How does this loop get screwed up?
vegastechvegastech Junior MemberPosts: 369
I have this for loop programmed into a button press:
LOCAL_VAR integer nChannel
FOR (nChannel=0;nChannel<4;nChannel++)
but it seems that when I press the button, the variable starts at 0, and then jumps to 4. Shouldn't it only increment by 1 after each press?
    vegastech wrote: »
    Your for loop isn't going to stop after one time through and wait for you to hit the button again. Its going to execute the loop until nChannel is not less than 4 every time you hit the button. What were you expecting to happen?
  • Jorde_VJorde_V UX Scientist Posts: 393
    It continues for as long as nChannel is less than 4, hence it will not stop before it reaches 4. What is it that you want to do?
    here is some code to accomplish this:
    button_event[dvTp,nBtn]{
      push:{
         local_var integer nChannel;
         nChannel = (nChannel+1)%4; //nChannel will cycle 0,1,2,3,0,1,2,3,0...
    I think this should work.
  • vegastechvegastech Junior Member Posts: 369
    I want it to increment by 1 after each pass, and then stop until I press another button, until I have pressed 3 buttons. I have a variable array that I am trying to fill 3 digits with. My goal here is to press 3 numerics, and have a numeric load the 1st, then 2nd, and finally the 3rd spot, to then send out a 3 digit channel.
    Try this:
    define_variable
    volatile integer nChannel = 1;
      push:{
         nChannel++;
         //Store button number data accordingly.
      release:{
        if(nChannel >= 3){
          nChannel = 1;
          //send data to device.
    vegastech wrote: »
    Yeah, a FOR loop doesn't work that way in Netlinx. Once started it will run on its own without stopping. There's not really a 'Next' command as you might see in other programming languages.
    first time i used a FOR loop in Netlinx i expected to "see" it count in the debug window.
    But instead i just saw 0 -> 255 ;)
    What about the Break command? Wouldn't that typically stop the loop after the first run?
  • John GonzalesJohn Gonzales Junior Member Posts: 609
    vegastech wrote: »
    It'll break the FOR loop when it's encountered but it won't restart it.
    --John
  • jjamesjjames Just another dude Posts: 2,904
    Spire_Jeff wrote: »
    define_variable
      push:{
         nChannel++;
      release:{
        if(nChannel >= 3){
          nChannel = 1;
    This is where a button_var (a variable only specific to a button event; broader scope than a local or stack, but smaller than a global) would come very handy. Unfortunately, in a circumstance like this we "waste" / unnecessarily use a global variable.
    Anyway - I'd vouch for code like this.
