Finding total value of an array of numbers..
2»
    It might work, but if you remember to do that, you might as well just put a set_length_array command in the define_start section :)
  • HedbergHedberg Posts: 671
    Spire_Jeff wrote: »
    What's "define_start"?
    Define_start is the section that is run once when a processor first comes online. If you prefer, you could write a function that does the set_length_array and then does the find_string command. This might also be better if you are assigning values to the array using strings and there is a chance that the processor will set the length shorter than the max length.
    Spire_Jeff wrote: »
    I haven't found the need to use set_length_array at all. The array length never changes so I guess I don't understand the need.
    I think the problem may stem from my use of a stack_var in this situation. I have not tried it with a volatile variable that is initialized at definition, but that should probably fix the problem.
    a_riot42 wrote: »
    I'm not sure I do either. For some reason I was convinced that there was a problem with initializing character arrays that were populated with zeroes, but today I can't find a problem.
    There are two different values for char arrays. There is a length_array and a max_length_array. If you have a variable declared as char sMyString[100], but do not assign anything to it, the length_array = 0 and the max_length_array = 100. If you the do something like sMyString = "'123456789'", the length_array = 9 and max_length_array =100. find_string in the test I ran was using length_array, not max_length_array for it's parsing. As I recall, if you do something like sMyString[50] = '1', the length_array does not change. If I have a minute, I will see if I can write a few tests to clarify all of this. I believe it might also be different for stack_vars vs global variables.
    Ok, I ran some tests and here are the results:
    As you can see, you have to do a set_length_array() for find_string to function properly. The only reason it is functioning properly on the persistent variable is because I have run this a couple times and restarted the processor.
    P.S.
    for display purposes, on the entire array contents, I replaced all of the 0 values with @s. This allows you to see that stack_var arrays are not initialized and could throw false positives if you are not careful.
    On global char arrays:
    Line      1 (16:47:39.609)::  ******Global PERSISTENT char array:
    Line      2 (16:47:39.609)::  $$$   Before changes
    Line      3 (16:47:39.609)::  #  length_array:25     length_string:25
    Line      4 (16:47:39.609)::  #  max_length_array:100    max_length_string:100
    Line      5 (16:47:39.609)::  #  Contents of incoming array:
    Line      6 (16:47:39.609)::  #  String Assigned
    Line      7 (16:47:39.609)::  FIND_STRING is reporting: 20
    Line      8 (16:47:39.609)::  #
    Line      9 (16:47:39.609)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line     10 (16:47:39.609)::  #
    Line     11 (16:47:39.609)::  #  Contents of entire array:
    Line     12 (16:47:39.625)::  #  String Assigned@@@@1@@@@@@@@@@@@@@T@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line     13 (16:47:39.625)::  FIND_STRING is reporting: 20
    Line     14 (16:47:39.625)::  #
    Line     15 (16:47:39.625)::  -------------------------------------------
    Line     16 (16:47:39.625)::  $$$   After insert into indexed position
    Line     17 (16:47:39.625)::  #  length_array:25     length_string:25
    Line     18 (16:47:39.625)::  #  max_length_array:100    max_length_string:100
    Line     19 (16:47:39.625)::  #  Contents of incoming array:
    Line     20 (16:47:39.625)::  #  String Assigned
    Line     21 (16:47:39.625)::  FIND_STRING is reporting: 20
    Line     22 (16:47:39.625)::  #
    Line     23 (16:47:39.625)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line     24 (16:47:39.625)::  #
    Line     25 (16:47:39.625)::  #  Contents of entire array:
    Line     26 (16:47:39.625)::  #  String Assigned@@@@1@@@@@@@@@@@@@@T@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line     27 (16:47:39.625)::  FIND_STRING is reporting: 20
