SRC file size
From the category of "I shouldn't be in this situation but I am"...
I am having to go back to a project to do a minor tweak but as luck would have it, during a flurry of last minute updates, I'm not certain of the most recent version of the code. Since everything is running well, I don't want to screw it up by going backwards a rev or 2!
However, when I transfer the SRC out of the master and compare it to the various SRC files on the job disk, none of file size match.
I would expect that what I put into the master (SRC) would be the same as what I have on the job disc.
My only thought is does anything happen to the SRC file when it is transferred into the master - a header maybe, date stamp, token gremlin? (this is an NI-4100)
Thanks!
Thanks!
Follow on question - any suggestion on the best way to determine (match) the running program in the master with the various versions on the project disc? (obviously I can't 'un-zip' the SRC file - he says with a frown)
Cheers!
Thanks for the tip - it sent me in the right direction.
Note to self - make sure you do a better job labelling files as they are created!
Cheers!
I just change .src to .zip then unzip it.
For finding out what is actually running on your master, if you may have transferred without source open up your possible versions in NS studio and launch debug. If the compiled tkn you've got sitting on your computer is different to whats running on your master you'll get a little dialogue popping up informing you of this.
If you are sure that you transferred with source as well then just download the src and extract it, it will have everything bar your modules and IR files.
--John
