Need information on IR emmiters
I need too basic informations:
1) Do IR emmiters differ somehow in functionality, or they all do the same? Do I have to worry about specific frequency range or something else like that when choosing the IR emmiter I'm going to use with a Netlinx Master?
2) If I connect two IR emmiters in parallel on an IR port, is there some way to amplify the signal?
I ask both questions because I have two different IR's on the same port, one of them having that red flashing led. When I pulse them, sometimes the devices answer and sometimes they don't. I thought it could be because they, together, need more current than the amount the master supplies. Am I too wrong?
Thanks in advance.
Thanks in advance.
Try connecting them in series. Whenever I have to stack IR emitters, I wire them in series and I have not had problems.
