variable text string
                    i'm trying to get the numbers on a keypad to display in a variable text button (for a audio conference system...to see the number as it is being dialed).
the touch panel is a VPN-CP.
i could create a keypad button, but that pops open a keypad and closes it after pushing "enter", which i don't want to do. it also does not have the star and pound symbol, which may or may not be needed.
so, i created my own keypad, sending the numbers to the Vortex EF2211.
how do i create a string, add the next character entered, have the full number displayed (as number buttons are being pushed)?
thanks.
thanks.
BUTTON_EVENT[vdvAllVortexTP,nPhoneNbrBtn] { PUSH: { local_var INTEGER nBtnIdx nBtnIdx = GET_LAST(nPhoneNbrBtn) IF(!flagPhoneStatus) //CHECK TO SEE IF THE PHONE IS ON HOOK { IF(nBtnIdx = 12) { sNumberToDial = "sNumberToDial,35" } ELSE IF(nBtnIdx = 11) { sNumberToDial = "sNumberToDial,42" } ELSE { sNumberToDial = "sNumberToDial,ITOA(nBtnIdx-1)" } } ELSE IF (flagPhoneStatus) { IF(nBtnIdx = 12) { CLEAR_BUFFER sNumberToDial sNumberToDial = "sNumberToDial,35" SEND_STRING vdvAllVortexTRS232,"sIDString,sTelcoFnct[9],sNumberToDial,13" CLEAR_BUFFER sNumberToDial } ELSE IF(nBtnIdx = 11) { CLEAR_BUFFER sNumberToDial sNumberToDial = "sNumberToDial,42" SEND_STRING vdvAllVortexTRS232,"sIDString,sTelcoFnct[9],sNumberToDial,13" CLEAR_BUFFER sNumberToDial } ELSE { CLEAR_BUFFER sNumberToDial sNumberToDial = "sNumberToDial,ITOA(nBtnIdx-1)" SEND_STRING vdvAllVortexTRS232,"sIDString,sTelcoFnct[9],sNumberToDial,13" CLEAR_BUFFER sNumberToDial } } SEND_COMMAND vdvAllVortexTP, "'@TXT',2,sNumberToDial" } }thanks so much for that guidance.
here is what i ended up with...
(would love to get feedback on this as well.)
BUTTON_EVENT[vdvTP,102] // dial
SEND_STRING dvTel_Interface,"'S03PHONE1',13"
SEND_COMMAND vdvTP,"'PPON-phone_text_box'"
BUTTON_EVENT[vdvTP,103] // hang-up
SEND_STRING dvTel_Interface,"'S03PHONE0',13"
SEND_COMMAND vdvTP,"'PPOF-phone_text_box'"
SEND_COMMAND vdvTP, "'@TXT',4,''"
BUTTON_EVENT[AUD_CNF_CNTRL]
LOCAL_VAR INTEGER nBtnIdx
nBtnIdx = GET_LAST(AUD_CNF_CNTRL)
IF(nBtnIdx = 11)
sNumberToDial = "sNumberToDial,'*'"
SEND_STRING dvTel_Interface,"'S03DIAL*',13"
ELSE IF(nBtnIdx = 12)
sNumberToDial = "sNumberToDial,'#'"
SEND_STRING dvTel_Interface,"'S03DIAL#',13"
ELSE
SEND_STRING dvTel_Interface,"'S03DIAL',ITOA(nBtnIdx-1),13"
SEND_COMMAND vdvTP, "'@TXT',4,sNumberToDial"
...sry, not sure how to format it to appear in the post the way yours did.
any hints on how to have dashes or spaces show up?
as in, if the first digit is 1, follow it with a space; after three digits, follow with a space; etc.
thanks.