    Line     28 (16:47:39.625)::  #
    Line     29 (16:47:39.625)::  -------------------------------------------
    Line     30 (16:47:39.625)::  $$$   After assigning a string
    Line     31 (16:47:39.625)::  #  length_array:15     length_string:15
    Line     32 (16:47:39.640)::  #  max_length_array:100    max_length_string:100
    Line     33 (16:47:39.640)::  #  Contents of incoming array:
    Line     34 (16:47:39.640)::  #  String Assigned
    Line     35 (16:47:39.640)::  FIND_STRING is reporting: 0
    Line     36 (16:47:39.640)::  #
    Line     37 (16:47:39.640)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line     38 (16:47:39.640)::  #
    Line     39 (16:47:39.640)::  #  Contents of entire array:
    Line     40 (16:47:39.640)::  #  String Assigned@@@@1@@@@@@@@@@@@@@T@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line     41 (16:47:39.640)::  FIND_STRING is reporting: 20
    Line     42 (16:47:39.640)::  #
    Line     43 (16:47:39.640)::  -------------------------------------------
    Line     44 (16:47:39.640)::  $$$   After setting array length
    Line     45 (16:47:39.640)::  #  length_array:25     length_string:25
    Line     46 (16:47:39.656)::  #  max_length_array:100    max_length_string:100
    Line     47 (16:47:39.656)::  #  Contents of incoming array:
    Line     48 (16:47:39.656)::  #  String Assigned
    Line     49 (16:47:39.656)::  FIND_STRING is reporting: 20
    Line     50 (16:47:39.656)::  #
    Line     51 (16:47:39.656)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line     52 (16:47:39.656)::  #
    Line     53 (16:47:39.656)::  #  Contents of entire array:
    Line     54 (16:47:39.656)::  #  String Assigned@@@@1@@@@@@@@@@@@@@T@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line     55 (16:47:39.656)::  FIND_STRING is reporting: 20
    Line     56 (16:47:39.656)::  #
    Line     57 (16:47:39.656)::  ##########################################
    on Non-Volatile char arrays:
    Line     58 (16:47:39.656)::  ******Global NON_VOLATILE char array:
    Line     59 (16:47:39.656)::  $$$   Before changes
    Line     60 (16:47:39.656)::  #  length_array:0     length_string:0
    Line     61 (16:47:39.656)::  #  max_length_array:100    max_length_string:100
    Line     62 (16:47:39.656)::  #  Contents of incoming array:
    Line     63 (16:47:39.671)::  #
    Line     64 (16:47:39.671)::  FIND_STRING is reporting: 0
    Line     65 (16:47:39.671)::  #
    Line     66 (16:47:39.671)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line     67 (16:47:39.671)::  #
    Line     68 (16:47:39.671)::  #  Contents of entire array:
    Line     69 (16:47:39.671)::  #  @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line     70 (16:47:39.671)::  FIND_STRING is reporting: 0
    Line     71 (16:47:39.671)::  #
    Line     72 (16:47:39.671)::  -------------------------------------------
    Line     73 (16:47:39.671)::  $$$   After insert into indexed position
    Line     74 (16:47:39.671)::  #  length_array:0     length_string:0
    Line     75 (16:47:39.671)::  #  max_length_array:100    max_length_string:100
    Line     76 (16:47:39.671)::  #  Contents of incoming array:
    Line     77 (16:47:39.687)::  #
    Line     78 (16:47:39.687)::  FIND_STRING is reporting: 0
    Line     79 (16:47:39.687)::  #
    Line     80 (16:47:39.687)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line     81 (16:47:39.687)::  #
    Line     82 (16:47:39.687)::  #  Contents of entire array:
    Line     83 (16:47:39.687)::  #  @@@@@@@@@@@@@@@@@@@1@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line     84 (16:47:39.687)::  FIND_STRING is reporting: 20
    Line     85 (16:47:39.687)::  #
    Line     86 (16:47:39.687)::  -------------------------------------------
    Line     87 (16:47:39.687)::  $$$   After assigning a string
    Line     88 (16:47:39.687)::  #  length_array:15     length_string:15
    Line     89 (16:47:39.687)::  #  max_length_array:100    max_length_string:100
    Line     90 (16:47:39.687)::  #  Contents of incoming array:
    Line     91 (16:47:39.687)::  #  String Assigned
    Line     92 (16:47:39.703)::  FIND_STRING is reporting: 0
