Axr-rf falling asleep?
in AMX Hardware
I have a system with a axr-rf for a RTI remote that works ok now that i worked some bugs out of the code. However, I am seeing that it seems that if the axr-rf is left unused for 30 minutes or so it becomes locked up or simply asleep. I have to unplug axlink (power) and plug it back in before it will receive commands from my RTI remote. I played with the RTI remote continually for an hour with no problem which leads me to believe that the rf box is falling asleep somehow after being idle for a certain period of time. Anybody know anything about this issue? And yes even when the rf box won't respond the green light blinks like everything is normal. Once a second. The red light does not blink of course when I am experiencing the problem.
You can't rule out the thing going bad though. I'd try another AXR-RF first.
It's also strange that it seems like some of the channels are coming in incorrectly. Like on one press I see (through telnet debug message) that channel 25 is coming in. Then I press it again and it comes in as 24. Very bad when you are trying to ramp volume.
I'm using the RTI U2 and I just dragged in the appropriate commands from an amx RF file that I've had for awhile.
