AMINO Set Top Box
Just curious if anyone has done any integration with the AMINO IPTV set top boxes. I'm trying to dig up some information regarding the telnet console that can be added into the stb build to see if I can control these via AMX over IP.
Anyone tried anything with these?
Speak to the Vision2 team at AMX, they have what you need.
I haven't heard anything concrete regarding what sort of control will be availible in the next release and if it will cover what I need.
If anyone from engineering reads this can you drop me a line? The Chinese whispers takes too long
I'm specing a system right now, so I'll ask the question and let you know.
I was told the STB was running custom f/w, but you're saying this is just a skin on the internal browser?
I've asked the question and will let you know the answer (the 2nd answer, the first was you can use IR!)
I'm sitting tight for the moment, but just in case I've specified som GC boxes to sit off the LAN out port on the 130H's so in a pinch I have a local IR and a 232 at the display/STB end.
How did this pan out for you? Got to decide how we're going to play this for 50 units now and the SDK looks like the best option
We use the Amino's but due to security restrictions we were limited to IR. I know that keyboard commands can be used to control the Amino, arrows and numbers. Perhaps some serial to usb keyboard emulator might work. Anyhow the IR capture for this device was painful, I ended up getting an IR file from AMX for the device. It would of been helpful to know that the IR pulse was .3 and not .5.
John
I'm having the same problems trying to get IR working with a 130H - could you tell me what settings you used?
Have tried .3 pulse times, CARON, CAROFF, the ir file from AMX as well as capturing from the remote directly.
From the Amino FAQ Details about finding the brand code are here:
http://support-beta.aminocom.com/ics/support/default.asp?deptID=1281&task=knowledge&questionID=766
Just wondering if theres something else I need to do to get this working.
All I’m trying to achieve is control of channel up and down
Cheers
