Program Main External Button on NXD-700Vi
Hi Guys,
Im looking to implement some panel to panel VOIP features for the first time and thought it would be a good idea to use the main extrernal button (usually used to access setup features) as a push to talk button. Does anyone know if it is possible to program this button? I cant seem to edit its properties through TP4 Design! Maybe it requires some coding? If this is the case does anybody know its channel number?
Shane
Shane
Yeah I tried that! However, it doesnt allow me to click on the center button to edit any of its properties. I can edit the two buttons either side without a problem. Were you able to click on it as you suggested?
That's possible, because holding the middle buttons enters setup menu. Holding it longer enters calibration menu...
