Cable Boxes with IR Receive Jack
Greetings,
I have a bunch of Pace brand cable boxes with "IR Receive" 3.5 mm jacks. Does anyone know a way to interface them directly with AMX IR?
Thanks.
Thanks.
I wish every IR device had these. I hate Hate HATE!!! ir flashers.
One thing though...
I have ran into one instance where I needed to add a resistor to it. The voltage was a bit too high for the device and it was having issues. knocking it down a bit solved the problem.
Otherwise, it's always worked flawlessly.
Besides carrier on and off, some of those connections require serial mode (Pioneer does that). So you have a few combinations of carrier on/off and IR/serial mode to try before you can completely give up. It's possible it's not active too, or even just broken.
Doesn't that figure. Typical receivers use 12v, which would have been a dead giveaway. It won't shock me if the signal is proprietary if they have their own box.
