American Dynamics
I am trying to connect American dynamics camera to NI4100 controller. Camera is Speed Dome Ultra 8 Programmable Dome Camera and I am using RS422 cable like this:
CAMERA CONTROLER
Rx+ Tx+
Rx- Tx-
Tx+ Rx+
Tx- Rx-
Also, I have set baud rate to 4800 like this
SEND_COMMAND 5001:1:1,”’SET BAUD 4800,N,8,1 485 DISABLE’”
I don’t have any communication.
Any idea?
CAMERA CONTROLER
Rx+ Tx+
Rx- Tx-
Tx+ Rx+
Tx- Rx-
Any idea?
This may solve your problem. When using a Sony EVID-70 camera (for example) AMX TX+ is connected to Sony RX-. Perhaps your camera follows the same polarity convention as Sony, and opposite the AMX convention.
The other thing to watch out for is that the installers followed the proper pin convention on whichever connector you are using. Pin assignments for one of the two-port cards are not at all the same as pin assignments on one of the serial ports with a DB9 connector.
If all else fails you can try connecting RX to RX and TX to TX. There will be two polarity possibilities there also.
