Not able to firmware update a NXI-ME260
in AMX Hardware
Hi there,
using the latest firmware v2.31.139 to upgrade one NXI-ME260 and of course folowing the TechNote at http://www.amx.com/techsupport/techNote.asp?id=613 I couln't get to load the fourth file. I always get an error ("Transfer aborted - unsupported file type") after the third file is loaded. I have tried rebooting in between, loading over a serial cable, over TCP/IP, etc, as to no avail. Any clue? Loading with Netlinx Studio.
I have upgraded two other NXI-ME260 and they did just fine. Had to load the FW files a couple of times but in the end they got to load the fourth file and have now the latest firmware. The last NXI-ME260 just don't want to get to the forth file of the firmware upgrade.
Any clue what I may try out?
Only the ME260/64 (201064) can be upgraded to Duet.
To what firmware do you want to upgrade?
Just disassembled the ME260 from the NXI in order to a look at its serial. It starts with 201060. There is a 16MB CF card in there. The ME260 is FG2010-60 REV A4.
I am trying the put firmware v2.31.139 which according to AMX is for both the original ME260 and the ME260/64.
The card you have is not possible to be upgraded to Duet firmware (v3.xx).
I erased the CF card by entering CLEAN DISK. It got erased (some files removed). DISK FREE shows me:
The disk has 10092544 bytes of free space.
Tried to load the firmware again without luck. I erased the program from the master and loaded and empty one. Tried to load the firmware without luck again. I can only load the first three parts of it. Then it waits a couple of seconds and then showing me "File 4 of 4" still the same error "Transfer aborted - Unsupported file type". I am of course rebooting inbetween.
I am kind of clueless.. Any more hints which I can try out? Below the output of SHOW SYSTEM:
Local devices for system #39 (This System)
Device (ID)Model (ID)Mfg FWID Version
00000 (00256)NXC-ME260 (00001)AMX Corp. 00256 v2.10.85
(PID=0:OID=0) Serial='201060o3822484',0,0
Physical Address=NeuronID 00C055040001
(00256)vxWorks Image (00001) 00257 v2.30.138
(PID=0:OID=1) Serial=N/A
(00256)BootROM (00001) 00258 v2.30.135
(PID=0:OID=2) Serial=N/A
(00256)AXLink I/F uContr(00001) 00270 v1.03.14
(PID=0:OID=3) Serial=0000000000000000
32004 (00257)NXI Download (00001)AMX Corp. 00260 v1.00.22
(PID=0:OID=0) Serial=0,0,0,0,0,0,0,0,0,0,0,0,
Physical Address=NeuronID 00C055050201
(00257)NXI/NXI-1000 Boot(00001) 00261 v1.00.01
(PID=0:OID=1) Serial=0,0,0,0,0,0,0,0,0,0,0,0,
Now SHOW SYSTEM shows me the following:
00000 (00256)NXC-ME260 (00001)AMX Corp. 00256 v2.31.139
33000 (65534)Virtual (00001)AMX Corp. 00256 v2.31.139
Physical Address=None
I just compared both CF cards and noticed that the "user" directory is empty on the card where the update wasn't possible. It contais some .asp and the like (remaining after CLEAN DISK). Mirrored the "working" card to this one and now I am able to update the firmware on the ME260 again and again.
Thanks for all the help!
edit:
After imaging the CF card I had to set the system number again in Studio (as it reverted to default 1).
