DirecTV Craziness!!!
I'm having the most frustrating time with a DirecTV IR controlled system right now.
It's a simple enough code. Button_event with button array setting off appropriate IR code.
All codes work correctly except Ch Up/Down and all the directionals. If you manually set those codes off or do it from the TP the DTV box goes haywire continually going up or down or left or right depending upon which menu you're in. Changing pulse time does nothing. I've confirmed the program is doing exactly as expected and, again, manually operating the IR channel produces the same results. The IR port is not hanging or emitting too long or even continuouslyh.
This occurs on 5 SAT boxes in the house. I have no other problems on any other systems with DTV (that I know of) I've captured the codes from the remote and that still produces the problem.
Another creepy thing is that it seems to have started recently. (about a month ago) I have not touched this system in over a year. I've reloaded code, firmware. no luck.
any helpful clues???
e
e
Here's the tech note:
http://www.amx.com/techsupport/techNote.asp?id=945??
The attached IR file is mostly my "old" file + the nav commands from the DirecTV v2 on AMX's website.
Not saying this is the only combination that will work, but it did for me on two different jobs.
Thanks DirecTV!
Thanks Paul. I did not see that tech note. That's helpful.
Colzie, I tried pulse times of 1 (100ms) with no luck. I'm going on site tomorrow. Perhaps I'll figure it out. Thanks so much for the new IR file. I'll give it a whirl.
Thanks guys!
eric
I ended up finding codes that worked somewhere, I think in an earlier post on this forum... but it looks like a working file was already posted here so I won't post mine.
