Extron IPL T PCS4i
I am having trouble getting an Extron IPL T PCS4i to work with my code. This is the first time I have done any controls over IP and I am sure that is the main cause of my problems. Could someone look at the code below and tell me what I am doing wrong?
PROGRAM_NAME='Levels'
#IF_NOT_DEFINED dvPWR_Cntrl_Rack
dvPWR_Cntrl_Rack = 0:2:0
#END_IF
#IF_NOT_DEFINED dvPWR_Cntrl_WS
dvPWR_Cntrl_WS = 0:3:0
#END_IF
#IF_NOT_DEFINED dvPWR_Cntrl_Table
dvPWR_Cntrl_Table = 0:4:0
#END_IF
DEFINE_CONSTANT
NON_VOLATILE INTEGER nIPPort = 23
IP_ADDRESS_STRUCT ipPWR_CNTRL_Rack
IP_ADDRESS_STRUCT ipPWR_CNTRL_WS
IP_ADDRESS_STRUCT ipPWR_CNTRL_Table
NON_VOLATILE INTEGER nLVL_BTNS[] =
300, //
301, //
302, //
303, //
304, //
305, //lvl 1
306, //lvl 2
307 //lvl 3
ipPWR_CNTRL_Rack.IPADDRESS = '192.168.1.122'
ipPWR_CNTRL_Rack.SUBNETMASK = '255.255.255.0'
ipPWR_CNTRL_Table.IPADDRESS = '192.168.1.123'
ipPWR_CNTRL_Table.SUBNETMASK= '255.255.255.0'
ipPWR_CNTRL_WS.IPADDRESS = '192.168.1.124'
ipPWR_CNTRL_WS.SUBNETMASK = '255.255.255.0'
IP_CLIENT_OPEN(dvPWR_Cntrl_Rack.Port,ipPWR_CNTRL_Rack.IPAddress,nIPPort,IP_TCP)
IP_CLIENT_OPEN(dvPWR_Cntrl_Table.Port,ipPWR_CNTRL_Table.IPAddress,nIPPort,IP_TCP)
IP_CLIENT_OPEN(dvPWR_Cntrl_WS.Port,ipPWR_CNTRL_WS.IPAddress,nIPPort,IP_TCP)
BUTTON_EVENT [dvTP, nLVL_BTNS]
SWITCH(GET_LAST(nLVL_BTNS))
CASE 6: //Set level to 1
seclevel = 1
nChange_Flag = 1
CASE 7: //Set level to 2
seclevel = 2
nChange_Flag = 1
CASE 8: //Set level to 3
level = 3
nChange_Flag = 1
DEFAULT:
level = 0
DEFINE_PROGRAM
IF (nChange_Flag)
SWITCH (level)
CASE 1:
SEND_STRING dvPWR_Cntrl_Rack, "$1B, '1*1PC', $0D"
SEND_STRING dvPWR_Cntrl_Rack, "$1B, '2*0PC', $0D"
SEND_STRING dvPWR_Cntrl_Rack, "$1B, '3*0PC', $0D"
SEND_STRING dvPWR_Cntrl_Rack, "$1B, '4*0PC', $0D"
SEND_STRING dvPWR_Cntrl_WS, "$1B, '1*1PC', $0D"
SEND_STRING dvPWR_Cntrl_WS, "$1B, '2*0PC', $0D"
SEND_STRING dvPWR_Cntrl_WS, "$1B, '3*0PC', $0D"
SEND_STRING dvPWR_Cntrl_WS, "$1B, '4*0PC', $0D"
SEND_STRING dvPWR_Cntrl_Table, "$1B, '1*1PC', $0D"
SEND_STRING dvPWR_Cntrl_Table, "$1B, '2*0PC', $0D"
SEND_STRING dvPWR_Cntrl_Table, "$1B, '3*0PC', $0D"
SEND_STRING dvPWR_Cntrl_Table, "$1B, '4*0PC', $0D"
CASE 2:
SEND_STRING dvPWR_Cntrl_Rack, "$1B, '2*1PC', $0D"
SEND_STRING dvPWR_Cntrl_WS, "$1B, '2*1PC', $0D"
SEND_STRING dvPWR_Cntrl_Table, "$1B, '2*1PC', $0D"
CASE 3:
SEND_STRING dvPWR_Cntrl_Rack, "$1B, '3*1PC', $0D"
SEND_STRING dvPWR_Cntrl_WS, "$1B, '3*1PC', $0D"
SEND_STRING dvPWR_Cntrl_Table, "$1B, '3*1PC', $0D"
DEFAULT:
SEND_STRING dvPWR_Cntrl_Rack, "$1B, '1*0PC', $0D"
SEND_STRING dvPWR_Cntrl_WS, "$1B, '1*0PC', $0D"
SEND_STRING dvPWR_Cntrl_Table, "$1B, '1*0PC', $0D"
nChange_Flag = 0
I can tell you that all of the extron equpiment will close the telnet port after 20seconds of no activaity.
also you should have a DATA_EVENT for each device so you can monitor each device for when it should fall offline then you can reconnect it.
DEFINE_CONSTANT
CONNECTED = 11
integer nTry2Connect
DEFINE_FUNCTION CloseConnection()
IP_CLIENT_CLOSE(devDevice.PORT);
IP_CLIENT_OPEN(devDevice.PORT,192.168.0.0,23,tcp);
DATA_EVENT[devDevice]
ONLINE:
ON[devDevice,CONNECTED]
CANCEL_WAIT 'make connection'
OFFLINE:
OFF[devDevice,CONNECTED]
WAIT 20 'make connection'
IF(![devDevice,CONNECTED])
ONERROR:
nCONNECTION_ERROR = Data.Number
IF(nCONNECTION_ERROR = 0)
ELSE
IF([devDevice,CONNECTED])
CloseConnection()
WAIT 30 'make connection'
EstablishConnection()
IF(nCONNECTION_ERROR <> 0 && nCONNECTION_ERROR <> 9)
