef = get_last(Kplayer) //determine which virtual device triggered teh event //step through each TP for(touchpanelRef = 1; touchpanelRef <= length_array(KTouchPanels); touchpanelRef++) { //if this TP is controlling this player if(controlledKplayer[touchpanelRef] = kplayerRef) { //send the level to the touch panel send_level KTouchPanels[touchpanelRef], 5, level.value } } } /************************************************************ * Pass scroll bar bottom information to the touch panel. * ************************************************************/ LEVEL_EVENT[Kplayer, 6] { stack_var integer touchpanelRef stack_var integer kplayerRef kplayerRef = get_last(Kplayer) //determine which virtual device triggered teh event //step through each TP for(touchpanelRef = 1; touchpanelRef <= length_array(KTouchPanels); touchpanelRef++) { //if this TP is controlling this player if(controlledKplayer[touchpanelRef] = kplayerRef) { //send the level to the touch panel send_level KTouchPanels[touchpanelRef], 6, level.value } } } /*********************************************************** * Pass all TP presses to module through virtual dev * * note that virtual dev follows standard IR button order * ***********************************************************/ BUTTON_EVENT[KTouchPanels, 0] { push: { stack_var integer touchpanelRef stack_var integer kplayerRef //determine which touch panel triggered the event touchpanelRef = get_last(KTouchPanels) //determine which player this panel is controlling kplayerRef = controlledKplayer[touchpanelRef] if(kplayerRef > 0) { to[Kplayer[kplayerRef], push_channel] } } } /**************************************************** * An example of how to invoke a script. * ****************************************************/ /*BUTTON_EVENT[KTouchPanels, 201] { push: { stack_var integer touchpanelRef stack_var integer kplayerRef //determine which touch panel triggered the event touchpanelRef = get_last(KTouchPanels) //determine which player this panel is controlling kplayerRef = controlledKplayer[touchpanelRef] if(kplayerRef > 0) { send_command Kplayer[kplayerRef], "'PLAY_SCRIPT:Theater Startup:'" } } }*/ /**************************************************** * Pass TP XY levels to module through virtual dev * ****************************************************/ LEVEL_EVENT[KTouchPanels, 7] { stack_var integer touchpanelRef stack_var integer kplayerRef //determine which touch panel triggered the event touchpanelRef = get_last(KTouchPanels) //determine which player this panel is controlling kplayerRef = controlledKplayer[touchpanelRef] if(kplayerRef > 0) { send_level Kplayer[kplayerRef], 50, level.value } } LEVEL_EVENT[KTouchPanels, 8] { stack_var integer touchpanelRef stack_var integer kplayerRef //determine which touch panel triggered the event touchpanelRef = get_last(KTouchPanels) //determine which player this panel is controlling kplayerRef = controlledKplayer[touchpanelRef] if(kplayerRef > 0) send_level Kplayer[kplayerRef], 51, level.value } /******************************************************** * The following events should be copied/pasted for * * use by the different players, if needed. * ********************************************************/ /******************************************************** * Receive events from KPlayer for lighting cues * ********************************************************/ /*CHANNEL_EVENT[KPLAYER1, 1090] //lights movie { on: { // pulse[IR_LIGHTS,5] //instruct the lights to turn off } } CHANNEL_EVENT[KPLAYER1, 1091] //lights intermission CHANNEL_EVENT[KPLAYER1, 1092] //lights credits CHANNEL_EVENT[KPLAYER1, 1093] //lights non-movie { on: { // pulse[IR_LIGHTS,1] //instruct the lights to turn on } }*/ /******************************************************** * Receive events from KPlayer for masking information * ********************************************************/ /*LEVEL_EVENT[KPLAYER1, 11] //Screen masking data { switch (level.value) { case 0: {} //unknown masking - open wide case 