Master/Slave question I believe - How To
First off I'm new to programming and this question may be basic but here goes. I have a NI-3000 that I currently have controlling DVD,TV,Squeezebox, Cablebox, video server and Matrix (component). I am very proud to have gotten my 1st program and TP's working with much help from various people and forums. I recently got a hold of an Axcent3 controller that I would like to put in the Loft that will control the TV, DVD, VCR from that location using the IR ports but would also like to control the NI-3000 to switch the Matrix and control the Video server and Squeezebox from the loft location. I know this is possible but how exactly to do it I'm not sure. My initial guess was to have my wired TP in the loft go to Axlink on Axcent3 and also have an axlink connection to the NI-3000. In that case would the programming for the local stuff be done on the Axcent3 and the other stuff on the Netlinx? I am lost, HELP!
Thanks in advance,
P.S. I already have a component Balun run to the loft from the Matrix Switch Downstairs.
Thanks in advance,
Edit -
I have since put the Axcent3 in Slave Mode using the example (setting port number to begin with 30, 30-35 RS232, 36 - Relays, 37-42 IR, 43 I/O) I have a flashing Green light on the Axcent3 I have set the IR Port in the program as 5001:37:0 (to start) and tried to send IR to Port via TCP/IP and Serial and I keep getting "Transfer Aborted - Time out occurred on the receiving device". I know you said it is difficult to transfer the IR Codes but I'm wondering if I did something wrong?
Thanks Again,
It doesn't add much time to do it this way and it can save aggravation. And, you know what they say, "money is aggravation." Or something.
Kevin D.
1 - Did a 'Set Device Base Number to 30' (Put Axcent3 into slave mode)
2 - Located on Netlinx Studio in Device Tree IR Numbers (37-42)
3 - IR Edit - sent known working IR's to device 37:1:0 (green progress bar to DONE)
4 - Tried through both IREdit (Actuate) and Netlinx Studio (control device) and nothing.
5 - On a Pulse I get the correct IR LED lit up.
Not sure if the IR didn't take (tried multiple times different locations 38, 39, 40, same result)
6 - Put back to Master and sent the IR's to Multiple ports via serial as 'Hedberg' suggested.
7 - Tried a couple different IR Emitters
When it's all said and done I'm sure it will be some minor thing I missed or didn't do, I just can't seem to figure it out. I was so pumped when I saw those Green IR Transfer lights going, I thought that was it for sure.
Any Suggestions?
Any other suggestions?
