Axis M7001 as dynamic image
My company has recently migrated to the new Axis M7001 video encoder, and I am having some difficulty setting it up as a dynamic image on a touch panel. The settings I have used in the past for the 241S and 241Q don't work anymore. I opened a support ticket with Axis, and they told me the motion jpeg path is as follows:
http://<ip>/axis-cgi/mjpg/video.cgi
This works in a browser, but not as a dynamic image; I'm assuming because the dynamic image setup tags a <user name>@ in front of the full path, but I'm guessing (not even really sure it does that, but it's how it shows up in the dynamic image tab).
I can get it to work if I use http://<ip>/axis-cgi/jpg/image.cgi, and set the refresh at one second. This is the still image path ... but I would like a bit better than 1 FPS.
Any thoughts?
Any thoughts?
I can't recall if maybe it worked in the TP but not TPD4 or it just didn't work either way. I know around the same time I was playing with an HAI camera that didn't use a path or filename which meant I couldn't make the entry in TPD4 but then Joe H. had a brilliant idea of creating a dummy name in TPD4 and then through code changing the URL which worked.
I can't imagine giving up so easily on the axis cam though so if I think of something I'll let you know. Maybe if I find that camera it will bring back some memories.
I made a temporary login for viewing only: user name = temp, password = pass .
I set this up and tested it on an actual panel... Seems to work fine... See the image attached of the dialog box showing the settings. Make sure your TP has DNS entries. The "Host" name is a zoned domain name.
My TPD maybe older... I would not also assume because you can't get it to be seen in TPD4 that it is not working. Try it on a panel. I never have been able to see Dynamo inside the TPD4 program.
I am using a NXT-CV7 (2.72.11)
Try ignoring the TPD4 error and testing it on your panel. If it still doesn't work, could you reply with the FG# and firmware version of the 8400 you are using.
Turns out it does work in the panel. It won't work with the Dynamo checked off, but that's fine, I don't need that ... at least I have streaming motion MJPG, which is a far cry better than 1 FPS single images. So what I've stumbled over here is a TPD4 bug, not a panel issue.
That leads me to believe that I might have tried that with the new Axis cam too which is why I don't have that feeling like it was an unresolved problem. Of course I did post earlier that I didn't know if it worked on the TP and it just didn't work in TPD4 or if it didn't work in either. Leads me to believe I tried but who the f knows. Those memory cells have evaporated.
In my back-and-forth with Axis, they told me that IE doesn't like to stream video without scripting (they specifically said Javascript), where Mozilla browsers will do it with just the HTTP request. So, if I had to guess, anything that embeds IE is going to have this problem ... assuming, of course, that isn't just a red herring.
Dave, I've passed this on to the engineer responsible for TPD4 and he is researching - we'll post any updates. Regarding the Dynamo checkbox not working, do you by any chance have an 8400 that was manufactured prior to January 1, 2007 (see serial number)? If so, the fast dynamo feature (i.e. hardware accelerated video) may not work due to hardware differences. If this is not the case, could you let me know & I'll look into it?
S/N = 596504X1170058 . I don't know which portion is the date code ... but the original contracts date 2007, so it's entirely likely it's just too old.
I might add, it doesn't appear to work with Dynamo checked when connecting with VNC. I don't have physical access to the panel without scheduling it with the client. It's possible it renders too fast for the VNC connection ... I just get a black screen.
Thanks to the collaborative efforts of DaveH and Billy Duncan at AMX I was able to get the the M7001 to work. My implementation takes the composite video stream out of an IC Realtime DVR into the Axis M7001. This client is using an iPad (WiFi) and 2 iPhones (3G/WiFi) for touchpanels. It is important to set the frame rate to a fixed amount since different browsers and panels can only handle certain frame rates. DaveH suggested 26 but to be conservative I used 24 fps. As SNoble mentioned it is important to use the DynamicDNS URL in your IP Address and a remote port. You can assign the remote port on the Axis M7001 using the Axis configuration software that comes with the product CD. It is set in the secondary HTTP Address. In my case I used port 34373. Here is the string I used.
myhome.dyndns-home.com:64373 axis-cgi/mjpg video.cgi?resolution=4cif
4cif is the frame resolution. You can change per the settings as noted on the M7001 Setup info.
This should allow for easier utilization of the M7001. I nice product with great form factor and lower in price.
David Groves ACE
DG Sales and Service
Do you have any program code you can share for the AXIS M7001 to amx touch panel?
Regards
This might work....
http://www.amxforums.com/showthread.php?6457-Axis-Camera-213PTZ
Mark,
I am not a great programmer like many on this Forum. Vining, the previous poster, is one of the most knowledgeable people on AMX Forums. I'd go with his recommendations.
I will tell you it did take a few tries to get it right for me. I do know you can get it TPD until you get it right.
DAvid
