5200 Connection Problems
If anyone is having problems getting a 5200 to connect to the wireless network, try resetting to factory defaults. I have had a couple in the past week that were very flaky and would constantly connect and disconnect from the wireless network. No matter what I changed, I could not get them to stay online (even changed to a different processor on a different wireless network). As a last resort, I tried the restore factory defaults button, rebooted and then configured the panels. Everything worked well. That means my first resort is now restore factory defaults.
Hope this helps,
Hope this helps,
I've had a couple problems.
1) panels seem to loose a lot of signal when they are docked. open the dock and the signal strenght goes up instantly. In the dock, reception is flaky.
2) When the TPs loose connect, you seem to have to go in and setup the wireless settings again. we use WEP 64. It seems to set itself to wEP128. It does this without fail. (which is, well.... a fail.)
Also anyone ever experience a 5200, or any touchpanel for that matter, go completely blank but still hear button presses only to have the touchpanel come alive about 15 seconds later? I also experienced this in our show home the other night. And of course both events occurred when I was showing potential clients how easy this system is to use!
It owuld be nice if my APs were fed POE and I was able to remotely cycle power but no such luck. Maybe in the next system design.
--John
I have this problem on multiple sites, but its more like once a week. Not to mention all the panels are new-ish due to the battery recall.
I have a similar problem with the panels (5200?s) loosing connection with the AP and when I try to connect to the AP via Ethernet, the AP is no ware to be found. The only thing to restore comm. is to recycle power. I call tech support and they told me to check the firmware, which I did, and is running the latest. The other thing they were suggesting is the possibility that the AP could go offline, every time there were power intermittences.
If anyone has some solution for this I?ll appreciate. The client is getting a little ??off.
I know for a fact in most of my 5200 wi-fi problems are due to the AP cuz I'm unable to see the AP with my laptop and when I go to the AP the activity lights are solid, no blinking.
