HDMI versus RGB and Stereo Audio
I am working with a client whose home is 4 years old and not wired very well for either HDMI or Analog Audio/Video. From my initial assessment I can get CAT5/6 to most locations. Some have limited access or one existing CAT5/Coax to the locations.
If you were designing the job would you sell HDMI or Component Video. Clients budget is tight and I am debating the trade offs between cost, reliability and future proofing. With HDBaseT just around the corner is the expense of HDMI worth the cost. HDMI switchers (any brand) are high dollar. Add in the converters and the cost gets real high relative to the cost of the project. Long runs of HDMI work, but are very sensitive to many factors. Initial design calls for 3 zones and 2-3 sources, a home theater and a mini theater in the family room with a locally sourced Blu-ray. Future growth might be adding 3-4 more audio/video zones and 1-2 sources.
I know having CAT6 (2-3 runs) will future proof the current design.
Thoughts, opinions, experiences, pros, cons and actual experiences are all helpful. Product suggestions appreciated.
HDMI distribution and tight budget don't belong in the same job at this time. You can wire for it in an attempt to be ready for the future, but there is no guarantee.
We use baluns routinely with component matrix switches. They work great as long as you use quality products. If you need 1080p you can add an HDMI Fury 2. I cannot wait for the end of the HDMI fiasco.
Long story short, with the right equipment, it can be done!
The biggest issue is HDCP compliance, and, as it's been said, it simply was not designed for multiple endpoint installations (and, in fact, could very well have been designed to deliberately preclude them). If you want the job to go smoothly and easily, stick with component.
True, but whether it should be used still needs to be evaluated on a case by case basis. You have to decide whether the benefits outweigh the drawbacks (cost, slow switching speeds, possible instability, ...) when launching into a system design.
Even if and when the HDBaseT is released it will no doubt have the same HDCP key end point issues but who knows maybe not. The idea of installing a LED TV and sending AV & power over a single CAT5/6 with no other wires would be cool.
