Home AMX User Forum AMXForums Archive Threads AMX Hardware Endeleo Media Distribution
feedback help
I'm needing help with this code that doesn't display feedback correctly. I have 8 inputs and 24 outputs, I also have a 'all' button to allow the user to send a single input to all monitors at once. I can select any input and send it to any number of outputs and the feedback works as it should. What doesn't work is when I select an input and send it to 'all'.
DEFINE_CALL 'ManualSwitch'
if (nSwitchIn < 4)
SEND_STRING DisplayDevice[nSwitchOut],"'kb 00 07',$0D"
Else if ((nSwitchIn > 3)&&(nSwitchIn < 8))
SEND_STRING DisplayDevice[nSwitchOut],"'kb 00 04',$0D"
Else if (nSwitchIn = 8)
SEND_STRING DisplayDevice[nSwitchOut],"'kb 00 03',$0D"
BUTTON_EVENT[dvTouch,102] // Send currently selected input to all outputs
local_var integer j
SEND_COMMAND dvEndeleo1,"'CLALLI',ITOA(nSwitchIn),'O0'" // SEND AUDIO AND VIDEO SWITCH COMMAND
SEND_COMMAND dvEndeleo2,"'CLALLI',ITOA(nSwitchIn),'O0'" // SEND AUDIO AND VIDEO SWITCH COMMAND
SEND_COMMAND dvEndeleo3,"'CLALLI',ITOA(nSwitchIn),'O0'" // SEND AUDIO AND VIDEO SWITCH COMMAND
for(j = 1; j < 25; j++)
nSwitchOut = j
nManualFeedback[nSwitchIn][nSwitchOut] = nManualFeedback[nSwitchIn][j]
call 'ManualSwitch'
[dvTouch,1] = nSwitchIn = 1
[dvTouch,2] = nSwitchIn = 2
[dvTouch,3] = nSwitchIn = 3
[dvTouch,4] = nSwitchIn = 4
[dvTouch,5] = nSwitchIn = 5
[dvTouch,6] = nSwitchIn = 6
[dvTouch,7] = nSwitchIn = 7
[dvTouch,8] = nSwitchIn = 8
[dvTouch,20] = nManualFeedback[nSwitchIn][1]
[dvTouch,21] = nManualFeedback[nSwitchIn][2]
[dvTouch,22] = nManualFeedback[nSwitchIn][3]
[dvTouch,23] = nManualFeedback[nSwitchIn][4]
[dvTouch,24] = nManualFeedback[nSwitchIn][5]
[dvTouch,25] = nManualFeedback[nSwitchIn][6]
[dvTouch,26] = nManualFeedback[nSwitchIn][7]
[dvTouch,27] = nManualFeedback[nSwitchIn][8]
[dvTouch,28] = nManualFeedback[nSwitchIn][9]
[dvTouch,29] = nManualFeedback[nSwitchIn][10]
[dvTouch,30] = nManualFeedback[nSwitchIn][11]
[dvTouch,31] = nManualFeedback[nSwitchIn][12]
[dvTouch,32] = nManualFeedback[nSwitchIn][13]
[dvTouch,33] = nManualFeedback[nSwitchIn][14]
[dvTouch,34] = nManualFeedback[nSwitchIn][15]
[dvTouch,35] = nManualFeedback[nSwitchIn][16]
[dvTouch,36] = nManualFeedback[nSwitchIn][17]
[dvTouch,37] = nManualFeedback[nSwitchIn][18]
[dvTouch,38] = nManualFeedback[nSwitchIn][19]
[dvTouch,39] = nManualFeedback[nSwitchIn][20]
[dvTouch,40] = nManualFeedback[nSwitchIn][21]
[dvTouch,41] = nManualFeedback[nSwitchIn][22]
[dvTouch,42] = nManualFeedback[nSwitchIn][23]
[dvTouch,43] = nManualFeedback[nSwitchIn][24]
Any insight will be very appreciated.
-Tim
    If you use the code brackets, it's WAY easier to look at the code.
        if (nSwitchIn < 4)
    	    local_var integer j
    		    nSwitchOut = j
    		    call 'ManualSwitch'
    With that said, the problem looks to me like it's in your loop. You're not really changing the nManualFeedback array. Try this:
    		    nManualFeedback[nSwitchIn][j] = 1
    		    call 'ManualSwitch'
    -John
    Actually, you're probably relying on nSwitchOut to get updated for the call, so you may need to do this:
    		    nSwitchOut = j
    		    nManualFeedback[nSwitchIn][nSwitchOut] = 1
    		    call 'ManualSwitch'
    -John
    Edit: Oops, wasn't paying attention, you show the call in your code snippet. You'll need to use the correction in this post so that nSwitchOut get's updated for each pass of the loop.
    tkroegertkroeger Posts: 13
    My apologies for the poor structure. I wasn't aware of the code brackets.
    Thanks for the correction. I'll make that change and see how it works. I appreciate the quick response.
    Initial testing yielded better results, but far from perfect.
    Now when I press Input 1 and send to 'all' the feedback works. When I press Input 2, the output feedback shows none selected, which is correct. If I proceed to select 'all' the feedback changes to show Input 2 is now selected to all, which is correct. Now, when I press Input 1 again, it shows to still be going to 'all'.
    Long story short:
    I have 8 Inputs and 24 Outputs, matrix-ed. I just want my feedback to indicate which Input is routed to which Output. Seems simple enough. Sigh.
    Once the flags are turned on, you're not updating them when the input is disconnected. You need to set the variable nManualFeedback[nSwitchIn][nSwitchOut] back to 0 when you've turned off the input or route a different input to a specific output. You can do it during the switch, or you can trap for status and parse the feedback to update the nManualFeedback variable.
    --John
