NI-700 Device ID 5001 will not stick
Joe Hebert
in AMX Hardware
I?ve got some NI-700s that won?t keep a 5001 Device ID. I go into Device Addressing and change the device ID to 5001 and it shows up in the online tree as 5001 but as soon as the NI-700 reboots the Device ID reverts to a dynamic address of 32002 (NS2 is 32001.)
Has anyone seen this problem before? The NI-700s have the latest firmware. Could it be a bad batteries? I?ve got 3 out of 25 NI-700s acting this way.
Any help is appreciated.
Thanks.
Thanks.
I have seen this behavior. Have you tried addressing it to a non-default address like 5002?
I believe uploading firmware again fixed it.
I'll report back with the results.
Thanks for the input.
Three out of 25 brand new out of the box NI-700s won't keep the 5001 Device ID.
They revert back to a dynamic address every time after a reboot.
Oh well...
I've got one word for you my friend...
'RMA'
Is the system number the only thing that gets lost?
You don't have any code running that changes the system number, do you?
My bad, I was just dealing with some multi-processor system problems and I had system numbers on my mind
I?m wondering how the Device ID is stored and if a bad or missing battery might be the problem. If I was smart I would have checked the time on the NI to see if that sticks. If I was smart...
That's where I was heading. I was wondering if the nonvolatile memory was just not holding on. So, was it a battery issue?
Now, the EEPROM has to be programmed correctly by our manufacturer when we ship. We recently discovered that a small set of EEPROMs were not being set correctly and therefore would not retain their device numbers. In fact, they essentially are read only. We thought we caught the whole batch and returned them to the factory but apparently a few must have slipped through. I am guessing that is the problem you are having. If you upgrade to 1.20.7 and the problem is not resolved then that would be an indication to me that you need to return those units back to AMX for replacements.
Sorry for the inconvenience.
