Netlinx not finding include files
I have a workspace with 3 systems that all share some common modules and includes. If the first system is active, I can re-compile the modules, but in the other two, they complain about not being able to find my includes, so I need to switch back to the first system to compile. The Include files are in workspace/includes and the modules are in workspace/modules.
What would be the proper syntax to the include statement? In the working system I just have:
INCLUDE 'FOO_Include'
which works
it seems like it should be one of these
INCLUDE '../includes/FOO_Include'
INCLUDE 'includes/FOO_Include'
INCLUDE '/includes/FOO_Include'
But neither of those work either, nor do they work with backslashes.
    I've never been successful with path information in an INCLUDE statement. If the include is workspace specific (including one with multiple projects) I just dump it in the same folder as the rest of the workspace files. If it's common to multiple projects, I have a folder just for those, and have the path set in the NS settings for library paths.
  • AuserAuser Posts: 506
    Under certain circumstances include files won't be found when hitting F7 to compile while editing a module, even though they are in the includes folder of the workspace for the active system. I can't remember what situation causes this off the top of my head - perhaps include files being included within other include files. If you right click -> Compile on the module in the workspace tree or do a Build System, then they'll compile. Bug.
    I'm in the habit of right click -> compiling modules that I'm editing as I've seen the behaviour frequently. I've never used paths in #INCLUDE directives, having them in the workspace tree for the system *should* be enough for the compiler to find them you would think.
  • travistravis Posts: 180
    DHawthorne wrote: »
    It's not possible to make it put the compiled files into a sub directory is it? .tkn and .src and .tko for every module and system makes the workspace directory so untidy.
  • Jorde_VJorde_V Posts: 393
    travis wrote: »
    I keep my modules in separate dirs. i.e. \modules\<modulename>\
    I also put my include files there.
    Also I have no issues with the include files when they're in those dirs.
