MVP5200i - Windows 7*64
Denis
Hi
I try to do a firmware update in a MVP5200i (battery upgrade kit) with Windows 7 64 bits but Windows dosen't found USB driver for this panel.
By the same time, if I look setting for virtual master trough USB in netlinx studio, it's 10.0.0.2 ans in the panel is 12.0.0.2 is it normal?
Laptop, windows 7 *32 upgraded from vista
Desktop, Windows 7 * 64 new install
Have you set the USBLAN connection to a static IP?
Simon
Okay . . . kinda makes sense. But if in theory, no USBLAN is needed - WHERE exactly do we need to change the "Windows" IP?
[RANT]Forget that though, I'm a bit ticked right now that I may have to transfer through WiFi and hope to god it doesn't freak. If I have to stay connected to the panel for 15-20 minutes as the newest firmware mentions . . . I can't download my code & continue testing for an hour since I have to update three of these. I've also got Windows 7 and of course it won't connect. The thing that gets me is if I call TS, I'm sure they'll say Win7 is not officially supported, and instead an OS that's 5 years old is. Can we get with the times please? Do I have to wait another 5 years before Win7 is supported?
What a way to waste my time since the 5200 goes into deep sleep and poof - goes offline, and cannot get back online. (FW upgrade desperately needed.) My time is limited, and this is potentially going to burn an hour? Not to mention possibly brick the 5200 in case wireless hiccups. Nice. Very nice.[/RANT]
jjames wrote: Now I just had to do this recently but of course I don't remember how long the firware transfer actually took but I usually wipe all the user pages first to make sure I have enough memory available for the new frirmware. Resending the entire TP file from scratch is what kills me and 15-20 minutes for that is no joke and I had to do 5 when I did the last battery exchange. 3 hours round trip and probably 4 hours onsite dealing with this BS made for an full day of non billable labor.
hi i had that problem once, i couldn't upload a design to a panel through usb the problem is when you install the amx usb lan driver, by default windows 7 block the driver because is not signed, so you just should to disable the driver signature of windows 7, there are many ways to do that just google it
have a nice day!!