1: {} //image is 1.33 (4x3) case 2: {} //image is 1.66 case 3: {} //image is 1.78 (16x9) case 4: {} //image is 1.85 case 5: {} //image is 2.35 } }*/ /*********************************************************** * Receive events from KPlayer for video mode information * ***********************************************************/ /* * Information about the video mode is returned via the levels * 20 (Composite & S-video), 21 (Component) and 22 (HDMI). * These values may be used to set a scaler or change inputs * on a projector that wants different video modes on different * inputs. */ //LEVEL_EVENT[KPLAYER1, 20] //Composite & Svideo mode //LEVEL_EVENT[KPLAYER1, 22] //HDMI vide mode /*LEVEL_EVENT[KPLAYER1, 21] //Component video mode { switch (level.value) { case 00: {} // no output case 01: {} // 480i60 4x3 NTSC case 02: {} // 480i60 16x9 case 03: {} // 480p60 4x3 case 04: {} // 480p60 16x9 case 05: {} // 576i50 4x3 PAL case 06: {} // 576i50 16x9 case 07: {} // 576p50 4x3 case 08: {} // 576p50 16x9 case 09: {} // 720p60 NTSC case 10: {} // 720p50 PAL case 11: {} // 1080i60 NTSC case 12: {} // 1080i50 PAL case 13: {} // 1080p60 NTSC case 14: {} // 1080p50 PAL } }*/ BUTTON_EVENT[KTouchPanels,2000] //select none BUTTON_EVENT[KTouchPanels,2001] //select KPLAYER1 BUTTON_EVENT[KTouchPanels,2002] //select KPLAYER2 BUTTON_EVENT[KTouchPanels,2003] //select KPLAYER3 BUTTON_EVENT[KTouchPanels,2004] //select KPLAYER4 BUTTON_EVENT[KTouchPanels,2005] //select KPLAYER5 BUTTON_EVENT[KTouchPanels,2006] //select KPLAYER6 BUTTON_EVENT[KTouchPanels,2007] //select KPLAYER7 BUTTON_EVENT[KTouchPanels,2008] //select KPLAYER8 { push: { stack_var integer touchpanelRef stack_var integer interfaceRef touchpanelRef = get_last(KTouchPanels) //determine the TP that generated this event interfaceRef = button.input.channel - 2000 //determine the Player Ref that is requested controlledKplayer[touchpanelRef] = interfaceRef //set the new player reference if(interfaceRef > 0) { pulse[Kplayer[interfaceRef], 79] //Clear the screen saver. send_command Kplayer[interfaceRef], 'REFRESH' //resend any strings to the touch panel } } } /******************************************************** * End of events to be copied/pasted per player * ********************************************************/ /******************************************************** ******************************************************** *** *** *** SAMPLE CODE *** *** *** ******************************************************** ********************************************************/ /******************************************************** * Change which TP controls which vdev at runtime. * ********************************************************/ /* * This code snippet assumes that you've got 5 different virtual * devices to control, and the buttons to pick which player to * control are channels 501 - 505. * * As configured above, these virtual devices may represent * individual Movie Players, Zones of a Music Player, or * even the same player controlled in different ways. Make sure * that the touch panel does an appropriate page flip to the * proper UI pages needed to control the selected KPLAYER. * (SATP if a zone is defined, OSD otherwise) */ /* BUTTON_EVENT[KTouchPanels,500] //select none BUTTON_EVENT[KTouchPanels,501] //select KPLAYER1 BUTTON_EVENT[KTouchPanels,502] //select KPLAYER2 BUTTON_EVENT[KTouchPanels,503] //select KPLAYER3 BUTTON_EVENT[KTouchPanels,504] //select KPLAYER4 BUTTON_EVENT[KTouchPanels,505] //select KPLAYER5 { push: { stack_var integer touchpanelRef stack_var integer interfaceRef touchpanelRef = get_last(KTouchPanels) //determine the TP that generated this event interfaceRef = button.input.channel - 500 //determine the Player Ref that is requested controlledKplayer[touchpanelRef] = interfaceRef //set the new player reference if(interfaceRef > 0) { pulse[Kplayer[interfaceRef], 79] //Clear the screen saver. send_command Kplayer[interfaceRef], 'REFRESH' //resend any strings to the touch panel } } } */ /******************************************************** * Sample keypad code * ********************************************************/ /* DEFINE_VARIABLE //define an array to specify the functions the keypad will perform devchan KeypadActions[] = { {KPLAYER1, 37}, //play-pause {KPLAYER1, 2}, //stop {KPLAYER1, 121}, //K preset 1 {KPLAYER1, 122}, //K preset 2 {KPLAYER1, 135}, //K next genre {KPLAYER1, 136}, //K previous genre {KPLAYER1, 4}, //K next track {KPLAYER1, 5} //K previous track // {MyTuner, VolUp} // {MyTuner, VolDown} // {MyTuner, Mute} // {MyTuner, Power_Toggle} }; //define an array to specify what will drive the keypad's feedback devchan KeypadFeedback[] = { {KPLAYER1, 1037}, //play-pause fb {KPLAYER1, 1002}, //stop fb {KPLAYER1, 1121}, //K preset 1 fb {KPLAYER1, 1122}, //K preset 2 fb {KPLAYER1, 135}, //K next genre - momentary {KPLAYER1, 136}, //K previous genre - momentary {KPLAYER1, 4}, //K next track - momentary {KPLAYER1, 5} //K previous track - momentary // {MyTuner, VolUp} // {MyTuner, VolDown} // {MyTuner, Mute_FB} // {MyTuner, Power_FB} }; DEFINE_EVENT BUTTON_EVENT[Sample_Keypad, 0] //trap all keypad button events { push: { stack_var integer channel channel = button.input.channel //determine which channel triggered this event if(channel <= length_array(KeypadActions)) //if the channel is in the array bounds { to[KeypadActions[chn]] //trigger that action } } } CHANNEL_EVENT[KeypadFeedback] //trap all feedback for the keypad { on: { stack_var integer channel channel = get_last(KeypadFeedback) //determine which position in the array triggered this event on[SAMPLE_KEYPAD, channel] //turn on that feedback } off: { stack_var integer channel channel = get_last(KeypadFeedback) //determine which position in the array triggered this event off[SAMPLE_KEYPAD,channel] //turn off that feedback } } */ /******************************************************** ******************************************************** *** *** *** end of *** *** SAMPLE CODE *** *** *** ******************************************************** ********************************************************/ /* * The following event is only necessary under very special circumstances. * Sometimes, button events and level events are communicated from a separate device_id * than the string events. For those situations, uncomment this code and the related code above. */ /* DATA_EVENT[keyboardDev] { string: { stack_var char kCharacter[10] stack_var integer keyboardRef stack_var integer kplayerRef //determine which touch panel triggered the event keyboardRef = get_last(keyboardDev) //determine which player this panel is controlling kplayerRef = controlledKplayerKeyboard[keyboardRef] //only proceed if the ref is valid if(kplayerRef > 0) { if(find_string(data.text,'KAL-', 1)) // when our custom header is found { remove_string(data.text, 'KAL-', 1) // remove the header kCharacter = "get_buffer_char(data.text)" // remove the keyboard character if(kCharacter[1] = '[') // if this is a fuzzy set (for instance [abc2] ) { //pull out the remaining characters kCharacter = "'[', remove_string(data.text,']',1)" } // send that character (or set) to the player send_command Kplayer[kplayerRef], "kCharacter" } if(find_string(data.text,'WAKE',1)) // when the TP wakes up { // clear the screen saver from the kplayer (if active) pulse [Kplayer[kplayerRef],79] } } } }*/ /******************************************************** * Handle feedback to the TP. * * note that the feedback for any given button is * * offset by 1000. * ********************************************************/ DEFINE_PROGRAM { local_var integer channel stack_var integer touchpanelRef stack_var integer kplayerRef channel++ //on each run through mainline, handle the next feedback channel if(channel > 142) channel = 1 for(touchpanelRef = 1; touchpanelRef <= length_array(KTouchPanels); touchpanelRef++) { //determine which player this panel is controlling kplayerRef = controlledKplayer[touchpanelRef] if(kplayerRef > 0) { [KTouchPanels[touchpanelRef], channel] = [Kplayer[kplayerRef], channel + 1000] } } }
