Battery Discharge Technote
I got the technote notice about http://www.amx.com/techsupport/technote.asp?id=912?fromPage=%2ftechsupport%2ftechnote.asp%3fid%3d912 and it left me wondering: When or why would I want to do this? Last I talked with tech support, I was told that full power cycles are bad and the battery would last longer if it is kept on the charger more often than not and that multiple short charge cycles are better for battery life than draining the battery completely.
Has anyone had a need to do the complete battery discharge?
Unfortunately I don't think we can tell customers to leave the panels out until they're dead so that next time they want to use it they can then place it in the charger and wait an hour before doing what it was which made them go to use the panel in the first place..
Just read the technote and all I can say is why?. It would have been nice to include a reason why someone would want/need to do this.
From what I understand, what you said about batteries is true of the older rechargeable batteries, but the new ones are supposed to be different, at least according to tech support. If you read the stuff about the batteries in an iPod, they talk about things being different from the older rechargeable batteries and that partial charges are not bad like they used to be. There are a set number of charge cycles, but it does not count partial charges the same as a full charge. The biggest problems are with extreme heat and cold. Extreme heat can destroy the batteries ability to hold a charge. Extreme cold will lower the battery output, but it should return to normal as the battery returns to normal operating temps. (Should being the key word
The tech note is the proceedure to discharge before returning to AMX
http://campaign.constantcontact.com/render?v=001x-UkwuaPPNhRZcHFtOK_do0HihUe8AhffMCvNKwb1SsAR6Og0TMpmoz8pElDMHMtWMvt9xz4bJD74ll7K0MTZgBQGOAChVqndZF0ZHtFMFuwHakRBIiI0_C3YehYnXRcuj58aoTLx40%3D
If that test discovers an issue with your battery, a warning pop-up will appear every five seconds until you send the panel back to AMX for repair.
You may want to have an extra panel on hand if you are updating firmware on a currently working system.
Reverting to the prior firmware only turns the 5200i into a non-communicating brick.
