Remote Transfer via NetLinx Master
Is it possible to add an option for TPTransfer to connect to i-devices via the NetLinx Master aka "Local NI Master Local Host"
If TPTransfer could connect to the NetLinx Master, updates could be achieved via the URL list (master-to-master), just like any other AMX touch panel. Many updates could reasonably be performed without a site visit, if the TPTransfer tool supported connections through the NL Master. Under the current model, there seems to be no way to transfer an updated UI without being attached to the same local network as the i-device. VPN access is not always an option, either due to corporate policy, mobile systems, or other network limitation.
Since TPTransfer seeks and connects directly to the i-device (iPad / iPhone), it does not appear possible to perform a UI or application update from offsite location.
In my case, I'm supporting the iPad UI for multiple sales people around the USA and seldom have direct communication with their iPads on the same network / WLAN.
Traditional dealers, particularly in the residential market, face a similar challenge in support of their clients with single or multiple homes.
Paul Bohnsack
Sales Engineer-Education
AMX
Paul Bohnsack
AMX
I believe one option would be set every iPad with a unique transfer port and add them one at a time in TPTransfer. This of course operates under the assumption you're using port forwarding. I tested this out once using my external IP, and it worked.
Since it seems to be an AMX controlled product the ability to go through a master would be nice. Heck I'd be happy if I could keep the dam file open whilst I xfer.
TPC would / will need to use the transfer code (0x0204 per the ICSP patent) in order to go through the master. While I'm sure they're capable of following the protocol provided in the patent, it just happens to be many years old and I assume prior to the ability of encrypting the ICSP connection. My guess is AMX won't provide the encryption process to TPC.
The file lock is an AMX issue, not TPC.
I would love to be able to enter a file location into the TPControl App for each device and then have the devices verify they are running the latest version of the file on startup.
I have found that it is quite difficult to setup service calls and system updates during business hours when the homeowner's phone is onsite to receive the updates. It would be great if I could do the service call, test on the iPad or iPod touch in the house, and then the homeowner's phone would automatically update itself the first time he launched the TPC App after getting home after work.
In my mind the best solution (and easiest for TPC to implement) is to use TPTransfer to send the file to an FTP directory on the master and have the i-Devices check in with the master for the latest revision. You could have a root TPC folder if you want all devices to use the same file, or specify subfolders by device number if you want them to use individual files.
