DIRECTV HR24
It looks like the IR codes for Ch+, Ch- and directional arrows on this piece are a little bit different than the previous models. I just replaced an HR20 with one of this pieces in a project, and when you press any of this buttons the receiver executes them correctly and all of the sudden starts running like this commands where sent several times. Anyone else experience this? I did a search here under HR24 and DIRECTV but couldn't find anything related.
it's not the pulse times that's the issue with these units passed the fact that they have changed the hold times. we were at 300ms on all our Ir commands for all models. they all still work as before. just installed a new HR24 and that's not the case. even with pulse times to 100ms and adjusting CTON to 1 and CTOF to 3, the dtv box goes nuts on those 6 commands. chan uop/down and all cursor functions. the hr24 gets in a loop and will not stop unless you hit another function such as exit. I don't have time to jack around with electric tape with pin holes poked in as suggested by some. think these are just gunna have to be controlled with serial commands. any other thoughts?
When and where are you sending the CTON & CTOF commands? Define start or the online event handler for that particular IR port? It should be in the online event handler. According to their tech note a pulse duration of 0.5 seconds will be evaluated as a hold which is bad since that's the default pulse time when using XCH, SP or the "Pulse" keyword command so if your using XCH or SP commands with the CTON/OF as described it should work as long as the device (NI device port) is online when you send those CTON/OF commands. If your'e using the "Pulse" keyword you have to use the set pulse time command prior to each IR string and then reset it immediately after since it's a global setting and why using SP is preferred and easier.
What are you using for an IR file? I have found that it is very easy when capturing a button that repeats when held (like your cursor controls) to actually capture several pulses instead of a single one. This is yet another shortcoming of the IRIS that has never been updated ... other IR capture devices seem to be able to account for this. So no matter your pulse time, if it is sending out two commands instead of one, the box might be misinterpreting it as a hold. I've had the opposite happen too, that I only captured part of a command, and holding wouldn't work at all ... you could use a TO command on the IR channel, and it would still just pulse. Different problem, but the heart of it is still a bad capture.
After you've checked what Spike said, which is also correct (especially about using PULSE, it definitely bypassed the CTON, and it uses a global time, not per device), if all else fails, try recapturing those commands. A quick and dirty test (or even fix, if you can stand leaving it like this) is to not use SP, or PULSE at all, but to put an ON and OFF on the IR channel back-to-back. That results in the absolute minimum pulse a device can manage. I've had to do it once or twice with remotes that simply would not capture properly no matter what.
Off topic, but the new file attachment utility pretty much sucks.
the8thst : have you used this ir file specifically on the HR 24 after this update from Directv?
I am not 100% sure the boxes are not HR23's, but I have used this on about 10 boxes that are less than 1-2 weeks old. The IR file is one I put together myself with hex values from an RTI learner (which I think is the best IR learner available).
the new boxes HR24's are rounded with a touchglass face (no hard buttons )
that new ir file did the trick, I guess the file I had had just enough repeats when captured to cause all other CTOn/CTOf settings to not help, thanks
I'm glad that solved the issues for you. The RTI IRpro is much better at learning IR than an Iris, and I use it for capturing all of my IR codes. It takes a little extra time to copy/paste the hex into IRedit, but I know the codes will work every time.
Even better, a pronto panel. (especially with rc5/rc6)
Hello,
So I am also having the scroll problem with the new HR24 DVR only. I tried to download the file but it just redirects to this is not a valid link. I also do not have the RTI piece but will look into getting one. If you can please repost the IR file it would be a great help if it solves this problem.
Thanks in advance
I just downloaded the attached file without issue. Try again.
Anyone else have this problem? I have opened a new thread for this here:
http://www.amxforums.com/showthread.php?7080-DirecTV-Samsung-HR-24-repeat-IR-codes-and-issues-with-DVR-functions!!
Did you try the IR file I uploaded to this thread?
It worked great for me, even with the emitter placed right over the IR pickup.
I did get some rare double hits, but a blocking hood fixed that.
Thanks for posting the file the8thst, it sved me a lot of time.
Joe
