Viewstat Communications
Scottpulman
Hey guys
Need some help with a ViewStat system that has suddenly stopped communicating.
I have 2 Viewstats connected to a Slave Axcent 3 via a distro board.
This system used to work, suddenly stopped, now I am trying to figure out why. To make it even more fun, I did not do this job originally, the original company has gone out of business so I am cleaning up... so to speak.
Anyway. I have communication, well I get responses, however they are not what I am expecting to receive. ( check out the attached screencapture )
I have swapped ports on the Axcent 3, I have tried an NI-700, I have remade the cable ( they were using those *#@Q*T#@$ cat5e to serial adaptors.... ) still nothing.
To me it seems like some sort of baud rate issue, but I can't figure out why. I have verified that the port is set to 9600,N,8,1 and 485 is off, but I still get these random responses.
Has anyone out there seen anything like this before?
Any ideas?
Any ideas?
I don't think the baud rate is supposed to be 9600. I'm not at my desk right now. But, i thinks its something like 38400 or something. Either way, verify the manual for a vewstat/aprilaire 8870.
e
Where did you find that? What manual. The one that I am looking at VST.OperationalReferenceGuide.pdf has the following only talks about RS422, never R2485..... hell even the AMX module ( non duet of course ) is the 'Viewstat422_Comm' module.
Im not putting it past, i think that we have all found conflicting documentation before, just want to get my ducks in a row.
Can you send me a copy of that manual?
I've always used the 422 com module too. That info was form the AprilAire8870_Programming.pdf and I beleive it's the only programming reference they published.
Most every problem I've seen with an 8870 network stems from one or more stats failing, screwing up the whole buss.
