Pioneer Receiver
JohnMichnrJohnMichnr Junior MemberPosts: 276
Has any body been able to control the multiroom output of an older VSX receiver (vsx47/45) using the remote input connector on the rear of the unit? I've tried to go infrom the IR port on my 700 but am having no luck. I've tried CARON & CAROFF and setmode data.
Any ideas?
(the protocol for these units did not include the multiroom outputs - just the main zone)
  • KrobarKrobar Junior Member Posts: 32
    Is it the wired 3.5mm plug control ports you want to use?
    To use them you need the 3.5mm Xantech 794 interface, it lets you interface from a AMX IR port into a Pioneer SR port.
    You want CAROFF and SET MODE SERIAL (not DATA) for Pioneers.
    DHawthorne wrote: »
    Is this how you plugin to a Pioneer SR interface without the need for anything extra?
    Krobar wrote: »
    Typically, yes. That doesn't mean there aren't an exception here or there, but that's always how I do it, and haven't run into one of those exceptions (yet).