Do_Push(KTouchpanels[panel],2000) // no player Do_Push(KTouchpanels[panel],2001) /// movie player 1 Do_Push(KTouchpanels[panel],2002) /// movie player 2 Do_Push(KTouchpanels[panel],2003) /// movie player 3 Do_Push(KTouchpanels[panel],2004) /// movie player 4 Do_Push(KTouchpanels[panel],2005) /// music server zone 1 Do_Push(KTouchpanels[panel],2006) /// music server zone 2 Do_Push(KTouchpanels[panel],2007) /// music server zone 3 Do_Push(KTouchpanels[panel],2008) /// music server zone 4
char m_UIIcons[3]
Line 36 (09:05:03):: Kaleidescape:Sending command "06.01/1/BROWSE:now_playing::1-6:SUGGEST:/76"
Line 37 (09:05:03):: Kaleidescape 5:Received push 911
Line 38 (09:05:03):: Kaleidescape 5:Received push 1086
Line 39 (09:05:03):: Kaleidescape:$0D$0A-- Processing response: 06.01$011$01012$02$04
Line 40 (09:05:03):: Kaleidescape:Error 12: Invalid parameter.
Line 41 (09:05:04):: Kaleidescape 5:Received release 81
Line 42 (09:05:04):: Kaleidescape 5:Received release 911
I implemented the new module the other day and so far no issues, but I haven't given it a real workout yet. Not sure what you mean about doing away with the arrays of popups though. You need them to drive the UI. I modified the module so that it only uses popups though.
e
Here ya go. I put the little wait in at the end because this is in a pretty big and chatty program. I don't mind if the fed back lags by a few ticks. You can take it out if you don't want it. I also moved the length_array statement up to startup. I just wanted to see the value in debug. YOu can put it back in the for loop if that bothers you.
The thing I noticed is that running the loop the previous way just slammed the processor. The output and input lights on the front of the master were pegged on. Also, there was a continual runtime error on line 1004. It was an 'array ref too large error."
did i do this corectly?
replaced this:
with this:
Thanks for the assistance
yes. (and some stuff to make this message long enough....)
The original code updates the status of one channel on all currently controlling UIs every pass through mainline. Your code updates all the channels on all currently controlling UIs every pass through mainline. Unless I'm mistaken, this seems like far more updating than the original code.
It's part of a short wait. the whhole routine only runs every 8 ticks.
Channel is left over from the origianal routine. I wondered about that as well. And since in the origianl it was a local var I was wondering how it would incremet. I left it as is and it compiles. I should probably change the name for the very reason that it is a keyword.
There is nothing wrong with doing it the other way. I just didn't wat to do a For Loop on every pass through mainlie for 20+ panels. I don't see anyting wrong with updating feedback every 6-8 ticks or so. The eye does't notice it that much. And the conditionals do have to be evaluated on eveyr pass whether anything chaged or not. The 2nd routine only does the 141 evals every 8 ticks.
Oh, I think what confused me is would have written it like this and not used a variable:
Wouldn't this work with no timeline code?
Your way is actually better in that it doesn't require mainline looking at the IF statment. The only reason I did what I did is that I actually start out with the flag at '1' and make is zero after 35 seconds after startup. That way it waits for the module to come online.
But, you know, I should just do it the way you describe. What's the differnece? So wht if for 30 seconds nothing happens.
Thanks!
e
I haven't compiled or tested that code but I can't see why it wouldn't work without using mainline. I will stick it in the module and see. I have noticed that kplayer transport button feedback is too slow to keep up with fast button presses so maybe it will help.
Keep us updated maybe you found away around some of the slow transport feedback
Good work and thanks for sharing
