String manipulation on command
Dear Friends,
I would want to parse the commands coming to a virtual variable using string manipulation. Is it possible.
This is what I 'm trying to do. It is goin into while loop, but string manipulation doesnt seem to be taking place. Is it because its a command string manipulation wont happen,.. Looking forward to you guys, Thankyou.
data_event[vdvMatrixAudio1]
command:
STACK_VAR CHAR sTempVar[50]
STACK_VAR FLOAT fPresetVal
WHILE(FIND_STRING(TunerBuffer,'XCH',1))
send_string 0:1:2,"'Test Radio',$0d"
sTempVar=REMOVE_STRING(TunerBuffer,'XCH',1)
// fPresetVal = atof(TunerBuffer)
send_command dvTP_Drawing_AMFM,"'^TXT-9,0,',sTempVar"
command:
In your program though, you're not parsing the command, your parsing the variable TunerBuffer which is getting filled somewhere else anytime data is received in the command buffer for vdvMatrixAudio1.
Usually you would have a line like this under the command: event
And somewhere else you would have:
I would open up Debug and see what the value of TunerBuffer is when the parsing routine is called, and when it's done. If you're entering the while loop, then you're seeing XCH in TunerBuffer, but the other thing is you're setting sTempVar to everything leading up to and including 'XCH'. If TunerBuffer = 'XCH88.1' as an example, sTempVar is going to equal XCH. Your send command will send back "XCH" to the button 9 on your touchpanel. If TunerBuffer = '88.1XCH' then sTempVar would be 88.1XCH.
--John
Anytime data is received in the command buffer for vdvMatrixAudio1, you're parsing TunerBuffer. Your variable TunerBuffer is getting filled somewhere else.
--John
