Google PowerMeter / Enphase Energy
rhurson
I have a client that is looking to display the info from Google PowerMeter on there touchpanel.
http://www.google.org/powermeter/
He is also looking to display info from his Solar system using this http://www.enphaseenergy.com/products/products/enlighten.cfm
http://www.theenergydetective.com/ted-5000-overview.html
Has anyone worked with these? How about another power monitoring device that works well with AMX?
We do this kind of thing with several clients. It's all the rage now.
My question has always been, "what do you do with this information?" It never seems to go beyond that.
At my personal residnece I actually moniotr the power use and it plays into my energy management system on my AMX contorller. I've been playing with it for about 2 years now and have drastically reduced my light bill. (sometimes by half.)
I'm not all 'Green' or anything. I do like saving money, however.
Yes, it is real time. And yes, you can watch the numbers drop.
I've done single breaker version and I don't know if this information is that useful in that there can beseveral loads on one breaker.
There are some that will moniotr individual devices. That too is a bit of a bugbear in that it is possible to know when something is on or off.
What I've been trying to do is make some semi-intelligent choices of what should be on and off at any given time and so forth. It has proven to be pretty challenging. I find that hte best success is in HVAC use, Lighting in unoccupied rooms and so forth.
I really want to come up with some way to disable an electric water heater when not being used and jazz it up just proor to when the owner comes home from work.
I haven't done web scraping before. Sounds like it's just like parsing out data. Do you have some example code you would be willing to share? He is going to be using the TED.
How time consuming is it? I don't really need to do anything with the data other than just give him a nice display of the info on his 10" panel.
http://www.ccontrolsys.com/products/pulse_output.html
Output pulse frequency follows demand. The math is easily calculated in Netlinx.
