Closest c language derrivative?
I'm going to be picking up a c reference manual to hep me with my programming, buy what version of c is netlinx closest to? Object c, c+, etc?
If you have no experience with a programming language and want to learn general programming language concepts, try Java instead of C. You'll not only become familiar with how programming languages work, you'll also acquire skills which are directly applicable to AMX programming if you decide, eventually, to jump off the Duet programming bridge. Also Netlinx is probably as close to Java as it is to C++. Sun has a pretty intense set of Java tutorials which you can download for free.
On the other hand, Java won't really help you either with NetLinx itself. It will be useful if you plan on writing Duet modules, but you will need to know NetLinx as well; you can't do an entire project in Java. You can, however, do a project entirely without Java, so make NetLinx your first priority.
This has me in stitches. What are you trying to insinuate?
Nothing, really. Java and Duet, I am very sure, place powerful resources at the AMX programmer's disposal. However, it's a non-trivial undertaking. At one time, I wanted to do it, but I found out better.