    Line     93 (16:47:39.703)::  #
    Line     94 (16:47:39.703)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line     95 (16:47:39.703)::  #
    Line     96 (16:47:39.703)::  #  Contents of entire array:
    Line     97 (16:47:39.703)::  #  String Assigned@@@@1@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line     98 (16:47:39.703)::  FIND_STRING is reporting: 20
    Line     99 (16:47:39.703)::  #
    Line    100 (16:47:39.703)::  -------------------------------------------
    Line    101 (16:47:39.703)::  $$$   After setting array length
    Line    102 (16:47:39.703)::  #  length_array:25     length_string:25
    Line    103 (16:47:39.703)::  #  max_length_array:100    max_length_string:100
    Line    104 (16:47:39.703)::  #  Contents of incoming array:
    Line    105 (16:47:39.703)::  #  String Assigned
    Line    106 (16:47:39.718)::  FIND_STRING is reporting: 20
    Line    107 (16:47:39.718)::  #
    Line    108 (16:47:39.718)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line    109 (16:47:39.718)::  #
    Line    110 (16:47:39.718)::  #  Contents of entire array:
    Line    111 (16:47:39.718)::  #  String Assigned@@@@1@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line    112 (16:47:39.718)::  FIND_STRING is reporting: 20
    Line    113 (16:47:39.718)::  #
    Line    114 (16:47:39.718)::  ##########################################
    on Global Volatile char arrays:
    Line    115 (16:47:39.718)::  ******Global VOLATILE char array:
    Line    116 (16:47:39.718)::  $$$   Before changes
    Line    117 (16:47:39.718)::  #  length_array:0     length_string:0
    Line    118 (16:47:39.718)::  #  max_length_array:100    max_length_string:100
    Line    119 (16:47:39.718)::  #  Contents of incoming array:
    Line    120 (16:47:39.718)::  #
    Line    121 (16:47:39.718)::  FIND_STRING is reporting: 0
    Line    122 (16:47:39.734)::  #
    Line    123 (16:47:39.734)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line    124 (16:47:39.734)::  #
    Line    125 (16:47:39.734)::  #  Contents of entire array:
    Line    126 (16:47:39.734)::  #  @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line    127 (16:47:39.734)::  FIND_STRING is reporting: 0
    Line    128 (16:47:39.734)::  #
    Line    129 (16:47:39.734)::  -------------------------------------------
    Line    130 (16:47:39.734)::  $$$   After insert into indexed position
    Line    131 (16:47:39.734)::  #  length_array:0     length_string:0
    Line    132 (16:47:39.734)::  #  max_length_array:100    max_length_string:100
    Line    133 (16:47:39.734)::  #  Contents of incoming array:
    Line    134 (16:47:39.734)::  #
    Line    135 (16:47:39.734)::  FIND_STRING is reporting: 0
    Line    136 (16:47:39.734)::  #
    Line    137 (16:47:39.750)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line    138 (16:47:39.750)::  #
    Line    139 (16:47:39.750)::  #  Contents of entire array:
    Line    140 (16:47:39.750)::  #  @@@@@@@@@@@@@@@@@@@1@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line    141 (16:47:39.750)::  FIND_STRING is reporting: 20
    Line    142 (16:47:39.750)::  #
    Line    143 (16:47:39.750)::  -------------------------------------------
    Line    144 (16:47:39.750)::  $$$   After assigning a string
    Line    145 (16:47:39.750)::  #  length_array:15     length_string:15
    Line    146 (16:47:39.750)::  #  max_length_array:100    max_length_string:100
    Line    147 (16:47:39.750)::  #  Contents of incoming array:
    Line    148 (16:47:39.750)::  #  String Assigned
    Line    149 (16:47:39.750)::  FIND_STRING is reporting: 0
    Line    150 (16:47:39.765)::  #
    Line    151 (16:47:39.765)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line    152 (16:47:39.765)::  #
    Line    153 (16:47:39.765)::  #  Contents of entire array:
    Line    154 (16:47:39.765)::  #  String Assigned@@@@1@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line    155 (16:47:39.765)::  FIND_STRING is reporting: 20
    Line    156 (16:47:39.765)::  #
    Line    157 (16:47:39.765)::  -------------------------------------------
