Sony VPL-EX4 pwr issue
I have a Sony VPL-EX4 projector and a Sony VPL-EX3 projector in the same room.
It appears that they use the same protocol except the EX3 uses 9600 N 8 1 while the EX4 uses 9600 E 8 1.
The problem I am having is that I can not reliably turn the EX4 on. Everything else seems fine.
The really odd thing is that I can sometimes turn it on. I thought it was something along the lines of the power on issue like the Sharp TVs. But I have looked all over the menus and I see nothing regarding the EnergyStar.
Any ideas?
Any ideas?
Have you tried polling it continuously?
ie.
do_while (<CurrentPowerState> <> <RequestedPowerState>) { send_string <RequestedPowerStateCommand> send_string <PowerStateRequest> }I did notice that if the PWR button flashed after sending the first power command then the second command would turn the projector on.
I guess the good thing is that the client only has one and it isn't used much.
Other than that I can only suggest that you try hooking the projector directly to the NetLinx via a short length of cable to see if the cable is a factor.
So far it appears that it works the first time every day. So if the customer only uses it once a day they will not know that a problem exists.
The dealer has a call into Sony to see what they can do.
