Axcent3Pro
                    Hi There, When downloading an IR file to the controller via NetlinxStudio the download stops after sending about 60kb. Does anyone know why or how to get the complete file to download?
Chad
It is actually 60 bytes and then it stops
I didn't recall ever changing to AXCENT as the type when loading Axcent3's as IO slaves here, so I pulled one out, and see the ports in NetLinx Studio when looking at the NetLinx... IREDIT here is set to NETLINX, and the upload is quick and complete. Tried several ports, no issues, as I recall from previous efforts. Therefore I don't think your issue is specifically Netlinx/Axcent settings.
I'm on VISTA. I've loaded an Axcent3 from a Win7 machine before with IREDIT, I believe. I've never loaded a blank file first and never recall upload issues at all.
I recall issues with Axcent3 as an IO slave acting oddly when set to address 1. "0" makes it a master, anything else is supposed to take it into slave mode. We were trying to use "1" for slave mode and had some issues with communicating. They all went away when we used 11 instead (anything but 0 or 1, actually, we settled on recommending 11) so serial ports are 11-16, relays at 17, IR at 18-23, IO at 24. We have them in service in at least 15 locations without issues like these... so... this is probably worth a try for your situation.
I also prefer setting the base device number to 11 for *slave mode* because it creates a simple mapping correlation. All you need to do is add 10 to the *master mode* port numbers.
Your right. I presumed it was is slave mode without considering the alternative. Mapping 8-13 would follow from a base address setting at 1... which I stand corrected is Master mode and 0 does appear to be out of bounds.
I have no experience with the unit in anything but a slave mode. If in master mode, I'm out of my element and withdraw, hat in hand.
But the IR sure does upload like you expect when in slave mode.