    Line    158 (16:47:39.765)::  $$$   After setting array length
    Line    159 (16:47:39.765)::  #  length_array:25     length_string:25
    Line    160 (16:47:39.765)::  #  max_length_array:100    max_length_string:100
    Line    161 (16:47:39.765)::  #  Contents of incoming array:
    Line    162 (16:47:39.765)::  #  String Assigned
    Line    163 (16:47:39.765)::  FIND_STRING is reporting: 20
    Line    164 (16:47:39.765)::  #
    Line    165 (16:47:39.765)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line    166 (16:47:39.765)::  #
    Line    167 (16:47:39.781)::  #  Contents of entire array:
    Line    168 (16:47:39.781)::  #  String Assigned@@@@1@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line    169 (16:47:39.781)::  FIND_STRING is reporting: 20
    Line    170 (16:47:39.781)::  #
    Line    171 (16:47:39.781)::  ##########################################
    on Local_vars:
    Line    172 (16:47:39.781)::  ******LOCAL_VAR char array:
    Line    173 (16:47:39.781)::  $$$   Before changes
    Line    174 (16:47:39.781)::  #  length_array:0     length_string:0
    Line    175 (16:47:39.781)::  #  max_length_array:100    max_length_string:100
    Line    176 (16:47:39.781)::  #  Contents of incoming array:
    Line    177 (16:47:39.781)::  #
    Line    178 (16:47:39.781)::  FIND_STRING is reporting: 0
    Line    179 (16:47:39.781)::  #
    Line    180 (16:47:39.781)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line    181 (16:47:39.781)::  #
    Line    182 (16:47:39.796)::  #  Contents of entire array:
    Line    183 (16:47:39.796)::  #  @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line    184 (16:47:39.796)::  FIND_STRING is reporting: 0
    Line    185 (16:47:39.796)::  #
    Line    186 (16:47:39.796)::  -------------------------------------------
    Line    187 (16:47:39.796)::  $$$   After insert into indexed position
    Line    188 (16:47:39.796)::  #  length_array:0     length_string:0
    Line    189 (16:47:39.796)::  #  max_length_array:100    max_length_string:100
    Line    190 (16:47:39.796)::  #  Contents of incoming array:
    Line    191 (16:47:39.796)::  #
    Line    192 (16:47:39.796)::  FIND_STRING is reporting: 0
    Line    193 (16:47:39.796)::  #
    Line    194 (16:47:39.796)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line    195 (16:47:39.796)::  #
    Line    196 (16:47:39.796)::  #  Contents of entire array:
    Line    197 (16:47:39.812)::  #  @@@@@@@@@@@@@@@@@@@1@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line    198 (16:47:39.812)::  FIND_STRING is reporting: 20
    Line    199 (16:47:39.812)::  #
    Line    200 (16:47:39.812)::  -------------------------------------------
    Line    201 (16:47:39.812)::  $$$   After assigning a string
    Line    202 (16:47:39.812)::  #  length_array:15     length_string:15
    Line    203 (16:47:39.812)::  #  max_length_array:100    max_length_string:100
    Line    204 (16:47:39.812)::  #  Contents of incoming array:
    Line    205 (16:47:39.812)::  #  String Assigned
    Line    206 (16:47:39.812)::  FIND_STRING is reporting: 0
    Line    207 (16:47:39.812)::  #
    Line    208 (16:47:39.812)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line    209 (16:47:39.812)::  #
    Line    210 (16:47:39.812)::  #  Contents of entire array:
    Line    211 (16:47:39.812)::  #  String Assigned@@@@1@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line    212 (16:47:39.828)::  FIND_STRING is reporting: 20
    Line    213 (16:47:39.828)::  #
    Line    214 (16:47:39.828)::  -------------------------------------------
    Line    215 (16:47:39.828)::  $$$   After setting array length
    Line    216 (16:47:39.828)::  #  length_array:25     length_string:25
    Line    217 (16:47:39.828)::  #  max_length_array:100    max_length_string:100
    Line    218 (16:47:39.828)::  #  Contents of incoming array:
    Line    219 (16:47:39.828)::  #  String Assigned
    Line    220 (16:47:39.828)::  FIND_STRING is reporting: 20
    Line    221 (16:47:39.828)::  #
    Line    222 (16:47:39.828)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line    223 (16:47:39.828)::  #
    Line    224 (16:47:39.828)::  #  Contents of entire array:
