TPD4 Button disabled state
I'm working with a general button, If it is set as Disabled (General Properties select 'Yes' from the drop-down) can I assign to it a diferent image? and if yes, How?
I've to change the button type to have this?
ND
  • Jorde_VJorde_V Posts: 393
    ND
    Should be possible with the following command
    send_command panel,"'^BMP-<vt addr range>,<button states range>,<name of bitmap/picture>'"
    send_command panel,"'^BMP-500,0,silly.png'"
    if you want to do multiple buttons you can by doing xxx.xxx so 500.515 would be button 500 to button 515.
    0 = all state
    1 = off state
    2 = on state
    This can also be found in the PI.
    Not positive if this also works if the button is disabled, but I imagine it should.
  • Hi all,
    thanks for your answers
    Hi all,
    I'm not schizophrenic or anything ;)
