AutoShutdown Timeline
Yes i'm new to this and no i have not done the programmer 2 course. I'm just bored and are trying to improve what i'm giving the customers. Doing this i'm trying to make a countdown that will turn of the system 20 seconds after pushing exit.
I wont be able to test this before monday and was hoping anybody here could tell if i'm on to something or totaly off on making this work.
PROGRAM_NAME='cShutdown'
DEFINE_CONSTANT
TL1 = 1
LONG Timearray[20]=
1000,
2000,
3000,
4000,
5000,
6000,
7000,
8000,
9000,
10000,
11000,
12000,
13000,
14000,
15000,
16000,
17000,
18000,
19000,
20000
BUTTON_EVENT[dvTP,39] //IF dvTP,39 EXIT IS PUSHED, EXIT PAGE IS SHOWN AND THE COUNTDOWN TIMELINE BEGINS.
TIMELINE_CREATE(TL1,Timearray,20,TIMELINE_ABSOLUTE,TIMELINE_ONCE)
BUTTON_EVENT[dvTP,40] //CANCEL THE TIMELINE AND RETURN TO MAIN PAGE
PanelPage ('Main')
TIMELINE_KILL(TL1)
BUTTON_EVENT[dvTP,210] //OFF BUTTON IS PUSHED BEFORE THE TIMELINE IS DONE. THE SYSTEM IS SHUT DOWN AND THE TIMELINE IS CANCLED.
TIMELINE_KILL(TL1)
TIMELINE_EVENT[TL1]
SEND_COMMAND dvTP,"'TEXT1-30,0',ITOA(20 - TIMELINE.SEQUENCE)" // AT THE END OF THE TIMELINE OFF BUTTON IS PUSHED
IF(TIMELINE.SEQUENCE = 20)
DO_PUSH (dvTP,210)
DEFINE_PROGRAM
IF (TIME = '18:00:00') // TIDSBASERT AUTOSHUTDOWN
DO_PUSH(dvTP,39)
send_command dvTP, "'PAGE-Exit 2'"
SEND_COMMAND dvTP,"'WAKE'"
  • My 2 cents... (partially, must be completed to get a compiler run)
    LONG lOneSecondTick[] = { 1000 } // second tick
    INTEGER nMySecondCount // manually count passes
    // start timer
    TIMELINE_CREATE(TL1,lOneSecondTick,1,TIMELINE_RELATIVE,TIMELINE_REPEAT)
    nMySecondCount = 0
    TIMELINE_EVENT[TL1]
    IF(TIMELINE.REPETITION = 20) // 20x repeated
    TIMELINE_KILL(TL1)
    nMySecondCount = 0
    ELSE
    SEND_COMMAND dvTP,"'TEXT1-30,0',ITOA(20 - TIMELINE.REPETITION)"
    nMySecondCount++
    Contains a variations - based on TIMELINE.REPETITION (how much repeats done, so 1st run thru Timeline it is 0 (zero)), or on a manually counted variable nMySecondCount.
  • Thank you, this made it work. my last problem now is the counter, it wont show the counting digits in the touchpanel.
    Anyone know whats wrong?
    Forget it, found a missing comma.
  • New error, something in this code is making my controller go bananas after i shut down the system. anyone that see whats causing it???
    DEFINE_CONSTANT
    TL1 = 1
    nMySecondCount = 0
    TIMELINE_KILL(TL1)
    nMySecondCount = 0
    TIMELINE_KILL(TL1)
    nMySecondCount = 0
    PanelPage ('Main2')
    TIMELINE_EVENT[TL1]
    TIMELINE_KILL(TL1)
    nMySecondCount = 0
    DO_PUSH(dvTP,210)
    PanelPage ('Main2')
    ELSE
    SEND_COMMAND dvTP,"'^TXT-300,0,',ITOA(20 - TIMELINE.REPETITION)"
    nMySecondCount++
    (****************************************************TIDSBESTEMT AUTOSHUTDOWN*********************************************************************************************************************)
    DEFINE_PROGRAM
    DO_PUSH(dvTP,39)
    PanelPage ('Exit2')