    Line    225 (16:47:39.828)::  #  String Assigned@@@@1@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
    Line    226 (16:47:39.843)::  FIND_STRING is reporting: 20
    Line    227 (16:47:39.843)::  #
    Line    228 (16:47:39.843)::  ##########################################
    on Stack_var char arrays:
    Line    229 (16:47:39.843)::  ******STACK_VAR char array:
    Line    230 (16:47:39.843)::  $$$   Before changes
    Line    231 (16:47:39.843)::  #  length_array:0     length_string:0
    Line    232 (16:47:39.843)::  #  max_length_array:100    max_length_string:100
    Line    233 (16:47:39.843)::  #  Contents of incoming array:
    Line    234 (16:47:39.843)::  #
    Line    235 (16:47:39.843)::  FIND_STRING is reporting: 0
    Line    236 (16:47:39.843)::  #
    Line    237 (16:47:39.843)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line    238 (16:47:39.843)::  #
    Line    239 (16:47:39.843)::  #  Contents of entire array:
    Line    240 (16:47:39.843)::  #  @$05$022$01$01$0A$07$EF$10@$0A$05$80@Friday, Jan 10, 2031@0.0.315@NSX Application@AMX Corp.@$02$04$0A$D37$04@@@g@@@g@@@g@@@g@@@g@@@g
    Line    241 (16:47:39.843)::  FIND_STRING is reporting: 28
    Line    242 (16:47:39.859)::  #
    Line    243 (16:47:39.859)::  -------------------------------------------
    Line    244 (16:47:39.859)::  $$$   After insert into indexed position
    Line    245 (16:47:39.859)::  #  length_array:0     length_string:0
    Line    246 (16:47:39.859)::  #  max_length_array:100    max_length_string:100
    Line    247 (16:47:39.859)::  #  Contents of incoming array:
    Line    248 (16:47:39.859)::  #
    Line    249 (16:47:39.859)::  FIND_STRING is reporting: 0
    Line    250 (16:47:39.859)::  #
    Line    251 (16:47:39.859)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line    252 (16:47:39.859)::  #
    Line    253 (16:47:39.859)::  #  Contents of entire array:
    Line    254 (16:47:39.859)::  #  @$05$022$01$01$0A$07$EF$10@$0A$05$80@Frid1y, Jan 10, 2031@0.0.315@NSX Application@AMX Corp.@$02$04$0A$D37$04@@@g@@@g@@@g@@@g@@@g@@@g
    Line    255 (16:47:39.859)::  FIND_STRING is reporting: 20
    Line    256 (16:47:39.859)::  #
    Line    257 (16:47:39.875)::  -------------------------------------------
    Line    258 (16:47:39.875)::  $$$   After assigning a string
    Line    259 (16:47:39.875)::  #  length_array:15     length_string:15
    Line    260 (16:47:39.875)::  #  max_length_array:100    max_length_string:100
    Line    261 (16:47:39.875)::  #  Contents of incoming array:
    Line    262 (16:47:39.875)::  #  String Assigned
    Line    263 (16:47:39.875)::  FIND_STRING is reporting: 0
    Line    264 (16:47:39.875)::  #
    Line    265 (16:47:39.875)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line    266 (16:47:39.875)::  #
    Line    267 (16:47:39.875)::  #  Contents of entire array:
    Line    268 (16:47:39.875)::  #  String AssignedFrid1y, Jan 10, 2031@0.0.315@NSX Application@AMX Corp.@$02$04$0A$D37$04@@@g@@@g@@@g@@@g@@@g@@@g
    Line    269 (16:47:39.875)::  FIND_STRING is reporting: 20
    Line    270 (16:47:39.875)::  #
    Line    271 (16:47:39.875)::  -------------------------------------------
    Line    272 (16:47:39.890)::  $$$   After setting array length
    Line    273 (16:47:39.890)::  #  length_array:25     length_string:25
    Line    274 (16:47:39.890)::  #  max_length_array:100    max_length_string:100
    Line    275 (16:47:39.890)::  #  Contents of incoming array:
    Line    276 (16:47:39.890)::  #  String AssignedFrid1y, Ja
    Line    277 (16:47:39.890)::  FIND_STRING is reporting: 20
    Line    278 (16:47:39.890)::  #
    Line    279 (16:47:39.890)::  - - - - - - - - - - - - - - - - - - - - - - - - -
    Line    280 (16:47:39.890)::  #
    Line    281 (16:47:39.890)::  #  Contents of entire array:
    Line    282 (16:47:39.890)::  #  String AssignedFrid1y, Jan 10, 2031@0.0.315@NSX Application@AMX Corp.@$02$04$0A$D37$04@@@g@@@g@@@g@@@g@@@g@@@g
    Line    283 (16:47:39.890)::  FIND_STRING is reporting: 20
    Line    284 (16:47:39.890)::  #
    Line    285 (16:47:39.890)::  ##########################################
