Full Transfer while Smart Transfer enabled
jjames
Since Tech Support is either A) too busy to return emails, or
they don't like me anymore - I think it's about time I try to get an answer from people who could at least speculate; maybe if I'm lucky enough, I'll get engineering to chime in.
On occasion, I'll transfer a TP file, and next thing I know, it's deleting the existing file on the panel and transfers everything, graphics and all. (Not system graphics.) I have Smart Transfer enabled, but it just doesn't do it sometimes. When it really aggravates me is when all I had to do was move or replace text on a single button, on a single page and have multiple panels to do.
I'm trying to figure out if it's something I'm doing wrong, or if when the panel & software compare manifests, it wigs out. Ideas?
That's assuming, of course, you aren't mistaking a system files update with a full transfer. Those happen every time there is a TPD update (or so it seems), and of course not all your panels get it until you need to revisit them for some reason. It takes nearly as long a s full transfer.
If it happened maybe once a month, but this is every other job. And when it takes 10 full minutes per panel, and you've got 4-5 panels to do? Talk about a WASTE of time. Can't download code. Should be editing TP files while this is happening. PITA.
I found the full transfer on TPD is nearly always faster than a "smart" transfer anyway. Checking for changes takes longer than sending a complete 40 meg project. I don't what's taking 10 minutes per project unless that's the "smart" analysis net time. I go to system settings, click REMOVE USER PAGES, back out, run TPD, it takes about 1 minute to get to its demo page, then start a full transfer. It takes about 30 seconds to move the whole file. Then about two minutes after disconnect to get to operating. But after the one minute connection, I can disconnect and start the next panel.
I'm transferring remotely, hence the longer transfer time. You can't tell me it takes about 30 seconds to transfer a 40MB file remotely - well, you can, I just wouldn't believe it.
The comment about how small changes can void the manifest stand, the bit about emptying and always doing full is wrong (except for TPC on iThings).
The manifest is like a snapshot, and the content in the file is like a bunch of tetris blocks. If you add a few or remove only certain ones, the snapshot can be compared. If you change just enough that the blocks (memory footprint) reorganizes for compactness, the manifest can't be effectively compared, so it presumes it must do a more complete send to be correct.
Quality of the analogy notwithstanding, this description seems to jive with my experience.
Danny - I'm not running anything like that. I manually do a clean disk every so often, but doubt that's it.
