NI-3100 I/O LED
in AMX Hardware
Hey Guys,
I've got a NI-3100 that seems to have a problem, the first 4 led of the I/O is permanetly ON, I've tryed to upgrade the firmware again to the last version (it was already the last version) but the situation is the same.
Anyone have got Ideas
Thanks a Lot
Kman88
Thanks a Lot
Kman88
A short between I/O 1 and gnd coused the first four LED light on??? I think that i not undertand.
I think that if the I/O chip is broken all the first 4 IO or the second four IO suks because of the I/O Chip is conntected to 4 I/O and in the 3100 we have 2 I/O Chip
Try sending this command from Control a Device and see if the input 1 LED turns off:
Device = 5001
Port = 17
System = whatever your system number is
Command to send:
SET INPUT 1 LOW
If the Input 1 LED turns off then rinse and repeat for inputs 2-4.
HTH
I think is an hardware problem
:-( :-( :-( I suspect that is what happened to...
