AMX MVP-8400 Boot problems
                                  in AMX Hardware
                    Is there any one who can help me to fix my MVP? i started my MVP and tried to update the firmware. The firmware procedure was suddenly interrupted without any reason. After that the touchpanel can't boot correctly. There is no AMX logo and no setup page. I orderd a new flashcard, installed in the touchpanel but no luck.
Any help will be appriciated.
Thank you,
Ayser
Thank you,
Ayser
Ordered a new flash card? As in, one from AMX with the firmware loaded? If you just bought a generic flash, it's not going to work. If you got it from AMX loaded for that panel, you have a hardware issue, and it isn't likely to have anything to do with your firmware update ... since a new, loaded card replaces the firmware. I would say that panel is going to have to go back to AMX.
