latest release of TPDesign 4
 informel
informel
                    I did not take any course last year and lost my certification.
Is it possible that the version available for ACE and others are different?
Latest version available for TPD4 is 2.11
but I have a manual that is for version 2.5 and I beleive the lastest version is 2.9
Reason I am asking is that if I want to modify the automatically generated touch panel .TP4 file I need TPDesign4 2.6 or higher.
That's what's on the website as far as I can tell.
Eric
if you follow this link http://www.amx.com/va/faq.asp#SystemDiagrams
you will see the following:
How do I add custom touch panel buttons?
You cannot add custom touch panel buttons. However, you can modify the automatically generated touch panel .TP4 file using TPDesign4 2.6 or higher.
Yves Laurin
Les Systemes Umad
ylaurin@umad.ca
Oh.
Never mind.
OK, I feel very stupid this morning.
In my head I was seeing 2.06 (I am use to double didit verdion number).
Thanks, I will hide in a corner for a while
meh...
don't sweat it. We all have our senior moments, even when we're young.
If you were seeing 2.06 in your head then it would be logical that you thought 2.11 > 2.06..
But I reckon you were reading it as 2.60 rather than 2.06
It shouldn?t be read as a decimal point either way.
It?s not point 11 or point 6 or point 06, it?s just 11 and 6.
The dot is there as a separator between major and minor revision.
How?s that for beating the crap out of a dead horse?
