Dynamic images from ACTi 3311...
Camera ACTi3311. Panel 5200i
If I define the Camera as dinamic image in Resource Manager:
Protocol: HTTP
Host: 192.168.1.15
Path: cgi-bin/cmd
File: encoder?SNAPSHOT
User: Admin
Password: 123456
Refresh Rate: 1
then all Ok.
If I send command to Panel:
"'^RAF-Camera,%P0%UAdmin%S123456%H192.168.1.15%Fencoder?SNAPSHOT%Acgi-bin/cmd%R1'"
"'^BBR-1700,1,Camera'"
picture from the camera does not appear.
Protocol: HTTP
Host: 192.168.1.15
Path: cgi-bin/cmd
User: Admin
Password: 123456
Refresh Rate: 1
then all Ok.
"'^RAF-Camera,%P0min%S123456%H192.168.1.15%Fencoder?SNAPSHOT%Acgi-bin/cmd/%R1'"
Space insert forum
http://www.amxforums.com/showthread.php?t=6346
A few things to note:
- If the resource already exists, RAF does not change it. In this case, use RMF and also note that you may have to hide then show the button to get around the RMF issue (this has been fixed and will be in the next release)
- Try flipping away from the image, then flipping back
- If the camera is sending Motion JPEG, set your refresh rate to 0
Good luck & let me know how it goes.
> a dynamic image to display at all with that build - did you get that issue resolved?
File: encoder?SNAPSHOT working on a version of 2.66.21 and 2.60.64
File: system?GET_STREAM working only on a version 2.60.64
If still not working, could you telnet to the panel, turn all logs on ("msg on all"), go to the page that contains the problem URL, save to a file & send?
