TP4 Fonts
Joe Hebert
Scenario:
I create a TP4 file and use Font A that?s installed on my PC. I then give that TP4 file to someone to transfer to a touch panel but that someone does not have Font A on his PC.
Question:
Does Font A get embedded into the TP4 file and therefore transfer as desired to the touch panel or does Font A get replaced with some sort of default font since the transferor didn?t have Font A installed on his PC?
Thanks.
Question:
Thanks.
Perhaps I can answer this question with a issue I've had migrating from Windoze XP to Windoze 7.
I noticed after installing all my AMX software that when I opened an existing TP file a few of the fonts turned out to be 'missing.' However, they were indeed there. In fact I had to transfer the missing fonts from my original XP Pro fonts folder to get it to work. Each time I'd put the older font into the new Win7 folder, it warned me that it already existed (probabl named the same)
So, it's obvious that the fonts are not embedded in the file. That would be a good feature request. Kind of a 'pack-n-save feature that allows you to embed all the parts-n-peices for the TP.
But the bottom line is, you have to have the font on your computer, and if you switch computers, it will break your panel design until you install it ... and the automatic substitution can get very ugly, I might add. Furthermore, there is a glitch in the process ... if TPD4 runs into a font that isn't installed, any subsequent custom font loaded will also fail and get substituted, even if you do have it installed. If I see that message when loading a file, I cancel out immediately, find the4 font and install it, then load the file again.
I like the idea of a pack-n-go feature but it makes sense why copyright issues would get in the way. One thing I just checked though is that if you generate a programmer's report (Panel -> Generate programmer's report) it lists the fonts in use on the panel. Makes it a little easier to figure out which fonts to send with the TP file just in case.
--John
Technically, even installing a paid for font on a touch panel can be a copyright violation, unless your license specifically allows it. Allowing someone to be able to download the panel file and install it for free on their own computer seems pretty clear to me as a potential issue.
I second this...
Anybody having the answer? I'm struggling with a job we're taking over and have to fix all UI with a bunch of Fonts that get replaced with "Courrier New", the worst possible font...
Thanks!
I'd even settle for a, "Hey, I doni't have this font, can you choose one for me to replace it with?" window instead of the "Hey I don't have this font, sucks to be you 'cause I'm changing them to what ever the heck I want to."
For those worried about font copyright issues, Google offers free fonts for the Web
