MVP5200 Page control - TP vs Program - order of go
OK - I have a 5200 (5 actually) I have on one page a return to main menu button. I have this button issuing a hide-popups-on-page command using TP4. Then in the program, on that button press, I call a rotine that determines what page it shoudl go to, and what sub-pages should be shown on the new page.
here is the problem. I will navigate back to a page to find that the pop-ups on that page did not clear. And of corse all my new subpages are displayed on top of the pops that should have cleared upon exiting the page previously.
I would have assumed that the touchpanel would issue the internal commands to itself, before sending out the function code to the prcessor making sure that the pop-ups got cleared. That doesn't seem to be happening.
I am guessing that the page flip command is getting to the touchpanel at or around the same time as it is trying to clear the pop-ups on the page, and things are getting lost. The page flip always occurs though. And I always see the correct op-ups on the new page.
Anybody seen this before or worked around it?
  • ColzieColzie Posts: 470
    JohnMichnr wrote: »
    Handle all page flips in code. :D
    If it really is a timing issue, delay sending the command via code to make sure the TP "command" had time to do its job...
    Are you sending the "clear all popups on all pages" command, or are you sending the "clear all popups on a specific page" command?
  • JohnMichnrJohnMichnr Posts: 279
    I'm using the "hide popups on page xxx' command. SO it is referencing the page that I am leaving.
    I changed my code to include a @PPA-xxx command before I send the page flip so that should do it.
    I have not been back to the site to download it though.
    I just thought it was weird that the onboard commands wern't working.
