Netlinx Studio - Network ports?
Hi folks,
Which ports does Netlinx Studio use for communications?
I can't talk to my NI-3000 from Netlinx Studio under Vista unless I disable Windows Firewall. I've unblocked the application and I've unblocked port 1319. Firewall says it's blocking a "Network Discovery NB-Datagram Out"; so I unblocked UDP port 138 as well. I'm still not having any luck.
Any advice would be appreciated.
1319 is the port you seek.
Definitely if you are remote, but it's never caused me a problem on a local network.
Also keep in mind that the programming port and telnet can be changed, so if 1319 doesn't work, you may have to go in RS-232 and fix it. I believe (not certain, haven't done it in while) they refer to it as the ICSNet port.
